View Full Version : Drivetrain
- Best way to disable converter lock up???
- Had a little accident, not sure if I can fix or not
- auto wont go in to gear
- HP&TQ limits of a Yank ST 3500
- What is !CAGS? What about Skip Shift Eliminator?
- Maintanence schedule for t-56
- A stupid question from a new M6 owner
- Gears
- How do you change shift points in a 93' 700r4/4l60??
- What do I need for a TH350 swap.
- Shifter M6 in 58 El Camino
- Mcleod Master Cylinder interchangable ?
- LT1 4l60e vs ls1 4l60e
- limited slip/posi ?
- 95 Trans Am transmission
- How do you use the Dial Indicator?
- Thinking about a new flexplate??? should i?
- bleeding clutch master cylinder
- Ford 8.8?
- gear question
- brakeline help MAJOR!!!
- M6 guys , I have a question !
- Stock Master Cylinder Blown!
- McLeod clutch value??
- anyone running 2.73 gears and a converter?
- spec stage 3 probs
- will t56 from ls1 work on lt1????????
- best rebuild kit for T5
- Rear caliper e-brake bracket part name?
- who said the 10bolt was weak?
- New Bolt-In Sequential 6-speed Manual!!!
- Ls1 t56 for lt1?
- What is the best aftermarket shifter for T56?
- Step By Step cuutch install
- Axle Condition Question...... :D
- rear end swap (ABS) hook up
- Clutch noise when clutch pedal floored??
- Z06 Clutch...is it worth it???
- so the factory hurst sucks huh???
- Flexplate/starter help? Please!
- Anyone Rebuild their 4L60e theirself ?
- shift kit install price?
- How hard to replace the differential unit?
- 4L60E No Upshift!!??
- 95 4l60e
- Is it worth the extra $145...???
- 3:73's or stock ?
- ls1 tranny mount & drive shaft
- 95 4l60e in a 94
- aack another speedbump on my way to discbrakes! Give a chick a break!
- Help! Moser 12-bolt broken after 1 pass!
- Electronic shift improvers?
- Need opinions on what the best quality lifter is for stock cam ...one has gone bad
- anyone think of running a 4 link?
- At what speeds is the 93' A4 4l60/700r4 suppose to shift?
- T56 is out the TH400 is in!
- Help! I dont know trannys
- Problems with the B&M Short throw shifter
- rwhp to flywheel hp conversion?
- Gear install... do it myself? hints? tips?
- 4l60e ?'s
- moser question
- Rear axle, bearing or seal problem???
- Torque arm mount -dana 60
- Soft Shifts when car is cold????
- Is it possible to make a Z28 into AWD?
- Is a T56 3-4 Syncro Assembly Easy to Get At?
- Fabulous Brakes, Much Less than Baer, etc.
- Advice Needed!
- Rear fluid
- My M6 All of a Sudden Became Hard to Shift
- rear end swap
- Updated slave cylinder p/n?
- t-56 parts
- T-56 problems
- Torque converter question
- New noise please help...
- is the lt4 clutch a direct bolt on for lt1 cars?
- 9" questions
- wheel bearing help
- How is converter lockup controlled on a '93?
- Anybody who's done the drum/disc swap some help plz!
- Torque Arm question?
- This may be a dumb question
- What stall to get? (rpm)
- snapping sound with hard shift?
- Center Force pressure plate with some other disk?
- 4th Gen REAREND, WELDED-ON CALIPER BRAKE MOUNTS
- Rear end question
- LT1 T-56 vs. LS1 T-56
- pops out of third
- Extreme Automatics trans ???
- question about gears
- 4l60e- 700r4
- tranny slipping or no?
- 700R4, highway RPMS a tad high :/
- Clutch pedal must be stabbed for the car to start???
- A4 rebuild
- rearend starting to make some noise
- 4L60E repair in DFW? otherwise PMAC/CM in Houston.
- throwout or pilot bearing? help & explain please
- UH OH, What The .....?
- Sprung -vs- Unsprung clutch?
- Should a new clutch slip?
- speedo is in-op
- A4 to synthetic Question
- Possible Tranny Prob?
- Clutch Disc Springs
- Possibility of tranny going bad?
- cant find blinker fluid at autozone (big thinkers inside)
- Symptoms of bad rear/posi?? Loud snapping when turning hard
- my transmission fell 3in inches while driving
- what gears?
- Changing Auto into Manuel???
- Knocked off .4 w/ B&M 2400!!!!!!!
- 4L60E up shifts when in 1st Gear
- Posi?
- 79 Z28 Transmissiom
- Why do my gears grind when i jump on it?
- So how bad for your brakes is doing a burnout w/out Linelock?
- should I flush the tranny or not?
- Clutch or rear axle fooked?
- 9Inch pinion seal
- Need advise on a Turbo 400
- LS1 driveshaft into an LT1
- Traction bars?
- Driveshafts, best bang for the buck?
- shift kti
- TCI shift kit first impressions
- wierd tranny rattles
- Fix master cylinder?
- tranny flush
- Need advice..rebuild my trans or get an aftermarket? Pros/cons to each?
- What clutch would you guys suggest...
- who uses transgo shift kit
- $375 shipped a good deal?
- diameter of 98 VSS sensor
- New Mcleod Clutch...Still Problems.
- Steering weird with locker engaged?
- transmission service
- Rearend Swap, What do I need to do?
- What suspension parts are best.
- LT1 and LS1 auto tranny's
- Will a shift kit from a.....
- Need help on which clutch to buy
- How hard to put 7.5 axle tubes on a 8.8 or 8.5?
- 95 4l60e
- Clutch problem, can anyone help?
- new clutch problems, please help!!
- High mileage tranny and TC: yes or no?
- Pilot Bearing Disinigrated
- What is so freaking spectacular about a GM stock replacement throw-out bearing?!?!?!
- Midwest stalls
- Bellhousing Bolt Pattern Dimensions
- What Trany to go with
- A clutch replacement is hard work!
- 4.71s in a 10bolt??
- 9" moser
- TCI Shift Kit install and one problem
- Slipping?
- How much power can the stock d/s hold?
- which driveshaft fits?
- 7.5" open carrier for spool question
- pro 5.0 review
- Gears?
- Setting Backlash.
- Please help shift kit install
- gears????
- trans problems---- help
- Tranny up in smoke
- different 4l60?
- Stock Torque Converter?
- swaping from a t56 to a th350
- Transimission Question
- High stall TC characteristics ?
- How Can I Tell If This Is A Ford 9 Inch or A 8.8 Rear
- Spec Stage Iii
- LT1 TC in a LS1?
- Best Place for LT1 Rear Rotors
- Where to get T56 parts?
- How much for a new rear end, and where?
- How to identify a stock LT1 torque converter?
- Whats the tq specs on a pressure plate?
- is this what you called a slipping tranny?
- Differential Upgrade
- Who builds the strongests 4L60E's out there??
- Reinforcing a 10 bolt?????
- chattering noise
- Driveshaft Compatibility
- Drill Out Mod on a Spec Clutch
- What clutch (non street twin) to support 500 rwhp??
- Grinding rear end
- 500 RWHP+3700lbs+4L60E Will it live?
- Arrgh... Just got a conversion u joint... still doesnt fit right!
- New GM Motive and gear whine?
- Bad pinion seal
- Rear End Girdles?
- M6 Guys: Gears?
- Is anyone running a McCleod adjustable clutch master cylender? Where do you get them?
- Problem with CenteForce D/F clutch
- 3000 stall with stock setup
- a4 to m6 swap!!!!!!
- T56 - occasionally jumps out of 2nd
- Trans Problem ?
- New Clutch?
- Lets say i put clutch disk in backwards?
- setting pinion angle??
- torque arm and pinion angle
- anyone out there using a centerforce cluctch on a fbody?
- Hpp Iii Shift Points
- Converting 4L60E to vacuum operation...
- Disappointed with SLP
- Anyone using the 4L80E???
- Energy Suspension's Poly Tranny Mount Install Question
- TH350 or T-56?????
- How to store 4L60?
- Anyone running a M6,230/236 and 4.56 gears ?
- shiftplus electronic shift improver??
- Clutch going?
- Finally ordered my 12 bolt J I got
- driveshaft lenth with 6" tailshaft?
- clutch and tranni question???
- Help, Anyone know the size of the bolt for the Pan Hard Rod (PHR)?
- rear end noise
- good stall speed for....
- Car is lopsided after axle swap
- Rear squeals when cornering under accel.
- Competition Engineering Rear Drag Shocks
- rpm w/ hot cam & 4:10
- Daily driver: lockup or nonlock up?
- what does a broken tranny mount affect?
- Where is the best tranny cooler location??
- Considering trading my 12 bolt for a 10 bolt. Am I crazy?
- Broken axle and more...
- Tc ??
- Very odd tranny problem (help!)
- Differential question
- Stock Tranny mount or Poly?
- Street Twin throwout bearing
- How much pinion angle do I need?
- fidanza alumnium flywheel
- Rear end swap
- Hyd throw out bearings
- PCM will not see TCC soleniod ...maybe wrong year trans ?
- Spongy clutch pedal
- How much can the stock clutch and 10 bolt take.
- Squat or anti squat
- Recommendations for tranny and diff fluid brand and weight
- Tranny Rebuild Questions.
- Hard to get in gear
