PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. will LS6 clutch suit LT1?
  2. Anybody had this??
  3. Mcleod ST Flywheel still out of balance after removing weight
  4. Viper T-56 Mainshaft for Sale
  5. Just got a pro 5.0 shifter
  6. Oil on the clutch
  7. Next step: Gears?
  8. Vibrations
  9. Cheapest/strongest replacement for the stock rear end and where to get them ?
  10. some questions about the T56 conversion
  11. Gears
  12. help with flywheel part number
  13. anyone ever snap a clutch fork in half?
  14. 93 auto doesnt like to downshift
  15. 4.10's installed Friday / Spec 2 installed Saturday
  16. is my 4l60e toast?
  17. Rossler 210, PG, or a Liberty 5-speed????
  18. Low tranny fluid maek it seem broke
  19. Clutch master cylinder
  20. my old tranny mount(pics)
  21. Odd noise from M6..rattling
  22. need help with trans
  23. Str
  24. What are the factory gear options?
  25. Help! what size stall do I need????
  26. Need a little advice...
  27. Mcloed Twin Clutch
  28. question about stall
  29. your thoughts on this clutch...
  30. Tranny is done
  31. Game plan 6cylinder rebuilder?
  32. 94 trans work in 95/96 vehicle?
  33. Torque converter stall question
  34. superior/fairbanks billet servos
  35. 4l60e trans line orientation
  36. Ford 9 inch off of ebay? any good?
  37. stahl help
  38. 4L60E? problems...
  39. 4l60e help
  40. Does anyone have a gear install guide?
  41. speedo is off how do i fix
  42. Aluminum Driveshaft?
  43. pics of my clutch
  44. Auto Trans Shift Point
  45. Torque Converter Reccomendation
  46. Pro 5.0 vs. factory Hurst
  47. External Tranny Cooler
  48. same tranny problem,getting worse
  49. bye bye 10bolt...
  50. automatic vs 6speed
  51. Th400 Swap Worth Doing Over 4l60e
  52. what's the best clutch for me???
  53. New clutch disc install questions
  54. Spec clutch problem. grinds when I push the pedal in
  55. Mechanical Speedo Tranny in 97 Camaro
  56. Wheel hop, do I have it??? (repost)
  57. Posi ??
  58. 02 rear gears
  59. how to tell what gear is car by code in dash
  60. 10 bolt vs. 12 bolt
  61. ram powergrip HD guys?
  62. T-56 Tranny help Please
  63. t56 leaking
  64. which torque arm bushing?
  65. What is this????
  66. Manual shifter
  67. 4L60(Not E) shifts at 4000rpm at WOT...
  68. Stock Flywheel Vibration?
  69. Scatter Shield
  70. Help! New Clutch Installation, what am I missing?
  71. 90 mph vibration
  72. Options to Replace the 2.73 on 1997 Z28
  73. Stupid slave cylinder???
  74. Just got my B&M shift kit
  75. What would be better?
  76. GM 700R4 Shift Kit questions
  77. anyone use one of these?
  78. 3.23->3.73
  79. energy suspension tranny mount
  80. TransGo shift kit settings?
  81. M6 Inspection cover?????
  82. M6 Stuck in 4th
  83. Street Twin master cylinder question
  84. Slave cylinder and pilot bearing part #
  85. shake rattle and roll
  86. Cracked flexplate?
  87. At what point will the SPEC stage 3 go?
  88. How much would gears help me?
  89. a few tranny questions
  90. Auto shifter first gear
  91. 01 SS, need a new rearend. Where to buy? prices?
  92. shifter linkage cable?
  93. 4L60E shifter linkage cable
  94. 4l60e having trouble downshifting under light acceleration.
  95. LS1 T56 in an '86 Iroc Z
  96. flywheel breakin??
  97. Trying to understand rim backspacing and offset
  98. where to get reverse manual valve body....best deal
  99. 3.73 question
  100. Driveshaft removal
  101. Help with rear seal on LT1 T56
  102. driveshaft safety loop??
  103. F & Y body tranny differences (T56)
  104. Rear end questions
  105. ok answer please...tired of searching...
  106. shifter help
  107. neutral safety switch
  108. Trans go shift kit question
  109. Need some RPO help with 3rd gen rearend!
  110. transmission cooler help
  111. 9 inch Pros and Cons?
  112. Shifting into 5th w/275/40/17s & 4.10s..help
  113. T5 Install Questions
  114. New 383 engine balancing problem with street twin HELP!
  115. Bleeding Clutch System
  116. ^^Selecting A Shift Kit^^
  117. Stall converter help, suggestions
  118. Question
  119. A4 to M6 Swap & Car Won't Start
  120. Gear Whine
  121. looking for a strong tranny
  122. Is this a torque converter problem?
  123. Need Transmission Help
  124. Need Transmission Help
  125. What's the best tranny fluid for my six-speed
  126. Who is using the 12" Centerforce?
  127. Way to tell diffence between 700r and 4l60
  128. Mcleod Clutch
  129. LT4 or Spec
  130. ====REMOVAL OF 4L60E from a 96 Z ====
  131. 700r4 high rpm when shiftting into 3 gear
  132. Automatic Shifters/What are you useing... pics?
  133. Fastest/quickest M29(2.97) t56?
  134. LT1/LS1 T56 Differences?
  135. Stock flexplate + 6200rpms = kaboom
  136. replacing pro-5.0 shifter springs??
  137. Borg Warner 9 bolt gears???????????
  138. Does anyone know ?
  139. Transmission questions
  140. Thanks Scott (aka Driveline Solutions)
  141. Clutch help.. Spec or OEM??
  142. Anyone here have the Ram HDX Clutch (LT1)#88516HDX
  143. Pro 5.0-Not returning to center.
  144. had tranny work done, bad shifter feel...
  145. flywheel polished, break in??
  146. 2500HD Rear end
  147. weird shift
  148. Mercron V question
  149. New gears and fixing the speedo?
  150. 1994 4L60E into a 1996
  151. 4L60E to 700R4 in a 1994 Z28
  152. Torque arm mount and tranny sensor
  153. LT4 clutch
  154. Please help. Post A4 --> M6 questions. Not the usual!
  155. six speed problems
  156. OE Pilot bushing ( with grooves). Where to find
  157. 5 speed lt1????
  158. How to find out what year tranny is in the car
  159. how much for a tranny swap?
  160. T-56 Rebuild parts?
  161. Th400 swap question?
  162. how do i blead the clutch on my 96 LT1 t-56
  163. LS1 T56 swap into LT1 A4
  164. Diff. Question Backlash
  165. turbo 400 swap
  166. Who has NOT had problems w/ their Spec Clutch??
  167. Mcleod twin disk lt1 problems
  168. Who is #1 in Converters and Why? [Fuddle - Edge - Vigilante]
  169. Can i use 2 bolts instead of the u-bolt for my master cyc?
  170. Should I have had my flywheel balanced?
  171. 3:90 gear
  172. 4L60E removal questions
  173. Please help me!!! Can't unbolt bellhousing.
  174. Mcleod sux ***
  175. Transmission wiring
  176. Clutch question
  177. Firewall broken loose on my LS1????
  178. My rear end
  179. transmission woes return.. =/
  180. 10 bolt + stall = ?
  181. Where to buy pressure plate?
  182. Stock Flexplate
  183. Link to make a home-built adjustable master cylinder
  184. Please help. put in 373's. now pretty gd. vibration..
  185. Strange 12 Bolt and Wheel Studs
  186. ATI torque converter
  187. all or nothing with my SPEC stage 3 and SLP flywheel(it sucks)
  188. Replacing the wheel bearings?
  189. fluid for M6
  190. ratchet shifter??
  191. 3.73 Gears with Stock Rear End
  192. 3rd and 4th gen rear compatibility
  193. Trans Fluid Change
  194. 12 bolts and 3.23s...
  195. what in the heck-o would cause this crack?
  196. will a 94 4L60E work in my 96?
  197. Transmission Cooler Mounting
  198. posi
  199. clutch squeak
  200. clutch squeak
  201. clutch squeak
  202. Cost to Rebuild
  203. Heavy Clunking Noise - Mechanic in Torrance, CA?
  204. power steering oil cooler
  205. Anyone with a 9 inch and 3.90 Gears, your help please
  206. C-Clip Rear Ends
  207. Mcleod twin clutch set up question.
  208. 120K on stock clutch?
  209. t56 conversion plug?
  210. turbo 350 trans
  211. 93 A4 transmission question?
  212. diff btw auto and m6 gears?
  213. How long should stock rear end hold up w/ 100 shot?
  214. Ok time for a new clutch Stage 4 or McLeod?
  215. gear companies
  216. Which Transmission Fluid?
  217. Car wont shift.
  218. did the 4th gen ever come with 3.73 stock
  219. tranny problems
  220. gear install prices
  221. Automatic LS1 with 3.73's
  222. Post what tranny you have and your thoughts.
  223. I have to rebuild tranny - should I replace torque converter too?
  224. Synthetic...
  225. Rear main seal....
  226. Cost of Clutch
  227. Th-350 rebuild difficulty
  228. Where's that thread "700r4 question"?
  229. auto to manuel
  230. whine in 6th gear only
  231. 4th gen drive shaft in a 3rd gen?????????
  232. How much parasitic loss with M6.
  233. Reluctor built into posi?
  234. tailshaft housing clamp or bracket
  235. Everyone with M6 & 500+ RWHP, what rear gears are you running?
  236. Race built 4L60E, Where to buy?
  237. What tran do I have?
  238. pan bolts
  239. trans brake for 4L60E
  240. Check out this flywheel
  241. The Infamous drivetrain clunk
  242. Ganna attempt to rebiuld an A4 Tranny out of a 3.8, what am I getting into?
  243. Q about Vacuum Modulated 4L60E
  244. ---> A4 guys with 3.73s
  245. Face-Plated or Pro-Shifted T-56
  246. Re: Clutch Problem
  247. Does anyone still sell the 1LE driveshaft?
  248. Are 93-97 f-body flywheels interchangeable with LT1 C4 vette flywheels?
  249. Not F-body sorry. 727 no reverse after loud pop sound?
  250. Tranny Question>>>help!!!!
