PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. how streetable would this be
  2. Ford 8.8, anyone ever tried one in a LT1
  3. Finish Line Performance A4 opinions
  4. question on 4L60E problems
  5. Manual/Automatic
  6. A4 Harness, diff b/w 95 & 96??
  7. 3.42s For a 2 series carrier
  8. rebuilding 4l60e?
  9. thinking of buying a used tranny
  10. how much abuse can rearend take?
  11. M6 Problems
  12. torque spec for clutch job
  13. axle advise please
  14. gears
  15. Clutch install
  16. gears for 6 speed?
  17. bleeding clutch
  18. removing trans.
  19. TCI Trans or CPT/Probuilt Trans???
  20. New vibration...
  21. putting in a stroker next year and have a couple questions
  22. Drivetrain Upgrade Question
  23. Moser 12 bolt installed..problem
  24. Tell if i have a shift kit?
  25. 10 bolt To 12 bolt question
  26. problem with drivers side rear axel on the 95 z28
  27. posi failing?
  28. Street twin Tranny install
  29. need help now please!!!!!
  30. strength of stock axle?
  31. Your opinion IF YOU HAVE RAN AN 8.8"?
  32. More Traction??
  33. Tough decision to make. What would you do? (kinda long but please read)
  34. How hard is it to install a new clutch
  35. trannys finnally gone, should i rebuild or buy another unit?
  36. Resurfacing flywheel and PP
  37. slipping tranny or what?
  38. Built Trans?
  39. McLeod Street Twin
  40. Is a TCI Saturday Night Special Torque Converter a good mod for mostly stock LS1?
  41. P1870 – hardshift and missing lock up when temp is "normal"
  42. Converter bolts. What size??
  43. Need help for another car. Tranny noises.
  44. No upshift
  45. U-Joints and driveshaft balancing
  46. M6 T56 6 Speed Transmission Leak.
  47. Decel fuel cutoff with vacuum modulated trans?
  48. what clutch to get???
  49. Troubles getting into 6th
  50. Unique T56 noise.....help me figure it out!!!
  51. M6 to A4 conversion (searched)
  52. If you break your gears.....?
  53. Damn transmission bolt problems!!
  54. shift damnit
  55. '97 4L60E in a '96?
  56. Gears or save for a Rear?
  57. Bad transmission???
  58. Reeaally need your help with T-56
  59. LT1 clutch disk upgrade....
  60. 4L60E Rebuild 'Kit' -- Need Opinions
  61. Does the stock rear have c-clips?
  62. what size are the converter cover bolts on a turbo 350 transmission
  63. Acc. problems when trying to pass
  64. Changed my gears to 3.73 what should the RPMs be?
  65. Mysterious Trans Leak
  66. Centerforce Clutch
  67. Those with a SPEC flywheel....
  68. Doesnt want to go into reverse all of a sudden (T56)
  69. 700 r4
  70. Hurst shift knob part #
  71. Which gears do I have?
  72. Anybody know how to Install sealing Rings in4l60e
  73. 1998 z28 help
  74. Best converter?
  75. has anyone used 4:30's? 4:30's or 4:10's??
  76. Is my flywheel too much?
  77. My "new" Spec 3 slipping behind a stock LS1.
  78. T-5 Tranny Dilema.......
  79. M6 conversion wiring problems!!! PLEASE HELP!!!
  80. '02 SS A4 having issues
  81. Clutch selection help
  82. zoom clutches
  83. please vote! POLL, what gear?
  84. KTRE/Moser 12 bolt wheel bearings
  85. Maddog clutch
  86. Small Tranny Problems maybe????
  87. What fitting for fluid cooler in TH400?
  88. Should I get a 12-bolt or Ford 9"?
  89. Cost of a rebuilt or 4L06 non electronic
  90. Easier on trans: WOT shifts vs. part throttle
  91. Bolt's on trans
  92. Need info on this tranny, shoebox or injuneer?
  93. This Posi Any Good?
  94. difference b/t 4l60e's
  95. 3600stall too much?
  96. B&M Ripper vs. Pro 5.0 vs. Hurst
  97. How much less for rebuilt tranny if i supply kit?
  98. ABS crap
  99. Couple of gear questions
  100. Diff cover
  101. How many bellhousing bolts for A4 LS1??
  102. will a tranny from a 94 work in my 97?
  103. What stall with 3.23?
  104. Strange 12 bolt w/ 3.90:1 gears??
  105. Did a one wheel peel then rear is warped, i think....need help!
  106. 4L60E and heat
  107. gears?
  108. HELP! What is this darn Noise!
  109. Gear noise and Series 2 carrier
  110. 95 V6 rearend to 98SS rearend
  111. speedo gear cheat
  112. v6 and v8 crossmember the same?
  113. Fast Street Cars! th350/400 Question
  114. What would I need to replace gears myself?
  115. 4L60E shift kit question
  116. 4L60E Woes
  117. help with trans fluid leak @ shift lever please.
  118. Used gears?
  119. anyone gone from 3.23 to 3.42?
  120. small leak from rear end
  121. Edge Torque Converters
  122. Who has had a pressure plate come loose?
  123. Transmission problems
  124. t-56 vs. th350
  125. Transmission/clutch problems, Need opinions, help
  126. Stupid Question(regaurding 9inch)
  127. TWM Shift Knobs Student Discounts!
  128. 2nd Gear Scratch
  129. Transmission
  130. Tranny Fluid and Tranny Question
  131. Spec + Series Clutches
  132. HELP Tranny Wont Shift At WOT
  133. Gears..average install price?
  134. Question about Posi's
  135. 2 piece driveshaft
  136. 4l60e vs. th350 vs. t56 swap.
  137. pressure plate problem?
  138. Disable traction control
  139. 4l60e in 1993
  140. shameful loss help questions to follow
  141. TH350 conversion people inside please
  142. ZZ4 Centerforce clutch
  143. My auto blew up because...
  144. Tranny problem....anyone experience this?
  145. big question
  146. Are Eaton GovLocks Any Good?
  147. Pro gears for 12 bolt????
  148. Auto to manual swap
  149. B&M Auto Rachet Shifter Conversion Kit for LS1 Auto trans cars
  150. Installing new gears.
  151. Traction control?
  152. 700r4 shift kit Q (cable going to TB)
  153. purchacing a moser 12 bolt
  154. ? About LS1 transmission mount
  155. Soo... The time has come for th end of my 10 Bolt
  156. posi-trac or limited slip
  157. Clutch Installation
  158. 3:23 to 3:73???
  159. Someone explane to me how a Stall converter works.Thanks.
  160. HELP! Car vibrates and makes a thumping noise around tranny.
  161. Can I do this on my T-56?
  162. Can I do this on my LT1?
  163. 700R4 Squeal
  164. Spec 2 instead of 3?
  165. PN for tranny mount nut?
  166. stock 10 bolt hold up?????
  167. Tranny compatability
  168. 79 Ta Rear End Strenght?
  169. What exactly do i need to upgrade my gears?
  170. pro shifted doug nash five speed strength?
  171. Problem with auto. transmission - hard shift when engine temp reach "normal"
  172. Strange rear and stuff
  173. Will all GM 10 bolt 8.5 gears work in my car?
  174. I need opinions on the SLP pressure plate with the mcleod disk
  175. Anyone else disappointed with Richmond????
  176. Torque Converter Question
  177. McLoud Clutch
  178. More 4l60e shifting problems
  179. i need a built tranny
  180. What happened to my tranny??
  181. Reluctor Ring question
  182. Torque Converter
  183. anyone know??
  184. 4L60 vs 4L60E
  185. is this a problem
  186. How much HP can a stock A4 handle?
  187. Help!
  188. Help me diagnose my T56
  189. Lou's Short Stick?
  190. Spec Stage 4 +Prothane Polyurethane tranny mount =Strange noises from tranny?? HELP!!
  191. Ford 9" question
  192. 97 4l60e
  193. m6+150-shot+slicks+bolt-ons WHAT GEARS SHOULD I RUN???
  194. Odd 4l60e problem
  195. where to buy?
  196. Thumbs up for CPT
  197. clutch assembly: good or no good???
  198. Shifter for '02 Auto Trans and Shift Kit -need advice
  199. T56 Intermittent whine
  200. 4:10's first gear mph???
  201. Zexel or Auburn?
  202. Well, it looks like my SLP clutch is toast...
  203. 4 channel 12 bolt in a 3 channel car. I have ABS light on, AND Brake light. Normal?
  204. Need Rear!!!
  205. stupid tranny question
  206. Anyone used a Derale Transmission Pan?
  207. Is this normal
  208. What driveshaft to get? (Strange 12-bolt)
  209. Need answer ASAP!!! Torque converter bolts!
  210. If my Tranny Is Currently Sick....
  211. Clutch Fork is toast.... (with pics)
  212. Explain: Torque Converter Slip vs. Gears/MPH
  213. Stock Rear End Gears?
  214. What makes our rear ends weak?
  215. LS1 DS yoke on LT1?
  216. B&M Tranny Cooler 94Z
  217. B&M Tranny Cooler 94Z
  218. Limited slip isn't working well
  219. whats the transmission options on 93-97 f-bodies??
  220. Tranny shakes at 39-45mph....
  221. 1994 Z28 Speedometer change to match new gears
  222. Help what would you do?
  223. installing a shift kit
  224. Rebuild/Torque Converter
  225. Very Odd T56 Problem -HELP-
  226. U-joint's
  227. TH350 vs. TH400 vs. 700R4
  228. Pinion seal ALWAYS leaks!
  229. How often do you change your tranny and rear end fluids?
  230. lock up solenoid
  231. **** pilot bearing
  232. Fluid leaking from the slave were it attaches to the Transmission...
  233. LT1 Flexplate - TH350....Need a Torque Converter HELP!
  234. LT1 - McLeod Street Twin - no reverse after bleeding?!
  235. clutch wont disengauge
  236. McLeod ST overkill?
  237. Urgent - What/Do I need a 12 bolt?
  238. how strong is t-56 guts?
  239. Does anyone think about a clutch explosion?
  240. Victory Racing Yank Converter GP
  241. Maddog clutch
  242. replacing input shaft
  243. TQ converter and gear effect
  244. LT1/LT4 clutch recommendation
  245. Advice for tranny install?
  246. 1995 4th Gen F-Body question...
  247. Stall Converter?
  248. quick question about gears
  249. Transmission year?
  250. Poly trany mount vibration???
