PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. What causes slip yoke play?
  2. Where to buy Just the clutch disc?
  3. TH350 to manual help!
  4. Flywheel loctite, What color?
  5. torque converter will not lock
  6. 4L60E swap to 700R4
  7. 1995 Camaro Z28 Auto
  8. b&m ripper shifter issues
  9. shift lever shaft seal change
  10. issues with welding relo brackets on a NEW rear!!! Please help!
  11. clutch pedal spoungy no slipage
  12. Pro 5.0 need grease?
  13. Anybody rebuild and upgrade their Eaton from 30 to 33 spline?
  14. T/a girdle??
  15. Converter help
  16. Center force clutch with stock Pressue Plate
  17. How much power can a 4L60E take and be reliable?
  18. How to tell the diference between M6 trans
  19. vote on which gear brand
  20. Vigilante Converter?
  21. Banging in rearend when not under torque
  22. Th400 Where,what And Who...
  23. Changing shift firmness mechanically
  24. tc won't lock
  25. rearend numbers
  26. Whos runnin RAM Powergrip clutch set?
  27. Question for people with S60
  28. Can't shift into third..
  29. Has anyone installed braided cooler lines for 4L60E?
  30. Tranny temp gauge install question
  31. PerformaBuilt! Weeky SALE SPECIAL $IN HERE$
  32. LS1/A4 to M5
  33. blown t-56 whats should i do?
  34. Not sure whats rong????
  35. throwout bearing, clutch master or froze pressure plate issue?
  36. Help! Weird sound from rear end!
  37. tci converter change
  38. T56... Shift Fork or Syncro issue... help?!
  39. Part number for GM master/slave combo?
  40. Tranny Concern?
  41. 4l60E clunk into 3rd
  42. 93 Z28 Trans. issue
  43. need a clutch...
  44. 4L60E Shifter Solenoid Replacement
  45. How to Install Aftermarket Auto Shifter
  46. 4L60 on it's way out...
  47. DUmb ?
  48. auto trans mount
  49. Lt1 Where Should Clutch Grab??????
  50. Help with pinion bearing
  51. help
  52. wot lockup
  53. Northwest Gear Install Help!
  54. V-body rear end fit in my F-body?
  55. ? for performabuilt
  56. Book for tranny rebuild?
  57. Slip yoke sticking T56
  58. Think it's time for a 12 bolt (see inside)
  59. entire new rear or just housing??
  60. 10 bolt, pinion NUT! HELP
  61. 4l60e not going into reverse
  62. How hard is changing a 4L60E?
  63. Moser 9" 93+ Questions.......
  64. 9 inch or 12 Bolt
  65. how much will my mpg go down???
  66. Anyone ever deal with Gripforce-clutch on ebay for a Valeo clutch?
  67. Please help!Clunking!!!Idk what or where!
  68. clutch problems
  69. Servo upgrade
  70. lt1 rear into ls1 car?
  71. viper transmission?
  72. new clutch
  73. 97 Z New Clutch Grabs Low Please Help!!!!!!!!
  74. What Series Am I? Best 3.73's?
  75. how to install safety switch on Quarter Stick??
  76. 1993 camaro shifts high
  77. Input Shaft Seal Difference's?
  78. Need help with my '94
  79. Slave Cylinder Studs Length
  80. 4l60 seal?
  81. Vig converter?
  82. Bad converter ?
  83. Help with rear end gear size
  84. Moser Rearend and Brakes for a thirdgen???
  85. pardon my stupidity...
  86. T56 Removal Help
  87. Yukon 4.11 Ring and Pinion Gears
  88. Stock Clutch Replacement
  89. Ram HDX and Powergrip chatter ?
  90. Transmission Question
  91. !?!?
  92. NEW Street Twin engages all the way at the top
  93. differential?
  94. lt4 v.s lt1 disc and throw out bearing question
  95. Rear end/Diff problems
  96. 4.10s and your 1/4 time. (m6 guys here)
  97. Support engine while removing transmission?
  98. t56 fluid
  99. 4.3 V6 4l60e on LT1?
  100. T56-shifter guide bolts
  101. Are stock LT1 flywheels nodular or cast iron?
  102. best place to get 3.73's ?
  103. Clutch Question
  104. Removing a stripped screw on the differential?
  105. 10 bolt with a4, girdle, and 315 Dr's how long do i have
  106. Is there any "how too's" on clutch master cyl.??
  107. t56 hard to shift...
  108. gm 93-02 10 bolt
  109. Royal Purple Synchromax - t56
  110. Remove AT Shift Cable
  111. the dana 60 just showed up, what paint to use?
  112. T5 Transmission Removal
  113. Help picking gears
  114. Clutch pedal engaging clutch EVERYWHERE???
  115. ls1 and th350 ?
  116. LS-1 T-56 in a LT-1 car???
  117. no 3rd gear in th350
  118. RAM PowerGrip Performance Clutch
  119. Sythentic fluid in t56 -Royal purple
  120. Which yank torque converter for my camaro??
  121. Uh oh.... 10B noise.. Normal? HELP!
  122. speedo
  123. T56
  124. Who runs a spool
  125. Tranny Fluid
  126. does this look like a good transmission
  127. what to do?
  128. Aluminum Flywheels (LT1)
  129. clutch pedal linkage => Is there a spring
  130. HELP!!! with bolt size
  131. If you had around 5k what would you do?
  132. I think the Clutch MC is leaking
  133. question bout my 10bolt?
  134. Which M6 shifter should I buy?
  135. do stock driveshafts twist and start causing vibrations?
  136. 700R4 TCC Hookup
  137. lt1 posi fit a ls1 housing?
  138. Broken POSi or non-posi?
  139. How many miles for stock Posi before rebuild?
  140. stock trans
  141. RE: HELP, Strip bolts on stock converter
  142. High speed question
  143. HELP TRANNY, should i build it??
  144. Does shifting to Neutral help to slow ur car?
  145. Notch shifter for the t56
  146. Driveshaft compatibility question
  147. 12-botl, vs 10-bolt pinion seal question.
  148. th350 to ls1 gm tranny adapter Part#
  149. Bent rod on master cyl
  150. ls1 4l60E to t56
  151. If you need a tranny rebuilt
  152. Downshifting an Auto bad?
  153. clutch going out?
  154. Outer rearend bearings have big play - what broke them?
  155. Bellhousing to Block bolts? T56
  156. 3rd gen versus 4 gen axle width
  157. shifters for the 4L60E
  158. Anyone running a centerforce DFX clutch?
  159. What diff??
  160. can't get 4l60 out of 98 ls1
  161. T-56 Clutch Disengaging Issues. Help?!
  162. U-joint help
  163. T56 parts question
  164. help me pick a clutch. Pretty please?
  165. q's about LT1 hydrolics
  166. Clutch petal grinding?
  167. pressure relieved
  168. LS1 T56 to LT1 T56???
  169. My 2nd Gear whines on my rebuilt t56
  170. Overflowing tranny?
  171. converter fitment question
  172. The feel of the new stall.
  173. tranny cooler and stall?
  174. Master cilinder help!!!
  175. Problems with 4L60E after rebuild
  176. RE: How to tune diablosport for new Converter?
  177. Test: plse ignore
  178. Had my flywheel resurfaced while out ,but still have questions
  179. 10 Bolt Rear End
  180. 97 Camaro trans feels notchy
  181. External Fan Cooler Only
  182. what is the max mph
  183. lets talk about locking the converter on a dyno
  184. BIG $ PerformaBuilt TAX REFUND SALE!
  185. HELP! Axles have in-out motion, what is causing it?
  186. Does a stall conv. help rolling starts....
  187. should i change my trans fluid?
  188. Neutral Lock-Out Switch (bizarre problem)!!!
  189. LT1 Driveshaft question
  190. Need tranny rebuild? 1-2 almost gone
  191. Shift points
  192. R.I.P. 10 bolt 2/10/08
  193. Stall wall questions
  194. Clutch pedal keeps getting softer and softer, but no slippage
  195. tune for stall?
  196. Does a 99 Auto Z28 have a limited slip diff?
  197. moser question
  198. Neutral Saftey Switch 88 Iroc-z
  199. floor opening for M6
  200. HELP! Rearend problem, banging on both wheels...
  201. Torque Converter holes not lining up with TCI flexplate.
  202. rearend question...
  203. Car only goes in reverse
  204. Let's hear everyones CPT experiences oh and btw I'm a n00b to the board hello
  205. pinion bearing/seal - where to buy (not kit)?
  206. m6 trans removal tip
  207. 4.10 vs. 3.73
  208. TCI Competition or Super Street Fighter (TH350)
  209. A4 downshifting problem...
  210. Question about automatic transmissions
  211. Is the LS1 & LT1 Clutch Pedal the same? Pedal assembly?
  212. rear end
  213. ideas for a 4l60
  214. What Dakota trans. do i need?
  215. Transmission question
  216. eaton lsd
  217. B&M tranny fluid?
  218. Converter experts please teach me
  219. Motor is done, now what rear end?
  220. My 93 z28
  221. t56 question
  222. carrier options
  223. How do i drift in an auto
  224. Want 2 change my auto 2 a manual.
  225. One wheel peel...broken/worn LSD?
  226. Who makes a "good" paddle shifter kit?
  227. 4L60E Neutral Safety Switch Location?
  228. trans temp sensor reads -40
  229. Major Leak Help Please!!
  230. rear end question
  231. Love my CPT trans.
  232. tranny lines
  233. Clutch Master leaking fluid
  234. Making my 4L60e live?
  235. shift points
  236. Please check my 9" ring / pinion gear pattern. Am I ready to go?
  237. the camaro is in it's death bed
  238. rear change
  239. 3.42-3.73 WOT problem (tunercat also)
  240. clutch chatter question
  241. name this rear end!
  242. New stall...
  243. Shift Problems Help???
  244. Strange part # for my flywheel...
  245. T56 to A4 swap
  246. Pictures of my damage rear axle
  247. rear end ?
  248. question about tailshaft..
  249. Clutch Dilemma
  250. loud screech when shifting
