PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. stock 10 bolt
  2. 3200 or 3600 converter for LT1?
  3. need help removing my axles!!!!
  4. Swapping rear ends
  5. looking for second gen aluminum driveshaft
  6. 4l60e compatability question
  7. How to adjust pinion angle properly?Weird sound...
  8. Tranny questions
  9. Help! Check my ring and pinion setup pics!
  10. How can I understand it is Viper Specs T56 ?
  11. 3.73 gears or 4.10 ?? thats the question
  12. 3rd and 4th gear mid RPM
  13. This sound like bad syncros or something else?
  14. P1810 code...what to do?
  15. Brand New Detroit Locker for GM 7.5 10bolt
  16. speed vs rpm, 4L60E, 3.23 axle
  17. What rear end?
  18. 6l80/6l90
  19. Maximizing Stroker Motor Efficiency
  20. Odd lockup on converter
  21. 98 rear end swap- need to know?
  22. ford 9 inch
  23. Stock Shifter vs. Hurst?
  24. Clutch w/ no breakin?
  25. Manual having trouble shifting
  26. ls1 trans cooler
  27. Why, the master and slave cylinder come together but..
  28. Need Help Now!!!!!
  29. Getting a camaro with an auto trans to shift into 1st?
  30. LT1 PP vs. LT4 PP. Can I use LT1 PP w/ Mccleod?
  31. Car won't shift into 3rd???
  32. Speedo Calibration for my 93
  33. 01 Z-28 10 Bolt in 96?
  34. t-56 Huge Problem!
  35. Which Stall?
  36. stock T-56 + 383... how long till it goes?
  37. has anyone here done the "drill mod" on an M6?
  38. 6spd clutch pedal coming off of master??
  39. need to know what stock torque converter
  40. Minor Drivetrain Issues
  41. wheel sensor..
  42. 4l60E vs TH350/TH400
  43. Axle Pin Alignment Help!
  44. Screeching noises from the clutch
  45. Will LT4 Throw out bearing work on LT1?
  46. need shift kit part number
  47. Broke 4L60e...again
  48. A4 output line to cooler
  49. pinion nut torque
  50. what code to look for tranny
  51. Looking for info for T56 trans.
  52. shifter keeps popping out of gear.
  53. need measurements on a 9 inch,everybody that has one
  54. Where to get clutches for stock 10 bolts
  55. blown tranny pan gasket
  56. How much play in rear
  57. What do I want in a Rebuild?
  58. got the 9 inch in, getting vibration at 75+ mph
  59. Shifting issue with transmission A4
  60. spec stage 3 is worn out at 30,000 miles
  61. breaking in a new clutch?
  62. How to BANG the pinion out of the rearend housing?
  63. Used pinion bearing preload?
  64. 3 channel - 4 channel diff question
  65. clutch hard shift
  66. need new discs for my street twin.... where do I getthem?
  67. Transmission options
  68. Drivetrain problems - Can't use 1st gear now??
  69. How can I find out what my...
  70. What's this noise???
  71. gears...
  72. possible torque converter problems?
  73. Grip Force clutch from Ebay for LT1
  74. Whats up with corvette servos
  75. My 6 spd did something weird this morning, help me out
  76. Clunk In The Front
  77. newby-z owner
  78. 12 bolt rebuild kit?
  79. t-56 shift kit.
  80. Will gears fit ??
  81. ("for sale" content deleted)
  82. T-56 Clutch fork??
  83. SLP vs HURST
  84. Selling My 700r4/4l60-How Much?
  85. NO shift to 3rd gear 4L60E, HELP FAST
  86. Whine in new gears???
  87. Good T56 Rebuilder
  88. Line Pressure Check
  89. 3.73 Gears
  90. C5 torque converter in a LT1
  91. Need help fast!
  92. how to upgrade to 3.73?
  93. Rear Gears
  94. looking for a new driveshaft
  95. ? will puting a 3.73 in change my shift points alot
  96. 96 Chevy Silverado Question
  97. What kind of power you running through your stock T56s...
  98. McLeod Street Twin first impressions
  99. The age old question, 12 bolt or 9 inch rear?
  100. 6 speed auto swap.
  101. Violent shaking when slamming 3rd...any ideas?
  102. 1997 V6 clutch hydraulic hose removal
  103. installed twin disk and now car won't turn over
  104. does anyone know what gears were ofered in 01 z28's
  105. everybody with a STALL come inside!!!
  106. detent cable ( kick down cable)
  107. 05 GTO Drivetrain
  108. Noisy Rear? Help me out....
  109. T56 swap - speedo questions
  110. could I use a higher stall converter?
  111. need help with shift kit
  112. 4.10 just dont work .....kid need HELP!!
  113. RAM HDX or Spec stage 1?....
  114. changing transmission fluid t-56
  115. t-56 fluid change?
  116. 700r4 for the lt1?
  117. Reverse Lockout Code 83
  118. Mcleod Twin w/aluminum flywheel
  119. Converter Problems?
  120. Can a driveshaft go bad?
  121. Tranny swap
  122. Installing built t56
  123. Replacing a AT trans. for a Manual in 2000 WS6
  124. Electronic or hardware 4l60e problem
  125. all A4 with 4:10's or 3:73's come inside!!!!!!!!
  126. transmission service help
  127. Gears or different convertor?
  128. Is it normal for my 2800 stalled car to.....
  129. Rearend Fluid suggestions
  130. what rear end do i have
  131. Just broke something
  132. 10 Bolt?
  133. DShaft End Caps :(
  134. Rear too far back?
  135. Inefficient converter or normal power loss?
  136. what gears?
  137. Chaning Tranny Filter?
  138. 1LE T-56 Tranny mount?
  139. rear end question, as always
  140. 3 trans pumps in a year.....
  141. Do I definatly have 3.42's ?
  142. Replaced broken tranny mount with poly one
  143. 3.23 or 3.42? Which should it be?
  144. Rear gear ratio related to tire size??
  145. z28 rear end with 3.42/lsd/disc
  146. RAM-88516HDX Anyone use it?
  147. Easiest way to change a throw out bearing
  148. A few questions for you 4L60e gurus...
  149. Truetrac Rearend Opinion
  150. Intermittent SES light -no TCC lockup - any ideas? Please!
  151. Mcleod Single Disc + LT4 PP ? Good Combo
  152. One Wheel Spinning
  153. pro 5.0 vs. hurst billet plus
  154. after moser 12 bolt install i have a weird bad sound from rear....
  155. Trans not holding rpms
  156. Anbody ever shim the slave cylinder?
  157. Re-use 10k mile LT4 PP with McLeod Single Disk?
  158. 93 LT1 Clutch going out, recommendations please?
  159. 98 stall on earlier camaros
  160. Tranny Plug In?
  161. A4 Line Pressure Question
  162. Stall Question
  163. th350 questions........
  164. clutch pedal stiffness with SPEC 4
  165. Stock Z28 rear end gear options??
  166. Wiring question around shifter area: 1995 LT1- M6 drivetrain.....
  167. M6 not wanting to go into 5th after engne rebuild!!!
  168. no 2nd 4th 6th gear
  169. t56 help i think it gernaded
  170. having trouble finding tranny mount part#
  171. limited slip?
  172. Spec 4 clutches what pad design should I buy
  173. Help! Rearend knocking and whining. Must drive 800 miles...
  174. Poll: What would you do??
  175. Momo shift knob/short shift?
  176. Which launches harder..camaro w/ 9 inch w/ slicks, or awd EVO
  177. Slip after change to Royal Purple .
  178. problems engaging reverse in my t56 with mecloed street twin
  179. Ways to know your trans is slipping?
  180. Clutch for bolt on car < $500
  181. Answer this correctly and I will pay you!!!!!
  182. Magnet in 4L60E?
  183. Question About Torque Converters
  184. a4 question
  185. loose flywheel?
  186. shift light 4 automatic?
  187. Question about A4 to M6 Swap
  188. Alright - Tranny Coolers, Shift-kits?
  189. Which fill hole should I use?
  190. 4L60E question
  191. Any Yank SS3200 users out there?
  192. Is the slave cylinder outside the tranny?
  193. Noisy Spec stage 3
  194. Strange Dana 60 for '82-02 F-bodies...
  195. Help with 94' 4L60E failure, I think?
  196. Would this tranny cooler be worth getting?
  197. Upgrading the slave master cyl?????
  198. Converting To Manuel
  199. How to tell 3.23's apart from 3.42's by looking?
  200. Converting To Manuel
  201. Race Clutch Comparison
  202. ZF 6 speed in a Camaro?
  203. 4L60E Transmision in Ebay
  204. Upgrading the clutch --
  205. LS1 tranny mount to replace LT1 mount?
  206. Need Part number for 3150 U Joint
  207. Abs sensor on my 12 bolts(Strange)
  208. stalls and gearing
  209. Stock Posi and 4.30 gears
  210. Diff magnet adhesive? Need it?
  211. Anyone restall their stock converter?
  212. What is this diff part?
  213. Torque Converter
  214. tranny won't fit all the way
  215. People with stall converters(3000+)
  216. Vendors for complete bolt-up 12 bolt rear ends.
  217. break stock 3.42s with 315 nittos?
  218. Moser 12 bolt.....or 9"
  219. alum. or stick w/stock DS after engine install?
  220. Well my SPEC4 lasted 2 years and 50,000 miles......
  221. Transmission wont shift into second when I floor it
  222. Spec Stage 2
  223. Transmission slipping, have an idea
  224. My setup th350 or th400
  225. 4.10 in an auto
  226. Abs Inop
  227. transmission/converter question !!!
  228. Changing Rearend.. and Removing Rearend Need tips Fast!
  229. Going to get a shift kit
  230. v6 drive shaft fit a v8?
  231. Transmission woes.....
  232. 3.73's or 3.90's ?
  233. no tranny data
  234. Just bought Moser 12 bolt have some questions...
  235. TH 400 wont shift to third on the jug!
  236. ok stall questions
  237. 4l60e Only Works in D or 3
  238. how to tell a stall apart??
  239. What is stock trans type?
  240. Just installed motive 4.10s
  241. just got my moser 12 bolt in ! its assembled but should it be checked ?
  242. transgo breaking splines/spider gears?
  243. Need some help with a noisy T56
  244. 3.73 or 4.10's
  245. possible converter issues, please read
  246. rebuild my own transmission.
  247. Tranny swap
  248. Shifter Button Won't Go Down
  249. Blown LT1.. Go with a Used M6 or A4 or LS1
  250. No Bleeder on LT1 T56?
