View Full Version : Drivetrain
- Is a turbo 350 Short Shaft Lighter Than a 4L60E?
- A t56 for $50.00
- Changing tranny fluid?
- I dont get it
- 4L60E question
- 4L60E Pump
- Driveline viberation and part #'s
- I've searched. Need LT1 clutch options for someone who can't spend alot.
- T56 rebuild question
- rear end rebuild questions.
- Strange Vibrations- Tranny mount?
- which is better overall
- question about 94 differential cover
- What is this?
- Q about 98 z28 rear end
- Clutch keeps popping out of 1st and hard to put in reverse!
- Auto Transmission Problem(s)
- Not Using the Trans Cooler In the Radiator?
- Changing Flywheel with Clutch
- Clutch Install
- rear end dilema
- "Normal" noise?
- I think I broke something.
- A4 Problem
- Rear End FAQ
- What gear is it?
- rear end HELP!!!
- Help Plz
- B/M Transpack How Hard are shifts
- Recommended Clutch?? '96 z-28
- Driveshaft balanced. Wow, what a difference!
- Speedometer calibration w/ new gears
- What is my transmission? '96 Z28
- rear end knocking, getting worse
- 4L60E interchange
- Vibration from pilot bearing??
- REbuild time, what can/should I do?
- Odd Grinding Sound, Clutch?
- 4l60e rebuild question
- Jiffy-tite quick connect
- trans seems to shift hard...could it be the rear end?
- Auto tranny pan aftermarket q.
- Rediculous bolt on T56 bellhousing!!
- Which SLP shift knob?
- 700R4 shifting RPM W/new crate 350TPI
- difference between 91 and 96 rear diff?
- Hurst or B&M Shifters A4?
- Q about M-6 to A4 wire harness conversion.
- LCA/bracket question
- diameter of converters
- how many teeth on a 95 LT1 flexplate?
- Where can I find some better than stock quality axles for my 96 TA?
- now i know this has been asked 1000 times...
- LT1 vs LSx Rear
- Shift kit for a4 z28
- What's the best way to clean the tranny? Photos.
- Gear noise question...
- Maddog Clutch
- 12 bolt problem-ring and pinion maybe?
- No criuse after T56 conversion, do something wrong?
- CPT Trans owners inside please.
- 94 Z-28 can't separate tranny from bell!
- Lost 3rd and 4th gear in my 99 Z/28 auto!!!
- Spec Stage 2 or 3
- SPEC OWNERS - HOW long did it take for you to.
- Quick 6-speed conversion question
- 95 T56 going into a 97
- 93 T56
- Moser 12 Bolt install problem.
- Driveshafts
- rear end?
- Strange S60 rear-end
- how to remove trans????
- 3.73 or 4.10 w/ the giggle gas
- What fluid to use in my M6/10 bolt
- Shift Kits
- Street Twin chattering.
- tranny noise
- upgrading t-56 with viper internals
- new help quick th400 conversation.
- trans
- 10 bolt on done status
- TIme ran out on my 10 bolt but I have one question
- Going TH-350
- Can a bad driveshaft effect 1/4 time?
- Softning the LT1 Clutch pedal, has it been done?
- Torque Multiplication Question
- what would cause an extremly hard shift??
- 67 Camaro Clutch Clunk engaging in 1st
- Noise while lightly on Throttle
- Anyone with the Dakota Digital SGI-5 inside...
- do I need traction control??
- Clutch Kit
- trans problem
- Quick Q... Relcutor ring removal..
- tranny installed now car runs like crap...
- Help! Hole in transmission housing!
- hmm, 4L60E or TH400???
- Posi going? or is it.....
- th350 or 400 swap
- T56 VSS sensor output with Dakota SGI-5
- I can't drive around 15-25mph !
- No No, seriously, tinking AND clunking noise
- any idea why different transmition cost
- 96' A4 2.73's - Won't downshift at WOT
- Autozone clutch/PP setup?
- Possible damage to 10 bolt - Pics Within
- 4.11s too much for a 700R4?
- transmission question
- need an LT1 T56 Flywheel
- weird metal on metal grinding noise
- borg warner t-56
- reverse lockout solenoid removal
- How far up does you LT1 clutch pedal engage?
- 12 bolt Moser with BMR relacaiton brackets.
- broke 10 bolt
- vigilantes and nitrous
- need advice
- Few questions about T56
- f1 racing clutch
- loud whining noise coming from rearend
- Leaking Trans cooler
- 12 Bolt Sale @ VRE
- Posi????? limited slip?????
- 700R4, Lock-up or non locking.
- T56 swap into 3rd gen
- Different gears?
- Broken TA mount for moser 9". where to get replacement?
- SS tranny lines
- Shifter
- need advice, san diego auto tranny rebuild, install warranty LS1/4l60e
- '95 rear end swap questions
- What gear do I have?
- just lost overdrive in my automatic v-6
- cant get the car to shift please help
- Just bought SS - Want Short Shifter? any ideas??
- Droping the 4l60E
- transmission mount/ differences
- trans-trouble
- Anyone who is using Mcleod Single disc...
- something broke in tranny last night need help..
- replacing slave cylinder
- 4L60E/TH400 info
- weak link on the 10-bolt
- just installed Ram Powergrip, feels like stock. help please
- 3.73 & 4.10 rear end gearing questions
- Can't shift into any gears after new clutch/trans install
- what other cars rears will fit
- Grinding in 1st when rolling
- Noise from T56 after clutch swap
- Gear swap cost
- Seal between Shifter and Trans?
- Camaro to Firebird Tranny Swap?
- soft grinding
- Spec Clutches, are they any good?
- 4L60E Help - Technical Clarification/Explanation
- How many quarts for t56 if filled throught shifter?
- Do different tranmissions have different engine wiring harnesses?
- strange shifting problem
- Weird problem with 6 speed
- I <3 The search function. Now... help me upgrade please
- Can u overide the Trans Perform Button so it's always on?
- 10 bolt check... hows everyones rear holding up?
- Rear end Gears...
- T5 weaknesses?
- Spun my center section on friday
- Do corvette shift knobs fit on an f-body ?
- Synthetic Mobil 1 75W90 Oil for Detroit Locker?
- T-56 to 4L60E conversion q's
- tranny wont stay in park
- Stock 94 4L60E hits revlimiter in 1st at wot
- will a stock steel ds fit a moser 9in?
- ?new rearend?
- LS1 A4 -Could this be "Torsional Rattle?"- strange drivetrain noise.
- Anyone running a 25-2600 stall with this size cam?
- S-10 tc
- Steel O Ring over pickup tube for trans filter.
- rear end leak- get new gasket or load it with sealant?
- Help!! 9" w/ Detroit Locker bad problems.
- 10 bolt wieght
- 82' iroc trans swap help needed
- pinion seal leaking ...anyone else?
- Question about th400
- Borg/Warner T-5 reverse
- 4L60E No shift at all???!!
- Knocking sound
- 1st to 2nd has sloppy shift
- Stock Rear End???
- 94 z28 diff. pinion seal leak
- Mounting question for T56
- Recommended U-Joint Brand/Vendor?
- Anyone ever had this problem
- B&M transpack shift kit questions
- Is this the correct tranny mount?
- Locking up an automatic trans
- auto to 6-speed pedal conversion time question
- Moser 9" Leak
- TH 350 Question
- 4:10 posi rearend
- rear end help??????
- odd grinding in 1st gear (m6)
- transmission mount torque question
- Viper Output shaft
- rear end
- Transmission speedo differences
- 1LE Driveshaft to 12 bolt
- cheap clutch replacement
- doing burnout...
- Tranny Swap
- LS1 A4 "Planetary gear noise" Ideas/suggestions?
- Source for thicker c-clips
- School me on Posi rear ends...
- TH400 conversions.....
- gains from alum. driveshaft?
- t5 and t56 length and output spline comparison
- Gear Ratio & Posi Unit Recommendations
- is this bad??
- Transmission question. (short question, long thread)
- rear end replacements
- Will a 96 t-56 fit an ls1?
- whos got vigilantes the cheapest?
- Autozone Flywheels?
- Problems with moser 9" and a lowered camaro.
- Just got the 9 inch moser without ABS, am I going to have to.......
- Torque converter problem
- which relocation brackets work with 10 and strange 12 bolts?
- T-5 swap to mid 70s T/A
- Shift
- help clunking noise
- How strong is my rear end?
- Solid Motor Tranny Mounts?
- mixing and matching parts?
- Another M6 - A4 Swap, harness ?'s
- HELP ASAP....remove u joint
- What DOT brake fluid for my street twin??
- Adjust tv cable question
- So I am assuming this 10-bolt is bad? (vid, rear out of car)
- Diesel 4l80e bolt up to a lt1?
- stock tranny in 1998 z28 A4 is called??
- 1998-2002 driveshaft question
- Moser Drive shaft+Moser 9" experts help please
- Servicing Trans And Rear end
- Stock Flywheel Vs. Aftermarket?
- Pedal and Shifter Vibration. 3.8L
- Transmission Fluid Bubbly?
- Noise from the Rearend
- pinion seal eliminate vibes?
- gear install in middle georgia
- Help with vibration (already searched)
