PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Tranny shifting problem (& DTC 16)
  2. Rebuilt 4l60E delayed first shift
  3. Caps Fell off my U-joint
  4. 4.10's and A4 how do you like them?
  5. Trouble going in 5-6 after Mcleod install.
  6. speedo sensor leaking
  7. Ok ordered my converter and Flexplate.....
  8. Shifter Indicator problem - Stops in the middle of numbers..
  9. manual shift 4l60e
  10. tips for replacing clutch master
  11. m29 t 56 tranny
  12. stall recommendations
  13. quick differential oil question (yeah, i did a search)
  14. A4 to M6
  15. which rear end to pick?
  16. Rear end gears nitrided or cryo'd a good idea? ---
  17. Linkage on auto tranny leaking
  18. 2002 rear end in my 94 z28?
  19. 93 auto wont shift
  20. Average ATF Fluid operating temp?
  21. Major Dana 60 problems
  22. Intersting clutch setup on ebay?LT1? LS1?
  23. truck 700r4 with 93 LT1
  24. Transmission pan gasket question
  25. Recommend a good tranny for my build?
  26. writeup for tranny pump replacement?
  27. Shifting Points??
  28. what can happen from reusing a converter?
  29. eaton limited slip vs tru-trac
  30. 4l60e
  31. 10 bolt in a 2800lb car... can it survive?
  32. Driveshaft issue
  33. clunking noise
  34. Any Good Trans Pans I Can Get At Summit For A 4l60e Trans??
  35. 4l60e ?
  36. clutch hydraulic probeblems
  37. Transmission
  38. Is it common for the torque arm to break the trans case in a rear end crash?
  39. tc needs warming up!?
  40. selling 350 tranny
  41. tranny problem (need help)
  42. How much HP can stock rear handle with 4.11's and a girdle?
  43. 4L60E advice
  44. rear end help
  45. LT1 T56 SFI Bellhousing!!!
  46. Problem Down shifting
  47. Transmission help plz help fast
  48. Narrowed 9"?
  49. LT1 steel DS (say no to LS1 DS)
  50. Bolt together converters
  51. Rear axle blowout
  52. Anoucement from PerformaBuilt
  53. Are all 700R4's the same?
  54. 4l60e year identification
  55. 4L60E pump problems?
  56. clutch disk install help
  57. which transmission to get?
  58. Digital Trans PSI gauge found!!!!
  59. Vibrations!!
  60. 12 bolt rear questions
  61. Tiny part BIG problem, Where can I get this pin?
  62. tranny tube spray??
  63. 3rd Gen. Austrailian rear end
  64. what to get: 4L60e tranny and Torque Converter
  65. vibrations in the drivetrain at over 100
  66. 1995 TA with shifting issues
  67. What info do i need to order the right yoke for my 4l80e
  68. 4l60e home rebuild questions
  69. Chevrolet Bulletin 91-05-7B ??
  70. Trashed TO bearing, need advice
  71. Lock-up intermittent at highway speeds...
  72. converter
  73. skip shift question....
  74. what gears for blown 383
  75. Install question ford 9" with TA
  76. tranny fluid question
  77. Is this large round hole supposed to be here?
  78. Clutch help
  79. Bellhousing question
  80. Lockup "test switch" to disarm and arm lockup....Which wire?
  81. Anybody Know the Weight of Stock Flywheel/Clutch/Pressure Plate Assy?
  82. 95 Z28 does not drive in 'D' (auto tranny)
  83. Difference...
  84. What's wrong???
  85. Street twin impressions
  86. 4L60E help
  87. called strange on the dana 60,[...]?
  88. Parts needed for axle bearing replacement?
  89. Problem with Torque Arm
  90. T-56 something weird happened
  91. transmssion problem????????
  92. How much HP/TQ can a stock DS handle?
  93. Torque Arm -- suppose to move back/forth?
  94. t56 rebuild
  95. A4-M6 swap...new torque arm needed?
  96. 10 bolt main cap torques
  97. Just an FYI on wire pigtails
  98. has anyone ran spec clutches?
  99. 4L60E no 1st gear select??
  100. 1st gear on my 93 z28?
  101. Moser 9" problems
  102. 9" yoke u-bolt torque spec needed.
  103. Shifter Springs
  104. why am i seeing a Borg warner 74658a and 74658c input sprag
  105. 4.10 and a 4l60e
  106. Strange 12 bolt vs S60 Rear End
  107. A little Information about PerformaBuilt Transmissions
  108. HURRY! What exactly did I break here?
  109. Billet Superior super servo vs fairbanks billet
  110. Sequential shifter for H Pattern
  111. Is a shim kit necassary?
  112. different street twin question
  113. 1k miles on my CPT trans and a few more passes lately.. still goin strong!
  114. Anyone rebuild stock differentials?
  115. Transmission slips
  116. clutch questions
  117. LT1 TO LS1 rearend swap
  118. axles too worn?
  119. gearing
  120. Ford 9 vs. upgrading parts in stock...looking for advice
  121. Slave cylinder
  122. 4l60/ 96 Z-28 ???
  123. 4L60E to T-56 swap
  124. Rearend swap?
  125. Converter flash question
  126. T56 Mileage - Need Advice
  127. Where can i buy a new 10 bolt rear (need price for insurance quote)
  128. Dot 5 In clutch master and slave?
  129. torque converter Install problems
  130. Codes but not fixed yet...
  131. Rear end gearing
  132. Car stalls in neutral at a stop (M6)
  133. Bleeding Clutch
  134. New 5&6 speed auto trans.
  135. Advice?
  136. Hurst HOTSHIFT ATF safe in T-56?
  137. noise?
  138. Opinions on Converter
  139. Another CPT car in the 10's
  140. Gear Oil
  141. 97 trans in a 94z
  142. How many BTU's for tranny cooler
  143. Grinding when cold (T56)...
  144. The best trans cooler?
  145. 3.90's for a 2 series carrier?
  146. Clutch fork problems
  147. A litle information about PerformaBuilt Transmissions inside
  148. Gear swap, best place for parts?
  149. 185k T-56 pics
  150. Rear end noise
  151. 4 month old tranmission is messed up for 2nd time
  152. Rear End
  153. So do you love or hate your Dana 60?
  154. Tools required to rebuild th350?
  155. question about limited slip additives
  156. question on rear-end..
  157. clutch master cylinder
  158. Will the clutch hose drill mod work for LT1s?
  159. T56 help!
  160. 1994 z28 3 to 2 auto downshift problem
  161. Where to get a Dana 60??
  162. Questions about the Mcleod street twin, yes I searched!
  163. One Piece driveshaft
  164. anyone w/ a ls1 and th350/400 setup in here
  165. banging noise in first under acceleration
  166. Transmission not shifting unless I let off the gas...what's wrong?
  167. Looking for detailed diagram of a T56
  168. Broken Trans Mount
  169. T-56 Hydraulic System help!
  170. Dumbest question ever - skip shift
  171. 4L60E to T56 swap?
  172. I just bought RAM HDX Clutch .....Need advice
  173. T56 goes boom???
  174. Wire Plug in the tail shaft of my 93' 4l60????
  175. PerformaBuilt Christmas SALE 10% OFF EVERYTHING TILL XMAS EVE
  176. ls1 rear end sawp into v6
  177. Flush or no flush?
  178. banging noise when shifting into 2nd
  179. 10 bolt carrier bearings
  180. AutoZone LT1 Flywheel...$59.99+Core
  181. 8.5" 10 bolt rear for F-body?
  182. driveshaft swap
  183. lsd ?
  184. Torque Converter Selection
  185. Torque converter
  186. easy petal
  187. Poly trans mount
  188. th 350 swap
  189. lightweight flywheels
  190. Guess this noise...
  191. Help w/ Man. Transmission pull
  192. do you have to use atf on a t56 ?
  193. u joint #
  194. strange 12 bolt abs sensor
  195. Diff temp.
  196. drive shaft - how many ways
  197. Diff. temp
  198. Clutch Hydraulics shot, anything better than stock?
  199. Trans sometimes won't shift unless done manually.
  200. 12 bolt question
  201. Rearend rebuilt still howling! Please help.
  202. Broke Bolt off in Flywheel
  203. oil coming out of rearend
  204. Would these fit a stock 10 Bolt?
  205. What combo would you recommend? (Stall/gears)
  206. Best type of rear end for Auto-X /road racing/ drag racing....
  207. Ford 9" Rearend
  208. Accepting a mechanical speedo..t56 related
  209. what has happen??
  210. Pullin Transmission
  211. Strongest 10 bolt gears? (oxymoron?)
  212. 400rw big converter stock tranny last?
  213. $680 to do a gear swap and replace leaking pinion seal?
  214. causes for broken flexplate
  215. vibration
  216. Performabuilt converters
  217. Noise from the rear of the car. Please help
  218. PerformaBuilt Count Down to CHRISTMAS SALE 20%-!9%-18%-
  219. Third time in the shop this past month...
  220. trans issues
  221. NEED A CLUTCH INSTALLED IN MICH !help
  222. 4L60 to BW M6 swap=> Change in drive shaft length?
  223. Pump Housings
  224. A4 to TH350 conversion.....Suggestion
  225. ? Differential Bearing Cap Stud Kit
  226. transmission leaking??? *pics*
  227. Auto or Manual?
  228. Under-gearing and over-gearing effects on 1/4 mile performance
  229. Speedometer/Tripometer issue...Help?!?!
  230. Tail Housing
  231. 3:73's???
  232. I need to get creative...
  233. drive shaft question
  234. Anyone use the straight crossmember from Spohn with Pacesetter Y
  235. Mustang T56 shifter?
  236. 12 bolt drive shaft
  237. transmission slipping
  238. ADJ Torque arm w/ duals?
  239. 427 RWHP LEVEL 1 PerformaBuilt
  240. Pilot bushing vs pilot bearing??
  241. is this a good clutch
  242. pilot bushing
  243. Gear swap, performance difference ?'s
  244. OEM hurst knob part #
  245. Torque conv. vibrations 3rd gen.
  246. Bucking/chugging.... What causes it?
  247. Rear end swap, drum brakes to disc brakes, any difference w/ brake line pressure?
  248. my 1995 z28
  249. Whats going on with my clutch/tranny???
  250. Noise from transmission!
