View Full Version : Drivetrain
- Do I need to match balance new flywheel?
- auto-standard swap
- Transmission guys inside please ~~~~>
- Single pad Mcleod owners, INSIDE
- need some gearbox help. please look.
- clutch pedal issues, please help :(
- Finally Installing my clutch
- Anybody using a Ford 8.8"?
- Advance Auto LT1 clutch?
- Anyone installed their own rear gears?
- deep transmission pan... which is the best for maximum cooling capability?
- how hot is too hot for an auto transmission to run?
- does anyone know....
- What Type or Gears...?
- slp converters
- shifting in to OD to soon
- ***Spohn Torque Arm Help***
- Strange 12-bolt owners in here please>>
- 3.73?
- Speedo with th-350
- Years of the 4L60
- GM Service Manager Info... Does this sound right?
- torque converter question
- Easy transmission ? inside.
- High Horsepower Auto Tranny???
- Need Advice/About auto transmision PLEASE HELP.
- Who has adjusted their Mcleod Master Cylinder?
- HP on a Mcelod single disk
- Need help with driveline vibration please...
- What posi unit came on a 2000 Trans am W/O ram air?
- Pinion seal leakage
- Th-350 swap
- Best way to dispose of a T56??
- Driveshaft question
- Idle speculation- T-56 behind big block in 2nd gen
- Tranny noise?
- 4l60e and 10s
- Clutch install
- A4 slips only when cold?
- 28 spline axels?
- Cryo Rear Gears?
- is my slave cylinder shot?
- pros/cons spec 3i
- Flywheels do you really need them?
- Clutch Q&A
- Questions on changing clutch slave cylinder
- 1993+ carrier?
- 93 formula stall verter
- no 2nd gear
- is it the clutch or flywheel
- what stall for my car
- any interest in a drive shaft group buy ???
- 8.8"
- lt1dave tranny's?
- abs delete
- torque converter?
- My tires stick out too far on one side....
- Tranny grinding???
- I went and did it this morning!
- converter question
- SLP stall converters???
- Best Automatic Transmission Fluid?
- Going from to a 400rpm lower stall...reprograming??
- TCI Competition 3800 too big?
- Centerforce clutch guys, have a ???
- Got a midwest 3200 w/2.0 str. What cooler to get??
- speedo gear
- Making the 10 Bolt rear end stronger??
- Uh oh! Transmission slipping, or not?
- mcleod 7500 and stock lt1PP
- 4:10 gear question...
- T-56 to bellhousing bolts???
- Centerforce Disc question
- Bad Clutch!!!
- Which Stall to get?
- 4L60E question
- viper, ls1, or lt1 t56?
- Where to get best deal on Stock replacement clutch?
- installed sway bar now have hard vibration
- mcleod performance clutch
- Flywheel hot spot?
- 3.73 question
- repairing reverse input housing(dished from band)
- t56 good ones, bad ones
- My Clutch?
- 3.23 to 3.73 gears what else
- Possile Auto Trans Problem
- Great improvement
- strongest driveshaft ????
- Whats the stock Driveshaft Measurements?
- tranny mount?
- Stock TC, How much does it weigh?
- 700r and 4l60e the same??
- 3-4 clutch pack
- 9inch posi ?
- T/A cover and stud kit worth it???
- tire size
- Converter Question
- Manual To Auto
- Need Help finding a part/part number
- Spohn TQ Arm and lowered cars...???
- 3.42 questions
- my REVERSE is F'd up!!
- Questions About 10 Bolt Axle Shafts
- Tranny messed up. Check balls in wrong places?
- Having a few problems after verter install
- problems with tranny...
- Clutch not disengaging, please help
- Rear end sounded like it was falling off at low spd(clunks)
- 6-speed transmission.....
- Breaking a 12 bolt??
- Best shift Kit
- Ring & Pinion setup?
- Pinion & Ring Gear setup?
- Grinding noise?
- how much are gears?
- Mcleod street twin question
- Question about Stock Torque Converter
- tranny help
- What clutch should I use?Spec?
- Tranny cooler install....Question!!
- Rear End
- Higher stall torque converter questions.
- Tranny Problem on 4L60e
- Clutches??
- Does an '85Z28 700R4 bolt right up to say, a '94Trans Am w/4L60?
- '94TA/A4 --- Questions...
- Rearend questions...
- TH400 trans - help please
- What gear oil & LSD Additive should I use??
- pricing on T56 parts
- Is the Corvette A\4 tranny the same as the LT11995 A\4?
- Tranny sound, whats makes it sound different then my?
- Not an F-body, but maybe trans exerts can help
- SPEC stage2 owners inside (drag racing?)
- diognose this!!
- McLeod throwout bearing for push clutch?
- Why is my tranny shifting so HARD?????
- Torque Converter
- Questions about installing driveshaft
- Hhhheeelllppppp!!!!!!!!!
- 8.8 Ford Rearend in 4th Gen F-bodies?
- CFDF problems
- m6 rebuilders inside!!!
- Welding Rear spider Gears??? Good Idea
- shifting issue's
- Limited Slip maintenance
- Clutch pedal vibration
- Adjustabl Slave Cylinder
- specific 3rd gen tranny question- 700r4 electric speedo bounce
- Has anyone succesfully rebuilt a 4L60E??
- Questions about manual transmission...
- Rearend moaning in turns + braking.
- T-56 swap...neutral safety switch works backwards
- Can you damage your a4 transmission and/or engine by manually upshifting?
- TCI 3800 Stall
- downsides to '93 T56's
- Cost of Upgraded Rearend
- Any of you guys have short throw shifters on your ls1?
- Performance axle
- T56 Question
- Transmission help
- Grinding T-56
- Suspension ?'s in here.....
- ring gear space. Do i need one?n
- Broken Trans Mount?
- 700R4..No O.D. after rebuild??
- Gears
- rear gears
- Possible need for new or rebuilt T-56, point me the way.
- Question
- 4L60e tranny shift problem.
- How to disable CAGS light on 1998+?
- Turbo 400 questions and wiring on 700R
- Changing Clutch
- t5 on older pre 80 motor please help
- Intalling TQ, What is benifit of swapping in a TA girdle?
- Auto tranny question
- transmission hp max?
- Pulsing when converter is locked
- Diff and manual tranny coolers
- Torque converter ??'s..whats it like?
- Clattering From Converter on A4?
- Trans blowing fluid
- Rear End Question
- question about the pro 5.0 shifter
- Converting to 3-channel ABS (or, how to remove Traction Control) ?
- How much doe sit cost to have a converter installed???
- what would keep reverse from gong in??
- foamy gear oil??
- Gears+M6=What MPG
- differntial fluid
- Zexel-torsen
- tools?
- T56... need help..
- Tranny is gone...
- reverse input drum
- Who makes the strongest 4L60e in the NJ area?
- How do i know if my clutch is going bad?
- Strong 10 bolt ??
- Light Flywheel !
- Converting auto to 6spd
- T-56 Troubles - need advice!
- Anyone using the S-10 Torque Converter?
- Which One!?!!?
- rear axles
- 28" ET streets
- Anyone take out their 4.10's to put in either 3.73, or stocks?
- Switching Axles?
- Driveshaft play
- 4l60e limitations ???
- Upgraded posi for series 2 carrier?
- rearend about to go???
- Help with drive and driven gear
- 4L60E Prolblems
- rearend problems
- Where is Pin A on the VSS?
- Problems with my 700R4 in my Truck. NEED HELP!!!
- clutch disks
- driveshaft length for th400 and 9 inch
- Is there a break in period for new stall converters.
- A4 to M6 Crossmember?
- Auto to Manual Conversion
- Wooshing Sound?
- upgrading to a stage 3 ?!?!
- This cant be good
- cant disengadge the clutch
- During WOT, does the TQ supposed to Lock up? or not?
- Street Twin break in question please...
- Best Tranny fluid
- clutch disks
- T56 Flywheel thickness?
- A "rearend" question.
- tranny coolers...
- 8.8 rears
- strange 12 bolt
- Help me with Ford 9" install???
- Edge TC
- raptor trannies
- grinding..???
- A4 to M6
- whine at 40-50 mph.. my guess, would like input.
- weird noise
- Need Opinions on Midwest Converters
- Dyno results
- Pinion Bearings/Pinion Seal
- speedo and 3.73
- Does anyone sell a T-56 REBUILD VIDEO
