LT1/T56 Flywheel balance
Is a LT1-T56 flywheel neutrally balanced, or externally balanced.
I'm building a 383 Gen I using a '86 up one piece rear main block, with a T56 tranny. I'm trying to figure out how it needs to be balanced.
If it's not neuatrally balanced. Does someone make one that is?
Re: LT1/T56 Flywheel balance
OBE is right, if you look on the engine side of an LT1 flywheel you'll see a curved square steel bar welded into place. This is b/c the LT1 is externally balanced from the factory. There are neutrally balanced flywheels available, so if your engine is neutrally balanced you should just be able to bolt it on. They're kinda pricey though...
karpetcm
09-29-2015 10:08 AM
