PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Question about Tranny swap to th350
  2. will ls1 yank st3500 fit my lt1?
  3. What does a 12bolt REALLY cost?
  4. shifters for reverse pattern
  5. wich converter for my cam
  6. Any one who has shipped a complete rear end...
  7. 4:11s
  8. Will I need a tranny cooler?
  9. 4.11s?
  10. Trying to decide on a stall converter.
  11. Engine brake kit
  12. No first or third gear? please help!
  13. A4 Having trouble going into gear. Need advice
  14. got ls1 edit programmer installed today and still doesn't have 2nd downshift at wot
  15. Just installed my 3.42 gears in my 96 vert.
  16. Numbers on Stock Stall in 96 Z28
  17. Help me pick vig torque converter stall speed for my car
  18. Strange rearend pricing and opinions
  19. can 342's go in a 2 series carrier?
  20. have a question about bringing my car to get a tune for my A4 trans
  21. help m6 tranny problem
  22. Tranny temp gauge
  23. Re: obd1 high rpm issues...
  24. So my tranny blew......
  25. torque converter cover, yes/no?
  26. Transmission change ????????
  27. Transmission problem.
  28. A-4 tranny problems
  29. Differential Cover mods
  30. New Converter: Now Extreme Vibration.
  31. gear or stall 1st?
  32. Clutch pedal soft, What's the problem?
  33. Torque convertor lockup
  34. Stupid plastic cup for shifter part #?
  35. Clutch Going?
  36. T5 Help
  37. New Gear Break In Question
  38. Best Place For Trans Rebuild in NJ
  39. a4 tranny fluid change????
  40. Stall convertors on the Dyno
  41. Gears
  42. I know nothing about auto transmissions...is this any good?
  43. Anyone else have this problem? Please Help!
  44. Gear or Convertor?
  45. Rear Differential Fluid - My Experience
  46. Polyurethane tranny mounts????
  47. whats the best transmission mount to use for my 00 LS1 camaro?
  48. gears affect speedometer
  49. Clutch Issues???
  50. Best rear end for 95 z28
  51. positraction
  52. Over drive wont engage.
  53. thoughts on locking up in the middle of 3rd gear ?
  54. Transmission shift is never consistant
  55. Moser 12 bolt cover gasket, where to get?
  56. Shifter linkage?
  57. rear end axle play.......how much requires repairs?
  58. looking for t56
  59. want to convert
  60. Won't shift 2-3 at WOT
  61. Will 8.2 gears fit 7.625 rears?
  62. Tranny mount???
  63. tranny help, po753 and brown, bubbly fluid
  64. TH350 speedo
  65. oil leak ruining clutch...input shaft seal?
  66. Tranmission Trouble!!!
  67. Any verts with these mods looking for some time slips.?
  68. Flywheel grinding?
  69. 4l60e delayed shifts?
  70. i need help, iam having a hard time installing energy suspension torque arm bushing?
  71. A4 to M6 Conversion. Whats involved?
  72. Bell housing grit and oil seapage? Is this normal at 85000km?
  73. who has 373-4.10 gears that whine-how bad
  74. Transmission noise when standing still
  75. gears install
  76. Moser 12 Bolt
  77. Can I save my tranny?
  78. Used GM 3:73 gear install
  79. Vigilante TC Install???
  80. 4.10 vs 3.73
  81. which tci converter will go well with my 373 gears
  82. should i get it?
  83. Will my rear hold?
  84. What hardware needed to install a new driveshaft???
  85. How do I stop flywheel from turning!
  86. Good driveshaft
  87. Anyone interested in trading a m6 for a4??
  88. Factory backlash specs for 94 Z ring gear?
  89. Clutch Pedal Vibration and others
  90. Rust on lsd
  91. Gear wine
  92. tranny prob
  93. 373 gears seems to have sluggish acceleration when driving
  94. new clutch?
  95. Trans Fluid for a TH400
  96. Who has a Pro-Built 4L60E?
  97. 99'camaro engine swap V6 to V8
  98. vibration when rolling to stop
  99. How much will gears knock off in the 1/4?
  100. Where and how do you adjust the master cylinder on a ST
  101. Drag racing torque convertor and tranny selecting
  102. Need quick help. TCS rear in non TCS car.
  103. BMR torque arm for a Moser 9"
  104. Stock LS1 Rear-End on LT1???
  105. 10 bolt risk and me?
  106. tranny shifting hard, doesn't want to...
  107. bad vibration at higher speeds
  108. cheepest place for gears?
  109. stock 10 bolt vs.12 bolt
  110. Manual lock up switch for Converter??
  111. Did I toast the trans and clutch or just the clutch?
  112. What's your pinion depth and backlash set at?
  113. T56 slave cylinder problem
  114. What does gear whine sound like?
  115. Universal joint for 9"
  116. quick question
  117. Throw out bearing.. making noise.. ???
  118. 3RD Gen rearend-to a 4th Gen car
  119. Transmission Shift Cable
  120. My new Moser 12 bolt has alot of "play" ????
  121. strange 12 bolt questions
  122. Those who have switched from 4l60e to 700r4
  123. where and what 4.11s to get?
  124. Question abotu Stock 10 bolt with 500-600 horsepower??
  125. need to upgrade 4l60e for a FI setup...
  126. Tranny may have went!! Need Help ASAP!!
  127. how much can it handle?
  128. T56 to non computer controlled auto tranny
  129. when changing shift points what aim i looking for?
  130. clutch adjustment
  131. rear end gear ratio
  132. can i use synthetic gear oil in my 2 series carrier?
  133. Spohn Torque Arm problem
  134. i hear a clunking noise when i make a complete stop
  135. Removing Torque Arm.
  136. Will this 2002 rear end work in my car?
  137. Ok got new carrier and 3.42 gears for my 2.73 car..actual observations and opinons.
  138. Pinion Seal Leak
  139. Transmission leak
  140. my rear end...
  141. 400 people inside please
  142. Gear/Stall--> Two part, Help
  143. overdrive ratio in t5
  144. Dead Rear End?
  145. from 2.73's to 3.73's
  146. Converter confusion: higher STR or steeper gears?
  147. I think I put clutch in wrong.
  148. tranny problems
  149. Question about unplugging torque converter ?
  150. t-56 conversion wireing
  151. Axle Size??
  152. First Gear Ratio????
  153. Clutch chatters.... normal???
  154. Possible serious problem with tranny or rear end....need help
  155. 1993 z28 gear change?? Speedo??
  156. Need Help with Freshly Rebuilt A4!!!
  157. rear and posi
  158. How do I pull the axles?
  159. Wierd Sound! :(! Sounds bad
  160. Installing new 12 bolt... couple ?'s
  161. Gears
  162. clutch bleeding technique
  163. 95 Z28 clutch & flywheel Q
  164. 4L60E Convert to M5?
  165. Making t56 stronger...
  166. How much would you pay for a Mustang 8.8 bolt in for your F-body?
  167. Carrier stuck??
  168. Slipping(?) 700R4
  169. Header Install, Tips Welcomed
  170. TCI=bad
  171. TCI pro super kit, opinions?
  172. Help me get my 4L60E out of my car!!!
  173. Weird Jolt
  174. 200-4R install writeups?
  175. 2.73's and a stall
  176. Kickdown to 2nd at 100% TPS going 60mph
  177. Rpms with 3500 stall
  178. What gear brand is best???
  179. 93 lt1 speedo recalibrator
  180. clutch problems
  181. HeAt!! too much of it!
  182. what s the difference in a lt t56 and a ls t56
  183. Reducing shift pressure
  184. Normal Transmission Temps?
  185. does anyone use a shift improver?
  186. th 350 trouble!
  187. Rear Rotor Swap
  188. T56 to TH400 swap, need some help
  189. Annoying!!!
  190. Shifter For 4l60E
  191. Really Hot T-56!
  192. 1310 to 1350 combination/conversion u-joint part numbers
  193. converter tuning?
  194. 4-channel rear swap in 95 TA?
  195. 4L60E swap to th400
  196. where to get ahold of Viper shift fork for my '95 T56
  197. Trying to bleed the clutch..pedal just goes to the floor and stays...
  198. A4 to M5 (Auto to 5 Speed Manual)
  199. I need Tranny Rebiuld Shops & Prices
  200. Poll!!! Swap my auto for a T56?
  201. t56 question, help please
  202. $900 LABOR to install Gears???
  203. Few ?s - Strange & Superior gears
  204. New valve for 4L60E from TCI
  205. 3:42 or 3:73's??
  206. Clutch slave and master
  207. WTB 2 Series 3:73
  208. Highest Quality 3.73 Gear
  209. Clutch problems NEED HELP!!!
  210. Panhard Bar?
  211. Spec stage 3&4 Pressure plates the same?
  212. pilot bearing noise
  213. Brain Fart During Clutch Install..Quick response needed
  214. Will my stock 10 bolt handle 500-600 horsepower??
  215. taking a leak
  216. How many teeth do our flywheels have?
  217. Thinking of a lower gear ratio?
  218. 8.5" from a 96 S10...will it fit?
  219. Axle Upgrade Required for 4.10s?
  220. My transmission is clunking?
  221. free set of 3.42s or pay for 3.73
  222. guys with 8.8 rears in your car inside please
  223. making a 7.5" stronger
  224. What size tail shaft for a TH400 in a 4th gen?
  225. Tranny cooler line size
  226. swapping a TH400 into a 3rd gen
  227. Odd Question
  228. P1870 ... Uhoh, I need suggestions...
  229. What's Umbrella style brakes?
  230. Need new driveshaft
  231. were did this come from?
  232. shift kit install?
  233. Torque convertor problem maybe?
  234. Shift Fermness???!?!
  235. Serious problems, might be rear end?
  236. To Those With Moser 12 Bolts???
  237. ABS light on all the time
  238. Help With a 3 Speed Auto to 5 Speed Stick Tranny Swap in '80 Z28...
  239. Hurst or B&M???
  240. Stall converter range?
  241. starting problem
  242. synthetic tranny fluid
  243. How did this happen?!?
  244. Can You Convert To 4ch. ABS???
  245. tranny mount?
  246. dumb question, are all LS1 camaros and trans am come with posi?
  247. Whats the going rate to have a T56 Rebuilt?
  248. 1st impressions of spec stage 4
  249. skip shift light
  250. shifting question
