stall Torque converter question
Old Feb 22, 2005 | 04:54 PM
RacingTiger04's Avatar
ok, my trans is comin out again this coming week so i figure i should go ahead and get the stall converter that i inevitably shrugged off when i had it rebuilt originally, so im cruious as to what would be a good stall for a daily driven very light bol on 94 Z28, only mods are true duals with bullet mufflers and a CAI from moroso, well the trans too but that doesnt change the power im puttin out anyway whats a good stall for this type of application? im thinkin around a low 1800-2100 would be good but how would it affect leaving a redlight and gas mileage?
Old Feb 22, 2005 | 05:48 PM
1jfuddle's Avatar
Re: stall Torque converter question
A 1800-2100 stall would likely be too low for optimal performance. I would suggest a stall around 2600-2800, which would give a much larger performance gain. If you do go under 2100, it can be done for a much lower price. Honestly, though, even saving the money, it would not be worth it.
Old Feb 22, 2005 | 06:25 PM
"White Knight"'s Avatar
You'd see no difference(at least that you'd feel) I think stock is 1800. You'll want the 2800. Tons of people driving 2800 daily drivers.....this will hurt gas milage slightly--you'd have to ask the guys running the 2800's for numbers though. Remember though, it will only hurt you if you do a lot of stop and go driving--if you are on the open freeway the converter will lock up and you will not lose any mpg.
Old Feb 23, 2005 | 01:39 AM
well see thats my problem, this use to be a really small town and stop and go was almost never, but now its rediculous. crawl to school at stop-5mph for about 10 mins each mornin, same thing on the way out. and my car has the OBD1 computer so dont i have to reprogram if i go 2800 or bigger? and i think the factory stall is around 1400.. cause my car turns the tires over if i hold it down past that... well it did before i got the fuzions anyway, havent tried since then but im sure it would. stalled would mean that with brake-torque applied it wouldnt move until the stalled rpm right? or am i confused on how these work... thanks for the suggestion though, ill just hold onto my money for now if a 2100 isnt a worthy difference
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
