3.73 gears...
Old Feb 17, 2005 | 02:56 PM
DiabloGT's Avatar
3.73 gears...
is richmond a bad brand? is there any bad brand?
thanks
Old Feb 17, 2005 | 03:11 PM
94Zpower's Avatar
Re: 3.73 gears...
I have richmond 3.73s with problems at all and they a renouned gear so to answer your question... yes they are very good gear.
Old Feb 17, 2005 | 04:23 PM
Z28Nut's Avatar
Re: 3.73 gears...
My 1st set of Richmond 3.73s didn't last a year before snapping 4 teeth off the ring gear BUT I believe the cause was poor gear setup by the shop that did install and improper break-in (and a really hard hitting 1-2 A4 shift). Richmond says in instructions to drive 10mi then let rear cool for 30 min and to do this a couple of times to prevent new gears from overheating. I didn't know this and the shop said nothing about it so I drove it 60mi home at 70-80mph The second time around I knew this and had a different competent shop do the install. Gears are much quieter this time and no probs.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
