Adding fluid to an m6
Old Feb 17, 2005 | 05:07 PM
karl81talt1's Avatar
I know it might be a dumb question but i was wondering if i could add tranny fluid through the shifter hole so i dont have to jack up my car and use a pump.
Old Feb 17, 2005 | 08:22 PM
Mizz96Z28's Avatar
Re: Adding fluid to an m6
I suppose you could but if you don't already have it apart it's not worth the effort plus if anything fell into the space below the shifter like gasket material or dirt, dumping fluid from the top will just flush it into the tranny. If you get a long enough length of hose you can just stick one end in the fill hole on the side of the tranny, fish the rest through the engine compartment and just have someone dump fluid in it and let gravity help you out. Just stay underneath the car so you know when its full and to keep the tube from popping out and making a mess.
Myles
Old Feb 17, 2005 | 10:08 PM
MustangEater82's Avatar
Yeah you can, I did it on a T5, I pulled the shifter out to swap to a ls1speed inc short stick and poured new fluid in their.
Old Feb 18, 2005 | 04:20 PM
Its real easy to get the shifter out in my car its just a boot not the whole console like a fourth gen. and i know you can do it on a t5 but wasnt sure about the t56.
Old Feb 18, 2005 | 08:01 PM
Bud M's Avatar
Yeah, but without taking out the fill plug how will you know when its full?
Old Feb 24, 2005 | 03:52 PM
just wanted to add about a half quart of fluid because when i filled from under the car only the front end was jacked up. so i dont think it is completly full and its just a tad hard to shift.
Old Feb 25, 2005 | 11:15 AM
CamaroBoy96Z28's Avatar
Definitely remove the fill plug to check the level. Dont assume, assumptions lead to mistakes. But filling throught the shifter hole is exactly what I and everyone I know does...its just easier. Shouldnt be hard to keep it clean around that area anyway.
Old Feb 25, 2005 | 05:06 PM
SVWHAT's Avatar
Why not just empty the whole thing and replace with new ATF fluid. Should be exactly 4 quarts.
Old Feb 25, 2005 | 05:27 PM
97FormulaWS-6's Avatar
Normally, I fill through the Shifter with the fill plug removed so when it begins to leak, I know it's full.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
