- 4L60E pan
- what torque converter and lockup for a cc306 and ported heads?
- Installing Short Stick?
- installed shift kit, code 73
- Richmond Gear install video
- T56 Inspection Cover bolt size
- installing site for spec three
- HELLLLPPPPP me
- Would this clutch kit work?
- Chattering Clutch is Waaaay Better
- 4L60E Perormance?
- Mcleod ?'s
- Are the LT4 and LT1 Flywheels the same?
- What does a torque converter do?
- Rear pinion seal ?'s
- Rear end gear oil?
- has anyont installed a hurst v-matic II shifter
- A4 Problem when Changing gears
- NEED HELP!! 700r4 overheated and wont shift!!
- LT1 T56 Bellhousing?!?!
- Shifter popping out of 3rd?!?
- Will my 9 bolt hold up?
- 3rd gen posi and gears interchangeable?
- Distance from the fly wheel to the edge of the throwout bearing?
- rear end question
- Help my find this mysterious clunk.
- car make-over
- What are the symptoms of a bad clutch?
- Need close up picture of Clutch Fork
- 5 speed.
- Help Please
- Hurst T handle
- should i attempt to rebuild my t-56?
- Rear Pinon Seal?
- how much work and cash for Manual Conversion
- Weird vibration
- Transmission Shifting Problem!
- Ripper shifter install.
- What kind of clutch should I get?
- Spec Stage 2 clutch and Q's
- Stock 2.73 Gears
- HELP!!! removing tranny
- Spun an axle in my Eaton at the Track
- SLP Shifter question????
- Auto Shifter
- Buy auto trans or rebuild it?
- transmission wont go on all the way
- Details on Trans and Rear help plz
- POS 4L60E "HELP"
- rear strength
- flywheel
- clutch install
- 98 stallconverter in a 95
- Clutch Install problems!
- A4 Trans help
- tranny cooler?
- Slave cylinder adapter spacer thing, where can I find one? whats its correct name?
- transmission swap
- spec or centerforce?
- A4 shift issue
- 3400-3600 stall
- Is this a good idea?
- Pro's & Con's: Roller Pilot Bearing or Stock Bushing..
- ebay shifters
- th350 trans cooler q?
- Roller pilot bearing install in LT1
- How much power can a Stock clutch hold?
- Car is stuck in drive
- T56 bolt to 6.0?
- how do you tell what kind of gears?
- Does ARP sell pressure plate bolts that actually work?
- Hurst billet plus install ?
- A4 and T56 Crossmember similar?
- Anyone use braided steel line for tranny cooler??
- 5 speed poping out
- Rear Install... in driveway...
- another convertor question
- A4 and M6 Torque arm the same?
- How fast am I rolling? Math Prob!
- How involved is a pinion seal?
- Should I get an aftermarket shifter or just the handle???
- I need a few questions anwered (4l60e)
- New Spec 4 Does not totally disengage????
- 700R4 Vig 4000
- Tranny Flush?
- Few questions on a moser 12 bolt before buying...
- Third gear is gone
- Sumitomo HTR z tires?
- wich stall?
- NEW 9 Bolt Borg Warner Rear End ideas needed
- need help with an axle problem.
- v6 drive shaft on strange 12 bolt?!?!
- converter doesnt lock
- Tranny Question
- New rear end?
- Tranny noises in 1st and 2nd
- Speedometer gear install problems (couldn't find what I needed with search feature)
- Paging Pro Built Automatics ??? pm`s full
- problem with 3rd
- Do i have 3 or 4 channel ABS?
- Has Anyone Else Had This Problem
- will ls1 adj clutch master work in lt1 car??
- anyone replace tranny bearing races? -- need help
- clutch will not disengage -help cars stuck
- a4 wont shift at or close to WOT
- T56 popping out of reverse - Something I can fix myself?
- When engaging clutch something is binding and motor will stall
- Help pick a trany setup
- what's involved 94z moser 12 bolt setup?
- Shifting problem
- A4 Wanting to get a new shifter
- Growling noise
- 3.73 problem
- Fitting issues with the Spec Stage IV
- TH350 conversion complete now car wont start
- 10 bolts ford sale
- clutch for 350rwhp
- t5 poping out of 1st
- Will a yoke from an LT1 10 bolt fit ....
- 700r4 probs
- PLEASE HELP- problem with 12-bolt order from Tbyrne
- Help me pick which gear ratio
- What series carrier does my Moser 12-bolt have? (and other ?'s )
- will a stall kill an a4?
- Which clutch is better SLP or RAM??
- Trans cooler
- Rear end leak
- Rear End Gasket
- about my stall converter
- transmission fluid color?
- "click"?? in rear axle/diff
- a4 to m6=car wont start
- What is stronger LT1 or LS1 drive shaft?
- 4L60E Articles
- Mcleod Street Twin HELP ASAP!!!!
- Gears
- Mcleod Street Twin Install Question
- Quote for Rear End gear installation..
- has anyone used the hurst TH350 conversion kit
- manual valvebody
- 3rd gen wheel size
- 8.8" rear end
- Need Cluch Recommendation
- 700R4 Leaking
- High Stall Problem Possibly
- 383/396 owners inside - Q on flywheel balancing
- What gears do I have???????
- What would keep a T56 from going into Reverse
- 26 or 28 spline?
- limited slip to posi
- stock T56 ?
- 83 z28 campatibility with a 88 camero
- Screetching noise from the rear end?
- 94 4l60e in a 97 not compatible??
- t56-6
- 1994 4l60e into 95 z28???
- New here...rear end noise
- T56 dust shield part number?
- axle help
- Rearend noise
- Spec stage 2 installed!
- Which is better Buy transmission or rebuilt?
- transmission/driveshaft alignment
- Will I have enough gear??? th350 guys
- installed B&M Transpak, now...
- th350 dipstick
- any good sites for installing spec 3
- Tranny swap, throwing new code for TC??
- Pigtails?
- Which VSS do I need?
- No tmission gears?
- Edelbrock Torque arm=CRAP
- 1999 Camaro Skip Shift>? Help
- 01 Z28 rear end noise
- Removing A4 dipstick tube bracket
- Will tail shaft on 700r4 work on TH350?
- Which Clutch. Spec IV or Street Twin?
- Can i run drag radials?
- 1-2 shift getting soft
- Broke rear end and now tranny seems messed up..
- For those who have Moser 12 Bolts...
- Spool in a 7.5 10 bolt, Break or not to bread??
- Car trouble acting up.
- how much did you guys pay to get a torque converter installed in your LT1
- Rear Axle Bump Stop OPTIONS?
- 12 bolt from older 60-80 chevy worth it?
- mixed reviews: drill out mod (for clutch/slave line) or no?
- Rear End Girdle
- DAMNIT I knew I would run into problems PLEASe help!
- McLeod street twin install problems
- What rear tires do you recommend?
- straight forward question need straight forward answer
- Getting my Tranny rebuilt
- Please Help!!!! tranny problem
- 4L60E Vaccum Line?
- shifter rattles in 3rd gear
- Whats needed for TH400 conversion in A4 94 Z28 ???
- Viper slip yoke
- leaking transmission fluid
- T56 swap
- ES Trans Mount Whine??
- Where do I buy a performance T-56?
- Need instructions for replacing a broken M6 tranny mount
- Balancing Flywheel and clutch
- what t56 clutches are the best
- Gear question
- how is your 2 step wired to you clutch
- ? diffrence between 3 & 4 channel
- Tranny gods, in here plz
- question about parts from summmit and jegs
- shift kit help...plz
- overdrive trouble?
- Need Part Number for Trans Dipstick and Tube
- Any one know good aftermarket auto Trans?
- Prothane polyurethane transmission mount
- 4.10 in an a4
- Are rear-end gear swaps something i can do?
- Flywheel To Pressure Plate
- WHat kind of gears
- LT1 OBD1 versus OBD2 4L60Es
- shift kit question
- 4th gen driveshafts
- Ford 9" Install
- need clutch help
- Anyone running Yukon gears?
- Centerforce clutch - Anyone had luck with one lately?
- GM Gears vs. Motive Performance.
- Different size Hub on rear of my car
- Tranny Leak?
- Ring Gear question
- shifter question??
- Bent clutch fork?? (pics...and short video)
- I didn't think I could do it. Ratchet shifter in an a4.
- Tranny options...
- Manual transmission that can hold up?
- Do I need a new Driveshaft???
- 9in installed...now vibrating @ 70+ mph.
- Torque converters?
- Mad Dog 700r4, check out the link, let me know some opinions..
- T-56 Transmission for sale!
- rear end question
- Assistance needed with clutch/tranny problem
- 17x11, 17x9.5 tire wear questions
- Vibration
- Clutch for LT1
- i just cant understand the lockup thing..intresting read this....
- Reverse synchro help please!!
- Replacing Reverse Synchro...need help!
- SBC flywheels in an LT1
