PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69
  1. Tranny time....AGAIN
  2. All 9" rear users inside please
  3. All 9" rear users question
  4. Were is that thread on OBD1 highstall fix. (the shift cable adjustment one)
  5. Strange Chrome-moly driveshafts ?
  6. Would you do this with your rear end?
  7. trans question
  8. Problem with Ram Clutch
  9. quick ?: How much will it cost?
  10. How much HP can the 02' stock rear end handle?
  11. Clutch problems after cam install...
  12. Need a 3.73 2-Series Gear
  13. If the transmission shop tells me I'll need to replace the electronics in my 4L60E
  14. spec stage 4..carbon/kevlar or ceramic?
  15. Issues with freshly installed SLP PP & McLeod single disc clutch
  16. 4L60E Question?
  17. Tranny Problems
  18. HELP/McLeod Street twin engagement issues
  19. Can somebody tell me...
  20. Tranny Rebuild???
  21. Want in a TC causes min. rpm drop between gears
  22. 4 channel ABS
  23. stall and daily driving?
  24. moser 9 inch install...what will i need
  25. Does the tailshaft have to come out to put my speedo gears in?
  26. How do you guys feel about TCI tranny's
  27. Trans go install need help
  28. Need Help Trans-go install gone bad
  29. M6 - bucking at low speed - normal?
  30. 3 series gears in 2 series carrier??
  31. tci torque converter ?
  32. Tranny cooler and TV cable reset?
  33. Downshifting from OD or bad converter? HELP
  34. Stall speed and lock-up via PCM
  35. tci converter wont bolt up to flexplate
  36. 4:10 gear diffrence
  37. Ok to use compliant oils from NAPA for drivetrain parts?
  38. Centerforce Clutch???????
  39. stock rear end
  40. Moser 9" questions
  41. torque arm
  42. bmr tunal brace
  43. vig ?????????
  44. Which year cars had 700r4
  45. What years had 700r4
  46. M6 swap: floor hole location
  47. Vig3200 is in
  48. good or bad thoughts on a 8" 3200 converter on a bolt on LT1
  49. Where to get new driveshafts?
  50. drivetrain
  51. How hard to drop a 4L60-E tranny?
  52. 99z Rear End
  53. Thumping noise on acceleration
  54. Gears or Torque Converter
  55. how to mount rear sway bar to moser axel ?
  56. slave cylinder woes
  57. 93 t56 swap couple questions
  58. clutch install
  59. Cleaning clutch disc?
  60. Anyone replaced a pinion seal in thier Moser 12 B?
  61. 4L80E into '97 F-body..who's done it?!
  62. Driveshaft: Aluminum or Steel?
  63. Need advice... balance steel d/s, or go aluminum?
  64. how much HP will a stock t-56 hold?
  65. any reason NOT to go with a 8" converter
  66. Grrrr...TC or Gears?
  67. 2 series carrier
  68. will my rear end hold?
  69. Want to use a 3 series rear in a 4 series car?
  70. Before I ****ing spend all this money on a rebuild kit...
  71. clutch install
  72. What are the symptoms of a bad throwout bearing???
  73. tranny temp with stall
  74. Help me Pick a clutch, Cant decide!!
  75. Tranny swap guide?
  76. stall converter question
  77. Clutch fork instal woes
  78. p/n on GM 4.10 gears for 3 series carrier?
  79. Converters too loose, Can I kick it into 4th gear down the 1/4?
  80. stay with the 4l60e or move on to another type of tranny?
  81. help m6 tanny making noise
  82. What's up with my LSD?
  83. What's my rear gear?
  84. Clutch toast?
  85. LT4 clutch ok into LT1 motor?
  86. No Overdrive
  87. Broke a ring gear - are my gears trash now?
  88. gear choices
  89. Not impressed with the Pro 5.0
  90. Manually Shifting an auto?
  91. transmission?
  92. My auto is P-R-N-OD-D-2-1 ?
  93. Rear end shaking on downshift!
  94. Info please
  95. What to look for when pulling diff cover?
  96. HELP! Vibration problem!
  97. Is this normal?
  98. Corvette Servo
  99. Breaking a 10 bolt? What happens
  100. gears
  101. Upgrading my a4
  102. Grinding?
  103. New Mcleod. Totally Hosed.
  104. Tranny cooler in! did I do it right?
  105. Adjusting B&M Megashifter in 3rd Gen
  106. new trany
  107. driving an A4 manually in first
  108. Rebuild or buy new T56 tranny
  109. How hard is it to convert to manual
  110. throttle position and shifting
  111. Auburn carriers?
  112. is transmission shot?
  113. TC help from a roll?
  114. gears
  115. Tinny click sound in Tranny
  116. Absolute horrid, end of the world noise coming from drivetrain
  117. 1993 M6-Any problems?
  118. LUK Clutch and Flywheel
  119. Lost all forward gears - Still have reverse. What broke? and don't say the tranny!
  120. Tranny go boom (M6)
  121. how do i know where the shift points should be with 3.73 gears?
  122. soild pinion spacer install
  123. On my recent roadtrip I noticed something, is it a worn synchro? Please take a look..
  124. Tranny Grinding/rubbing noise
  125. New G2 Diff Cover, need help with installing please!
  126. Problems with an A4 car after cam install
  127. What are the symptoms of air in the clutch lines?
  128. Automatic Trans. Hits Rev Limiter Before Shifting
  129. Is this rear worth $400?
  130. Slave and Master cylinder for clutch
  131. Rattling noise when clutch pedal is all the way down...
  132. M6 sticks in 4th
  133. Vibration Not driveshaft!!!!
  134. 12 bolt or 9" ford rear" pros and cons please
  135. Is the trans mount from pep boys just as good as the dealer (for a ls1)
  136. Identifying 4L60E
  137. cop camaros and their rear ends
  138. Quick Question
  139. How are aluminum flywheels fro street cars
  140. 8.8 rearend
  141. clutch return???
  142. COPO Posi traction with 4.10 gears rear end - Does this exist?
  143. A4 to M6 swap kits
  144. Art Carr vs Pro Built, whos better
  145. going from 3:23 to 3:73 on a A-4, any difference?
  146. Put new SPec III clutch in.. Grabs but clunks when rolling??
  147. How to put posi in.... read!
  148. SPEC II or III ??? 410hp/450lb ft..?????
  149. Paging all converter owners
  150. How many trans mounts?
  151. what is the backlash for gm superior gears and how do you adjust it?
  152. does size matter
  153. person at pi says get 2800 stall? seems to low in my opinion
  154. Hydraulics or Bad Clutch???
  155. Necessary tools for settup up rear gears?
  156. Removing Strange 12-bolt axles
  157. steady "clunk clunk clunk" diff prob?
  158. Did the 95 lt1 formula really come with a Australian rear end??
  159. Tranny wont downshift into 1st gear
  160. (Wrong section I know) Need quick answer about bent CLUTCH fork
  161. clutch and gear ?
  162. Blew up my limited slip, what are my options??
  163. Z06 clutch in 99Z hydraulics required?
  164. A4 4.10 owners inside please.
  165. 3rd gear Syncro problem
  166. Writeup for DIY rear gear install?
  167. 2 different trans go kits???
  168. 12 bolt or 9"
  169. torque converter lockup at WOT??
  170. shifter ?
  171. spec clutches bad?
  172. WOT line pressure drop
  173. Differences between Mac and TA rearend covers?
  174. Will a 99 vette T56 work in my 95 TA if I use my bell housing?
  175. Upgrading my Gears
  176. what stall and brand would you recommend?
  177. how much worse will my gas mileage be goin from 3.23 to 3.73?
  178. What Gear Noise is Acceptable?
  179. Equivalent to MCLEOD TWIN w/ Alum. FlyWheel???Cheaper of course...
  180. Question about rear end "clunking"...
  181. 2.73's and 3500stall??
  182. clutch, tranny and rear end questions
  183. Is This A Good Tranny?
  184. No 3->4 shift
  185. rebuild question
  186. Drivetrain Question
  187. turbo 350 band adjustment
  188. Strongest drivetrain on a budget?
  189. Spec Stage 3 hybrid is in
  190. how to tell? Tranny slipping
  191. 2.73 to 3.73
  192. SPEC To Develop a Twin Disk?
  193. mcleod kevlar/organic or street twin in my ls1??
  194. 4l60E auto tranny
  195. trans is slipping
  196. vig converter same for 96 lt1 as ls1??
  197. Best stall for the money?
  198. dacco converters any good?
  199. Stock 4L60E specs?
  200. if u put a detroit locker in a 10 bolt
  201. 4L60E and EDGE Converter Problem
  202. what are my gears options?
  203. 700 hp t56
  204. can't get diff out. little help please
  205. How scared of 10bolt? Price of 12bolt?
  206. Need a 4L60-E, told only a '94 will work
  207. P1870 transmission code
  208. line pressure
  209. 99Z Rear End Rebuild Kit
  210. Clutch and flywheel ?'s
  211. 4L60E wont upshift past 2nd gear?
  212. Anyone with McLeod Single Disk and/or SLP Flywheel???
  213. 40-50 mph in D ?? a4
  214. New Clutch and Flywheel
  215. Spec Stage 2
  216. Is this my clutch??
  217. anyone familiar with the fast kit
  218. tranny's slipping what to do...
  219. Vacuum modulator conversion for 4L60E
  220. Help!!!
  221. shifter accidentally went into reverse from 3rd on my A4 60E
  222. Removing a '95 4L60E?
  223. 4l60e 2nd gear start
  224. Need Info/Advice on 1st Gen Conversion from Auto to Manual
  225. Too much tranny fluid cause grinding??
  226. Clutch questions
  227. performance
  228. What tranny fluid to use in T-56 trans?
  229. gear brand choice
  230. which converter for my setup
  231. rear motor seal
  232. Tractech Differential?
  233. which transmission to upgrade from stock 4l60e?
  234. odd gear install question?
  235. Spec Stage 4 Review
  236. converter lock up
  237. HELP PLLEASE! rear end clunk- U-joints?
  238. Crusing Engine RPM with 3.42 and 3.73
  239. will my stock rear end handle 3.73
  240. 1978 Trans-Am 10 Bolt Factory pinion depth
  241. new slp ctuch slipping, replace or fix?
  242. Rebuild 700R4
  243. Tranny cooler size?
  244. 4.11 gear?
  245. 12s with 2.73????
  246. clutch slipping ??? Or pressure plate weak ?
  247. Not your typical "need clutch advice" thread...please help decide.
  248. Not your typical "need clutch advice" thread...help me decide...
  249. Sound like a vehicle speed sensor?
  250. Moser Questions(D.S)
