Stock Posi...
Old Feb 27, 2005 | 01:17 PM
ChrisUlrich's Avatar
Stock Posi...
96 WS6 6 Speed... posi is stock? Then how come only one freakin wheel spins!!
Old Feb 27, 2005 | 01:22 PM
JBird33's Avatar
Re: Stock Posi...
My '97 spins both, every single time...wish I had an answer for ya!
Old Feb 27, 2005 | 01:28 PM
ShawnMacAnanny's Avatar
Re: Stock Posi...
Mine spins one when making sharp right turns, then locks when straight. two when making left. Always two in forwards or reverse. It's not a posi, it's a limited slip. I don't know why yours only spins 1 though. Maybe yours is broken or something.
Old Feb 27, 2005 | 01:50 PM
Peytons'z's Avatar
Re: Stock Posi...
Sounds like your carrier is on it's way out. Mine was starting to do the same thing so I replaced it last week. Replaced it with a eaton posi and 3.73 gears and wow! what a difference.
Old Feb 27, 2005 | 02:24 PM
Re: Stock Posi...
Carrier? Whats that?
What kind of difference you feel... power off download because of the 3.73's? Or traction?
Old Feb 27, 2005 | 02:40 PM
Antz97ZNJ's Avatar
Re: Stock Posi...
my 97 did the same thing, most of the time it would only spin one wheel...never did get to check it out sold it
Old Feb 27, 2005 | 02:42 PM
wicked_95z's Avatar
Re: Stock Posi...
your posi is on its way out. mine is doing the same thing when I drag with slicks. I believe its the clutches in the posi not holding.
Old Feb 27, 2005 | 08:28 PM
Re: Stock Posi...
How hard/expensive is it to swap out an aftermarket posi?
Are they really that much better? What could be better... if they are all supposed to do the same thing.
Old Feb 27, 2005 | 08:37 PM
nonamez28's Avatar
Re: Stock Posi...
i would like to know the same thing
Old Feb 28, 2005 | 05:20 AM
wicked_95z's Avatar
Re: Stock Posi...
Well the hardest part about swapping posi units is setting up the ring and pinoin afterwards. And even then you just need right tools and time. I believe the Eaton Heavy Duty posi is the popular choice. Supposed to be a quality piece. I thinks its what Moser puts in their 12 bolts.
Old Feb 28, 2005 | 06:41 AM
Grimpala's Avatar
Re: Stock Posi...
I've got an Eaton with 400# springs in my Impala. Its held up numerous times to hard launches with my spec clutch and T-56 with 4.56 gears and a 4600# curb weight.
IMO take your gears to someone who has been setting up gears for a long while. I tried to set mine up when I put the 4.56's in and didn't get the preload right. I set the pinion depth fine, but the carrier was slapping back and forth. Ended up takign two evenings of my time, and still had to take it to a shop for a day and pay $200 labor.
Old Feb 28, 2005 | 09:14 AM
Peytons'z's Avatar
Re: Stock Posi...
Maybe this will help you a little,
http://www.chrismans.com/AskSpankyDiff.html
As for your question on what kind of difference do you feel, no more one wheel burnouts is the biggest difference. I was getting stuck in my gravel driveway because one wheel would get into some loose gravel and spin.
The main reason I went with the eaton posi though was because it is rebuildable. The auburn carriers that come in most of our cars are not. If you have yours replaced go ahead and replace everything in the rear such as wheel bearings, u-joints, seals and might as well get a new ring and pinon. Its not cheap though, expect to pay around 1k for parts and labor.
Old Mar 1, 2005 | 11:10 PM
y5e06's Avatar
Re: Stock Posi...
pre '99 posi's are POS! They wear out super fast. You can do [roughly] three levels of upgrade. You can go w/ the SLP takout zexel-torsen posi from '99+ cars, you can go with an aftermarket like an eaton or torsen T2, or you can go w/ the bad boy torsen T2R. If you're on a budget and mostly daily driver I'd go w/ the Zexal-Torsen takeout from SLP. Last I looked $100 plus shipping. Plan on another $100 for a 'delux' install kit including bearings, seals, etc. If you have to pay someone, then an additional $150-$300.
note: the clutch type posi's wear out. some can be rebuilt, some can't (stock auburn). the T2R, for example, is not a clutch type.
There are other opinions out there, these are mine.
Old Mar 2, 2005 | 12:52 AM
1racerdude's Avatar
Re: Stock Posi...
They call that peg legging.The clutches are probably gone in the posi. Get an Auburn or Eaton and put your ring gear on it. Keep the side shims seperated when you take it apart and put it back together. No need to reset up anything. It will be fine. Use your old carrier brgs if they are not worn out,have a shop press them off the old carrier and onto the new one.Or get new posi kit and have someone build it for you,like taking the carrier to the dealer and say fixit.
Old Mar 2, 2005 | 12:38 PM
99andMine's Avatar
Re: Stock Posi...
Also, keep in mind that if when changing your rear diff 80/90 be sure to add the GM Posi additive or you take the risk of making it peg legged!! Its like 5 bux from any GM dealer.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
