a-4 to m-6 guys come inside
Old Feb 13, 2005 | 03:15 PM
chevelles101's Avatar
For those of you that did the switch, what did you do about balancing the flywheel? I have a used one with the conversion kit I bought off of a fellow board member, but don't know what to do about balancing since the LT-1 is an externally balanced engine, I beleive. The car is a 95 Z. any help is greatly appreciated. thanks, Nick
Old Feb 13, 2005 | 06:09 PM
Re: a-4 to m-6 guys come inside
anyone have anything on this?
Old Feb 13, 2005 | 06:24 PM
Janny's Avatar
If you have a stock flywheel, you need not worry about balancing it unless someone else has messed with it. They are all balanced from the factory and they are balanced in exactly the same way. Mass production/cheap you know.
Old Feb 13, 2005 | 10:13 PM
thanks thats all i needed
Old Feb 14, 2005 | 12:49 AM
GreenDemon's Avatar
I thought the LT1 was internally balanced? I thought the 400 was the only one that really needed that as far as production engines are concerned.
Old Feb 14, 2005 | 08:35 PM
Eff's Avatar
Eff
technically, I believe it is internally AND externally balanced.
Magenta_Hearts
Mar 25, 2015 10:24 AM
cmsmith
Mar 14, 2015 03:48 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
