View Full Version : Drivetrain
- Dana 60 Pictures and questions.
- What are the pros and cons of a 12 bolt vs. a 9 inch
- Very quick T56 swap question *Swapping it right now*
- Vibrating at 70 and 90 after gear install?! ---
- Help ASAP!!!!
- Cant find Tranny mount for LT1 Camaro!!! ---
- 700r4 problems
- Automatic Flex Plates????
- conversion fittings for braided trans lines
- how to calibrate speedo in 93 m6
- Advice On Getting 4.10's In An M6
- Currie 9" and ABS questions.
- tranny problems
- 2800 stall and stock rear/gears?
- 4l60e Problems
- 2800 stall and stock rear/gears???
- Gear brands for a 12 bolt 4.1X's
- help picking a torque converter
- univeral joints
- 4L65E Front Support and Output shaft
- Have a problem
- Quick gear question...
- Can i replace just the Slave for the Clutch?
- Forgot To Torque Down Pinion Nut!!
- 4l60e about to go?
- opinions on what tranny to choose
- Helloooo everyone!
- How much HP can a muncie M22 handle?
- transmission smoked?
- swapping out a tranny,need insight
- does anyone have the mcleod twin disc ?
- Tranny shifts weird / abs light
- Soft McLeod... Normal?
- Pilot bushing lube?
- Stall vs. Gears
- car hard to get in gear(m6)
- RAM Clutches.
- S60 hope I get lucky?
- How do I press on the axle bearings?
- vette servo
- New torque converter sounds like a bucket of rocks and car don't move
- couple of problems
- will a 96 b-body 4l60e fit in my 94 f-body?
- tranny swap
- Wheel stud safety problem..?
- Transmission won't shift 2-3!!!
- s60 issues??
- pcm changes,auto to standard,any help?
- clutch slipping?
- 10 Bolt ?
- Transmission Question
- TV Cable didn't work. What about the valve???
- Help! rear end carrier Problem Help!
- Where do you find gear paint to check gear pattern?
- help with drill mod
- question for yank owners???
- 4L60 "squeal" and another ques.
- Synthetic Gear Oil and GM Additive
- Pics: Differential
- Clutch Pedal Question
- Help identify my muncie M22's origin
- Slave cylinder?
- Best Option on Rear ends for a 96?
- Torque converter not locking up and speedometer not working
- And the grinding noise of the week is ...
- Clutch time...
- Overdrive Question
- budget build help
- WHY does this thing keep killing Rear Ends?
- no reverse
- Swapping a 12-bolt from a suburban into my 4th gen?
- Rearend, what am I forgetting?
- A4 4.56 1/4 mile trap RPM?
- Which Clutch Kit???
- Shaking
- Mcleod ST flywheel balancer weight
- 4 channel rear in 3 channel car
- ? LS1 Rearend in LT1
- drag radials
- Roadracing / AutoX Read end options and ABS related questions ..........AUTOCROSSERS!
- Strange gears- ring busted, pinion fine... factory defect?
- Mcleod ST: Aluminum vs steel vs stock???'s
- Synthetic oil for tranny?
- my rear is shot so what gears should i get
- Removing center section of Ford 9"
- How do you remove the ring gear?
- Should I get an alum DS for $50?
- gear selection question
- 1993 M6 trans
- converting from auto to 6 speed Do i have to get my 355 rebalanced
- dana 44?
- which gear ratio 3:73 or 4:10
- Do the wheels have to be off to get the c-clips out?
- Does gears cause stress on trans?
- Rear end clicks on right side when moving in reverse?!---
- rebuild a4 or go with t56
- T56 Reverse...sucks.
- 1996 4l60e problems no 4th gear
- rebuilding transmission
- custome driveshaft
- ST & truetrac review
- Driveshaft length
- new auto tranny break-in
- clutch problems??
- clutch advice
- How to tell if rear end bearings are going bad?
- clutch problems
- currie 9" interchangability lt1 to ls1?
- Viper T56 Conversion
- PN on Reverse Lock Out 'Noid
- What gears in my rearend?
- trouble shifting when cold
- ST and stock rear?
- A4 to M6 Conversion Help!
- Pros & Con's to straight-cut gearing?
- Need a diagnosis.
- 1LE Drive Shaft???
- Torsen rear end oil
- Any 9" rearends that are ready for bolt in???
- synthetic vs. non-synthetic oil for manual trans
- LT1 axle...LS1 axle spline count queston.
- 3rd and 4th gear out?
- Can I swap a 8.5 into my 4th gen?
- Carrier Series
- Clutch locks up when sits for awhile
- Need advice 373s in 96' Z28
- 4L80E questions
- What year and car th400 etc
- RIP 10bolt
- rear end noise
- Tranny Swap Question
- B&m Ripper Vs. Pro 5.0
- Trans, HP, and gears
- Cahall Performance Transmissions
- who makes the strongest th400
- Best Auto To go with High HP
- Important Clutch Question! Please Help Fast!
- gear in the trans am
- Auto Trans problem
- t56 removal question to replace clutch
- T56rebuilds.com
- GM LS Diff fluid w/ Royal Purple??
- how can you run a '97 4L60-E in a '95?
- pulling tranny (a4)
- Transmission or Tune Problem
- 12 Bolt....or 9"
- Nasty whining after gear swap
- t56 install
- 4L60E...maybe...maybe not
- Crazy Sound NEED HELP PLEASE
- Installing Built T56 by my SELF? Ideas?
- Good tranny?
- Hitting Rev Limiter
- Transfluid, can I use this?
- Replacing transmission mount?
- flywheel/PP alignment
- 95 trans am ,worn shift cable???? automatic
- 1992 Z28 700r4 swap to 350 turbo
- Possably a broken input shaft?
- Diff between 4L60e ODB1 and ODB2.
- Shifting into first on an auto
- T56 to pre 68 smallblock
- 3:73 or 4:10 Rear gears: Lets Debate
- Basic Rear Diff Question ABS
- Pics of bleeding clutch master cyclinder in LS1
- LT1 to LS1 T-56 Conversion.
- What clutch?
- Contaminated clutch???
- 5th gear
- 98 SS differential
- output speed loss
- Can changing rear end oil reduce whining noise
- can i still use this disc?
- New Motive gears noisy after first hard run
- Spec 3 on drag radials?
- Are m6 pedals the same for all years 93-02??
- Another McLeod disengaugment issue. CL SL Bleeding Q,
- Simple T-56 Question... (On going problem)
- Your thoughts on this
- Clutch master and slave cylinder question
- Correct Gear/Slick Combination?
- Paging FRANK
- Changing my posi unit, reshim gears?
- Mcleod Clutch single disk too thick?
- Best/cheapest way to do a 12 bolt
- needle bearing pilot bushing
- Just put my order in and...
- Rearend question
- m6 flywheel width? Any know the spec?
- 400 turbo
- what differential and axles to get?
- V6 converter in a Lt1???
- New hydraulics didn't brake plastic strap on slave????
- m6/t56 guys that lauched the 10 bolt on slicks 4500+
- Clutch recommendation
- neutral + clutch in = stall
- Car T/C in a truck???
- Cannot decide my gear ratio...help!!
- 1995 Z28 Gears Shifter
- Gear light?
- summit gears, good or bad?
- 6 speed swap
- Whats the difference???
- Flexible transmission filler tube
- Reverse... ****in t56's haha
- Quick curious question
- Clutch problems
- Can someone help me understand ABS and Gear swap
- Whine from short shifter install?
- Good clutch kit for bolton + 75hp spray
- inspecting my clutch
- moser 12 bolt LS1 to lt1 car
- Shift Kit Questions?
- M6 or auto for 700 rwhp drag car
- Question stock driveshaft issues....vibration related
- HELP ME DECIDE (rear end)
- what parameters cause TCC lockup?
- TRANNY GOODBYE?..or clutch?
- Speedo/Milage change from 2.73->3.73
- What brand of th-400?
- Is this normal from the factory on a T56?
- Best Clutch for 700+ HP
- Rear end and clutch pedal "click"
- Debugging a clutch problem...
- Strange Dana s60 owners inside.
- What rear end do you suggest to take 600 hp?
- New TC-How long does it take....
- new gear... speeds?
- major problem, tranny done-for... questions about how to keep my converter?
- gauge swap?
- Gears and speedometer calibration
- is shifting bad on a 4l60e?
- What is the best tranny option for me to go worth to support 750-850rwhp?
- Transmission rattle ('02 6sp)
- 4L60E woes...
- chatter and clunking noise
- A full spool 4 the GM 7.5????
- Clutch leaks fluid inside car onto foot. How to fix?
- Help...clutch problems
- stock torque converter
- stay away from Spec!
- Moser 9"
- squeal from transmission (A4)
- factory/stock torque converter
- 3k stall = ridiculous for a daily driver ??
- mcleod single disc
- What's the Stock U-Joint Size for 4th Gens?
- help me choose a clutch setup
- How strong is a 9 bolt??
- 4L60e Transmission swap guide
