View Full Version : Drivetrain
- stock TC on a built 4l60e
- Fly Wheel Recommendations
- I'll need a drive shaft soon ... any ideas ?
- clutch
- t-56 question
- rear end gears
- Problem with trans
- who else things strange 12 bolt axel tubes are too small?
- 3.42s shift points
- Is a 12 bolt the only solution to our problems??
- TH350 swap how much loss or gain?
- Tranmission not upshifting
- Dealer needs VIN to reprog. PCM after swap?
- tq conv not locking up after warming up
- Unbalanced Driveshaft
- Trans probs !! Help !!
- PCMFORLESS "firmer" shifts?
- factory hurst vs. pro 5.0
- VSS Question?
- ET Streets/10 bolt
- rebuild posi unit?
- is it my clutch??
- Swappin 'trains...
- whats the strongest pinion yoke for a 12 bolt?
- Noise from T56 after clutch install - please help
- Skip Shift Eliminator
- newbie needs help, 6 speed in classic old chassis
- Th400 LS1?
- Need clutch for 425 hp
- Twisted driveshaft slipjoint splines?
- Is replacing driveshafts difficult?
- Noise from T56 when downshifting.
- LS1 axles
- TH350 or TH400, which would be better for me, and whats needed for the swap?
- tranny shifting poorly
- Main differences between the Pro 5.0, SLP short throw, & B&M ripper?
- drikve shaft maybe
- 96 4l60e
- Transmission Dying.... AGAIN!
- How did I get a bad wheel stud with my moser??
- 700r4 trans probelms
- place to buy GM motive gears
- Shifting in an Automatic
- LT1-specific converter install guides?
- Poly Trans Mount
- B&M Electronic Shift Improver Kit
- Shifting the 4L60E
- heavy duty parts
- Got my t-56
- Those w/ McLeod Street twin
- Those w/ Mcleod Street twin inside
- Questions on 95Z rearend
- putting in rearend gears
- 6" Cowl Hood
- Anyone here with moser or spohn driveshaft?
- Trans blanket for a M6
- Will SPEC exchange the old style for new?
- 4L60E question
- posi
- Upgrading Rearend Questions?
- T56 question
- What do I need with gears
- sticking trany
- centerforce clutch
- typical clutch break-in procedure
- typical clutch break in procedure
- new clutch or not ???
- gears
- Odd Noise
- What parts recommended for clutch rebuild?
- PLEASE HELP - Built 4L60e pops out of gear at WOT
- Spec S2, M/C & S/C ordered. Question inside.
- Performance gain w/ light flywheel?
- Does anyone else have probs w/ their stock sway bar fitment w/ strange 12-bolt?
- for those who have a B&M console shifter...
- Break in?
- I BLEW MY REAR!!! And I need advice...
- 4.56's or 4.11's
- what is the stall speed of the stock torque convertor?
- FKING tranny, need help or gonna sell the car!
- how to rebuild a stronger 10 bolt??
- How to Change Pinion Seal?
- TC acting weird?
- please Help! Tranny experts inside...
- 9" arrives today/need tips and tricks
- Which Rear End Fluid Do You Recommend
- Manual Valve Body in 4L60e?
- who carries spohn products?
- clutch or tranny noise
- Do I need control arm relocation brackets for Strange 12-bolt?
- 3.73's????
- Torco Vs. Midwest Converters
- Mcleoud Clutch Question
- Clutch hydraulics drill mod??
- Moser Quality control?
- Clunking feeling and sound on hard take-off!!
- Any fluids help worn or damaged synchros?
- Rpm?
- Spec Stage II means I need new master & slave cylinder?
- Clutch Write Up Needed
- z06 clutch
- T56 value?
- Will the Z06 flywheel work on my Z?
- "Viperizing" a T56 - What does it involve?
- setup help , stall and gears
- Which Clutch to Purchase?
- clutch
- Iron Disk, Adjustable PP, & Blowproof Bell Housing
- Need New Clutch. Which one?
- Clutch slipping at high RPM's
- Gear Install Question....
- M6 Guys who went to 3.73 gears
- best place to take t-56 for viper conversion?
- short shifter
- slp short shifter
- yank vs vigilante
- Question about my 6-speed
- calling anyone with a street twin
- options for a 2800-3000 stall?
- Why does my converter stall higher than rated?
- Rear-end Question???
- Whining rear?
- McCleod clutch questions w/ 6spd
- Decisions, decisions.....TH400/200-R4 (RSKrause)
- Please tell me if my tranny mount is broke!!
- What do you REALLY think of stall torque ratio?
- 700r4 with electric plug on side = lockup?
- how to work ALL the factors in to stall speed?
- what to do for a tranny?
- 3.73's and 2800 stall = ?MPG
- ODD but yet I have never seen before??
- Good or Bad clutch?
- Anyone ever put a corvette IRS into a 4th gen F-body?
- LT1 Clutch Linkage: Tech Question
- Aluminum Drive shaft?
- got grind??
- Ford 9" rear?
- Crazy noise from rear diff.
- trans extemely hard to get in gear...
- feels like something is slipping... tranny? rear end?
- t56 lt1/ls1??
- Street Twin Problems
- U-Joint Reusable?
- trans questions
- tranny
- Help with Driveshaft U joint? rounding? 11mm socket
- Clutch problem, need some help!
- Which stall rating do you like the best?
- Is Centerforce a good clutch brand?
- Moser 12 w/TCS install?
- need help making my 12 bolt stronger / choice of posi/locker/spool
- is the mcleod flywheel SFI approved ?
- shift cable adjustment
- T56 Questions
- New Tranny Mount for T56 Install?
- help me build a strong 10 bolt
- gear install question
- 12 bolt = junk
- Serviceable hubs?
- bought a Moser 12 bolt used...?
- Tranny Help Please!
- Moser 9 inch Question
- Reduce rotating mass by 6 lbs., any measureable improvement?
- What kind of break-in for a rebuilt T56?
- 4th Gen. Vibeshafts and trannys
- Free-wheeling when off gas
- Possible AWD Conversion?
- TCI converter owners in here plz!!!
- What would cause this?
- Think I have a problem with my T56
- Selecting a gear
- Upgrade SLP to SPEC III
- driveshaft
- Gear change, any opinions, suggestions on E.T. effects?
- TH-350 question
- 2.73's
- Are all 4th gen DS yokes the same O.D. diameter?
- How much is there to gain by switching to an LS1 driveshaft?
- Internal construction of the T56
- manual tranny
- diagnose please
- How hard is it to replace the diff gasket (side the yoke goes into)
- Part #, price for McLeod adj. master cylinder
- Hardness of "race" v. "street" ring and pinon
- 6 puck SPEC stage 3?
- "Race Built" 4L60E
- DANA 44 Rear
- Converter observations
- Welcome to the new forum!
- doing a rear end swap... 3channel/4channel/tc questions
- LCA"s
- HELP! which clutch mine just went
- I made progress on the T56 removal, but another problem
- Which clutch should I get?
- transmission swap
- McLeod adjustable master... how do I swap it?
- How much HP is a stock clutch good for?
- Anyone snap a clutch fork in half??
- spicer u-joint#'s
- What were the stock gears in the '95 Z28 8 cyl. cars
- Stall Speed 101
- Automatic shifting?
- Good Price On Honda ATF Z1
- Did i get the one bad street twin?? or what??
- hurst quarterstick in my Z28?
- firmer shifts
- Pinion seal woes
- 1999 TA posi Track Question
- limited slip
- th350 questions, yes I did a search
- Cags, and shifting questions
