PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. What diff. do I have? 95 z-28
  2. Centerforce DF Clutch
  3. pop feeling through arm rest
  4. Rubbing/Whining noise
  5. Bm Shift Plus
  6. How do you get the master out of the firewall?
  7. what year rearend will fit?
  8. SLP Billet Steel Flywheel
  9. horrible mileage...converter?
  10. slave cylinder?
  11. Braided trans lines, adapting to factory lines at radiator
  12. Shifter flex at WOT?
  13. stock trans
  14. Oh man here's what I did (photo)
  15. Quick gearing question
  16. Clutch issue
  17. Clutch Going OUT???
  18. Trans question
  19. Pulley problems
  20. Filling up t56
  21. tranny question?
  22. What part in my clutch assembly is failing?
  23. Just installed a 9" rear end from Scott at DLS
  24. fluid on torque arm ???
  25. TA Diff Cover
  26. Ratchet shifters
  27. 96-97 4l60e in a 95 lt1 car
  28. kinda weird question?
  29. How hard is it to replace a ring & pinnion?
  30. Fidanza Flywheel Balancing?
  31. Is it worth it...?
  32. clucth problems
  33. mity-vac clutch bleeding...in reverse
  34. Vibration only in 3rd gear....any guesses?
  35. A4-->M6 Inspection Plate
  36. How to flush/replace clutch fluid
  37. Guidepins on tranny came off, also cant shift WOT M6
  38. Reduce gear backlash?
  39. T56 Skip Shift Question
  40. Tightening Pattern For Flexplate
  41. Clutch Advice-LS1
  42. will there be a night & day difference?
  43. anyone running a manuel steering rack?
  44. Swapping a 4l60e
  45. Centerfoce DFX ??
  46. 2800 Stall Converter with 2.73s....Interesting
  47. converting auto -> manual
  48. need truck help
  49. blow scatter sheild/bell housing
  50. a4-m6 torque arm question
  51. series 2 series 3
  52. Lock up Questions and Remedys
  53. M6 to 700R4 swap?
  54. rear gears
  55. i forgot to say
  56. oil Pressure keeps dropping????
  57. Double Overdrive in a 4L60E
  58. transmission problems
  59. a wiring question
  60. 4L60E need help!!
  61. differential question
  62. labor prices-Moser 9" vs. Strange 12-bolt
  63. Mystery trans wire to NOS--
  64. security light
  65. Best LT1 Clutch?
  66. Another VERY satisfied CPT customer !!!!
  67. using N20 through shifts?
  68. LS1 clutch swap guide?
  69. 96 ta rear
  70. T56 Trouble - Synchronizer
  71. Help in choosing a stall?
  72. Stall do more than lower 60' time?
  73. How long on stock flywheel?
  74. are these the right parts for 3.73 ?
  75. Gears and stall
  76. 3600 Tci Oh My Goodness
  77. Keep The A4 OR Swap M6?
  78. Grinding noise coming from rear end...
  79. T56 interchange question
  80. 4th gen clutch releasing high
  81. Moser 12 bolt + Denny's Nitrous Ready DS = which torque arm and drive shft loop?
  82. th350/2.73's-what kinda mpg?
  83. Ford 9" ring and pinion installation kit???
  84. need sum major info
  85. Quiet Gear Set Up in Moser 12 Bolt
  86. H/C A4 ls1 cars from 3.23 to 3.73 gains?
  87. Which exact p/n of ARP wheel studs to order?
  88. Engaging clutch sounds like rocks crushing ---
  89. Motive 3.90's for the 10-bolt - Review
  90. Are 3:42's the wrong thing for my setup?
  91. wont shift into 3rd gear
  92. 4l60e/th400 swap
  93. IROC trans swap questions
  94. MAC differential cover, ARP stud kit...clearance issues
  95. transmission performance button?
  96. LT1 Flexplate Bolt Question - Help
  97. Driveshafts - Stock Alum 1Le - Diameters
  98. Should trans cooler be this hot??
  99. Impy rear end
  100. chrome differential cover?
  101. Yank's customer service.
  102. 4L60E Problem
  103. clutch work...some basic questions
  104. B&M Shifter Stops
  105. lt1 and th350
  106. Peptobismal looking fluid?
  107. Royal Purple and LSD additive?
  108. hyd line broke...clutch fluid on clutch...
  109. 9" Owners please
  110. Does a bellhousing blanket add significant protection?
  111. Lock-up only occurs with Lock-up Switch
  112. 4l60e error 82
  113. T56 issues
  114. Having some SERIOUS 4L60e fun... Experts please chime in.
  115. Flushing Slave Cylinder Fluid
  116. turbo 350
  117. Scattershield
  118. pro 5.0 --- B&m---Or Hurst???
  119. slipping 2-3 shift
  120. Removing U-Joints from LS1 Driveshaft
  121. Thumping from Auto Trans???
  122. 4L60E to T56 conversion
  123. Opinions on torque converter brands
  124. Link to Tranny Removal/Installation Instructions
  125. Is this a problem? (video)
  126. Ram Adjustable Clutch Master
  127. 4.11 12 bolt guys come inside
  128. T-56 question
  129. about my diff...
  130. Oh man what did I do...
  131. Clutch will not disengage, rod doesn't move that far.
  132. vibration
  133. Buying a used converter, some questions
  134. Just ordered my Yank PY3600 Extreme...
  135. Just ordered my Yank PY3600 Extreme...
  136. Looking for a tranmission builder in colorado
  137. T56 clutch fork parts?
  138. New convertor for my car help
  139. s60 rear sway bar??
  140. T56 in a non-F
  141. 4l60e lock-up comes and goes,
  142. clutch pedal not coming all the way back up
  143. Which Pin is A on the M6 VSS?
  144. biggest tire under factory wheel well
  145. GM 3.23 or 3.42 gears
  146. 3.23 vs 3.73 gears,is it worth it?
  147. How to drop trans w/o dropping motor??
  148. will a caprice drive shaft fit into a camaro tranny?
  149. maddog sec 3 clutch on ebay
  150. LS6 clucth
  151. Ram adj clutch master cylinder
  152. adj clutch master cyl....where do YOU like your pedal?
  153. yank 3500/Vig 3600?
  154. Flywheel and Pressure plate bolts
  155. TH400 or TH350?
  156. Anybody Buy a Tranny from Performabuilt...feedback
  157. th400 install: checking i have stuff right
  158. Bleeding The Clutch
  159. T-56 question
  160. Need list or kit for th350 or 400 swap ,please help
  161. Valeo pressure plate/any good?
  162. Who sells a bullet-proof turbo 400?
  163. Running problem after 6-speed swap...
  164. Couldnt get it in gear.
  165. When did your 10 bolt break?
  166. rear end and trans ?
  167. poly mount vibrations
  168. Strang 12-bolt
  169. Nuetral start and backup switch R&R help
  170. Help Please? Proper Backlash for Used GM Gears
  171. Torsen Question
  172. Clutch's
  173. Gears and odometer
  174. Where is the T56 fluid fill hole?
  175. Need A new clutck
  176. Is this normal for ring and gears?
  177. I think I'm being robbed...
  178. how much oil is needed?
  179. LT4 clutch prices?
  180. Recommended Shifter and Install
  181. 94 4L60E stock converter in an 87 700R4..
  182. Opinions on manual valvebody
  183. Are The Newer Bigger Servos Necessary?
  184. what is an lt4 clutch? differences?
  185. Auto Trans Question??
  186. GM 3.73 or 4.10 - Where to buy??
  187. 1993 borg warner/ZF six speed???
  188. Is going to 3.73s from 3.23s worth it?
  189. any tips on keeping my 7.5 together at the track tonight?!?!
  190. Automatic Conversion Questions
  191. quick question
  192. differential girdle...info needed
  193. Spec stage 3 PLUS...
  194. The same o'l "Clutch ?"
  195. clutch question
  196. So I blew up my rearend. Questions??
  197. questions on setup
  198. Where is VSS pigtail on auto tranny?...
  199. trans
  200. M6 pedal wiring help
  201. Having trouble shifting, please step inside to help...
  202. rear end messed up again, and ideas?
  203. Clutch engages further out on the pedal? ---
  204. TC choice advise.
  205. Where's the bleeder? '99 LS1 T56
  206. Braided tranny lines
  207. I floor it, but it barely moves!?
  208. rear end axle problem
  209. Rear End Swap?
  210. lt1 driveline vib. help
  211. moser or strange
  212. TRANS FLUID change
  213. Drive-Shaft Length with Moser 12-Bolt?
  214. LT1 fit on 92' TH400R (4L60) Tranny?
  215. Need clutch replaced DFW TX area
  216. Need a flexplate...
  217. Here is what happens with shady trans. shops !!!
  218. powerglide into LT1?
  219. New TH-400 with no reverse?
  220. Centerforce DF prob
  221. powertrax lockright rear...
  222. T-56 to Auto 4L60E? swap .. need some help
  223. SPEC Twin Disk Clutch Assembly
  224. Rear ends whining
  225. Doing burn outs in a manual trans camaro.
  226. 6 speed difference
  227. Qustions about manual trans
  228. Shift Stick
  229. Clunking Noise On Manual Trans!!!!!!
  230. Cheap, near-stock replacement clutch?
  231. Series 3 Carrier Direct Replacement for Series 2?
  232. McLeod Street Twin
  233. First time doing fluid/filter change... couple questions
  234. ws6store short stick vs ebay
  235. Trutrac trouble
  236. Clunking sound in rearend...
  237. TH350 sensor
  238. f-body Dana 60?
  239. Venting!!
  240. TH400 trans
  241. Help me buy parts for my tranny
  242. Tranny woes.. or normal? (VIDEO)
  243. Tranny woes.. or normal? T56 LS1 (VIDEO)
  244. T56: What could this sound be?
  245. How do I find out what type of Posi unit I have?
  246. centerforce dual friction _ bad or good idea
  247. posi unit
  248. trans problem
  249. Do I have 3.73's?
  250. What all should I buy for a rear gear swap?
