Clutch fork inserted
Old Feb 7, 2005 | 09:56 PM
AlmostfastLT1's Avatar
I have a 94z LT1, spec stage 3, I want to know when I install my clutch fork onto the throw out bear and it clicks in, how much play is there. I know it is on it, but are you all to wiggle the fork when it is installed (not pulling it out or in, just wiggling it side to side). Or just it be very tight and you have to pull it off the throwout to be able to wiggle it.
Old Feb 7, 2005 | 09:59 PM
1FASASZ's Avatar
Re: Clutch fork inserted
mine always has some play
Old Feb 7, 2005 | 10:16 PM
OBE1 95Z28's Avatar
Mine has side to side play also.
Old Feb 7, 2005 | 10:31 PM
96camaroz28lt4's Avatar
When I installed my clutch it felt like it wasn't on tight but it was on. Just install the slave cylinder and mash the pedal and you will feel it. But when you install a clutch it feels like the clutch isn't even engaging because the pedal is so soft but it really is.
Old Feb 7, 2005 | 10:56 PM
thanks guys just worring a little too much!
Mark
Old Feb 9, 2005 | 10:00 AM
I notice that when I install the clutch fork it clicks and has some movement, but when I pushed the clutch fork it slips off throwout and hits part of bellhousing (pushing it like a simulation of how the slave pushes the fork to pick up pressure plate). I looks like it is on but like I said when you push it it hits and looks like in needs to go in another inch or two to clear the area around the fork(bellhousing).
Mark
Old Feb 9, 2005 | 11:46 AM
CamaroBoy96Z28's Avatar
If the fork falls off or is hitting any part of the bellhousing, its not on. When its on it should be very obvious, the paddle part of the fork where the slave pushrod fits into the recess will be situated in that opening on the bellhousing where the slave bolts up without anything in the way. Keep messing with it, it'll go into place.
Old Feb 10, 2005 | 10:56 PM
I just think the fork may be bent from when my buddy was pulling on the motor when the fork was still connected to the old clutch.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
