View Full Version : Drivetrain
- '94 Camaro Z28 Automatic
- 1995 M6 Clutch issue
- 93 a4 lt1 hits limiter when downshifting
- best rearend gear?
- 95 popping out of reverse?
- T56 noise normal?
- ??? on a A4 to M6 swap
- Pressure plate & Flywheel
- Dumb question - tranny overfill
- anyone ever used a Vette 700r4 in a Camaro or T/A?
- Replace 93 6 speed with 94-02 6 speed?
- easy question
- tailshaft play auto tranny
- Auto tranny shudder issues??
- tire/axle help
- Sounds like firecrackers in my transmission!
- T56 swap question
- T56 Swap and the car wont Startttt HELP
- Clutch Bleeding, Clutch adjustment, etc.
- 96Z engine/trans into 94Z
- Clutch line discontect good or bad?
- A Clunk
- 94 LT1 4L60E slipping badly
- removal of tranny, please help!
- My "Little" rear end....
- replacing clutch
- V6 and V8 rear end any difference?
- PerformaBuilt Holiday Give away is back SEE INSIDE!
- trying to change hurst shifter stick
- ABS sensor for Strange 12 bolts
- RTV Sealent/12 Bolt confusion
- skip-shift wont let me down shift
- help!
- clutch help
- 94 lt1 auto trans
- Driveshaft alignment?
- FlyWheel + pressure plate Torque Specs for an LT1
- I Hope it's not the Tranny
- Manufacturing defect on McCleod scatter shield...
- Clutch Problem
- Can't get into reverse - It seems to have disappeared?
- Transmission Leak problems
- '95 4L60E - problems in 1st gear only
- Auto shift problems
- any damage on over torquing rod bolts
- Bleeding clutch, but with a catch..
- F1 Clutch And flywheel Stage 2 Installed.
- Transmission help.
- Elusive eighth check valve
- ring and pinion
- Rebuilding the Pro 5.0 Shifter?
- rear end swap 96 into 98
- 1994 LT1 PCM to control 1993 Pickup 4L60E?
- Occasional rear end knocking...help
- Strange Engineering
- Clutch for boltons plus S-Trim on stock Lt1
- 12 bolt or 9 " driveshaft question
- 96 z28 shift problem
- Need some professional opinions.
- 383 lt1 a4 to m6 swap
- Installing a Spec Stage 3 Clutch Tomorrow
- M6 to a4 swap
- Oops!!!
- car isn't shifting into 4th.
- 93 Camaro T56 clutch master stroke
- 4.10 gears
- Ford 9" vs OE GM Rear End
- Bought a used T56 and a new SPEC Stage 4 clutch..
- 93 T56 clutch slave cylinder adapter fitting help?
- Rebuilding 700-r4
- t56 to 5 speed swap
- Did I blow my clutch master?
- what crossmemeber for 700R4 into 97 camaro SS
- servo question
- my LT1 t56 has a tremec stamp...
- t56 tranny no second
- 4L60E trans shudder crossing 80mph only
- LT1 t56 thinking to go 3.23
- I need help on rearend decission
- Factory Hurst Shifter
- rebuilt tranny
- help!
- is this a problem?!
- Could someone recomend me a clutch for my application?
- slap shift
- Need help- Swaping a intercepter caprices 96 4l60e trannie to my 97 z28 30th aniv..
- New SFI approved LT1 Blastcan (Bellhousing)
- tranny leak
- Bleeding the slave cylinder
- Vibration at 50mph in third gear in A4
- T56 was STUCK in gear, now working w/o issue - why?
- trans cooler kit
- 1996 vette ZF -speed
- 94 formula a4 1st gear block?
- is this a good torque coverter?
- thorson-gleeson reat end noise in 02
- shifter
- Drivetrain making noises
- 700r4 transmission
- Drivetrain gears
- LT1 T56 stock flywheel question
- ungodly noises
- 95 Z28 Clutch Problem
- 1967 camaro with turbo400
- Slipping on 3-2
- 3.73 gears for 2002 Z28 A4
- 95 auto not shifting up correctly
- transmission swap. 94 t5 in 86 iroc z auto
- Loud Bang/Knock on acceleration or downshift
- Auto Tranny
- 02 auto with 31K miles... dead?
- ring and pinion swap with ABS
- Ring pinion trouble...need help bad
- Rebuild my T56 myself or send it off?
- Tranny problems? I'm stumped
- 12 bolts Posi limited slip additive question
- Tranny Rebuild- Performace
- first post need help 1995 Manual Trans wont go into reverse
- Transmission wont shift in to 2nd unless i back off the gas gas
- Lt1 vette clutch same as lt1 camaro?
- Car won't shift at or near WOT
- part # to rebuilt Mc Leod Master cylinder ?
- slipping 4l60e..help!
- Rear Axel Strength
- stall recommendation
- t56 swap question
- adjustable master bad adjustment causing slipping clutch?
- Bleeding slave cylinder
- 4l60E issues
- Transmission issue... please help
- difference between a 1995 t56 and a 2001 t56?
- shifter cable
- question about rearend gearing
- Replace short block / engine in 95 z28
- 3.73's or 4.10's For my 10 Bolt M6 Z28 (NOT a DD or Highway Car - About 400RWHP)
- HARD Clutch To Drive! (Adjustments??)
- Aluminum driveshaft for street/strip car
- Clunking Trans? Under 30 MPH WOT
- 4L60E drops out of 4th
- Traction Control Retrofit
- What clutch should I Buy???
- ProKing Converters
- 4 speed auto to 6 speed manual
- driveshaft problems
- Help: Transmission stuck on motor.
- Considering going auto and have a few questions
- vig 3600 conv ?
- seriously considering a t-56 swap
- 4L60E raped by previous owner
- 1998 LS1 w/ LS7 Clutch?
- Clutch, Flywheel or both?
- 94 Camaro clutch fork bottoms on pressure plate.....HELP!!!
- How do you.........
- Factory Rear end is leaking
- rearend/tranny questions
- clutch dragging
- 4L60E VSS Reluctor Ring Question
- 94 auto Z slips/revs between 1-2
- What is this horrible noise? (Vid included)
- 4L60E problems
- Who sells "Lou's short stick" shift levers for the PRO 5.0 Shifters?
- time for a CLUTCH
- What side of the clutch disc goes towards the transmission?
- 94 and 96 auto the same
- changed rear gear to 390 now my trans is slipping in 3rd and OD!
- rear end
- Driveshaft recommendation
- performabuilt end of month 1 day only sale till midnight tonight 100 off!
- 1993 Z28 4L60 to 6 Speed
- Pwm?
- strange vibration on decel
- who has pedals, or info for and LT1 six speed swap??
- Keep the convertor?
- Gear install problem
- 99 4L60E solenoid hell
- Is it bad to shift into neutral without the clutch?
- M6 Install
- Brand new rebuilt transmission not shifting
- Turbo 400 trans in 95 lt1 camaro
- please help!! clutch bleeding issues!!
- T56 woes. Need help!
- Poly Trans Mount
- Another one bites the dust...
- 4L60E Problem
- rear axle end play
- Eaton G80 code posi
- Can T56 be removed without bell housing?
- What fluid in a Dana 60?
- ok so is there a big difference between 3.42 and 3.73??
- Major trans leak with a twist
- Keep the stall or not - opinions please.
- 350 or lt1 and t-5 for roadracing
- Transmission pops out of first gear
- 4L60E Won't pull, could be convertor?
- Mccleod twin disk problem
- SLP Take off Carrier Is it 2 series or 3??
- clutch travel
- 1996 Z28 Camaro manual wont go into forward gears on shifter on or off
- 9" rearend noise- deacceleration
- Cleaning Transmission?
- LT1 clutch slippage causes?
- McLeod Bellhousing Owners Step Inside
- Feedback on a Fidanza flywheel and best bang for my buck clutch?
- Those of you with High stalls i need your input
- Yank Converter
- howling in rear end
- Checking & Changing Trans Fluid
- 94 z28 peformabuilt 4L60E TC slip
- 4l60e conversion to th700r4
- what the best gear for my money
- Can't shift into reverse
- what 700r4 trans to get
- what is overdrive for?
- 4L60E self-destruction (pics)
- I need a part number for clutch hydrolics...
- Not shifting from 2 to 3 after turbo/tuning attempt
- No HP
- Pressure Plate Balance ?
- Flywheel
- LT1 4L60E to T-56 Questions
- T-56 stuck in 4th gear?
- Need to fix 7-5/8" 10-bolt Cheap (meaning Redneck Scabjob)
- solinode
- Shifter Differences
- Replacing throwout bearing
- th 350 question
- 4L60E install
- A4 to M6 swap, won't go into gear while running
- could u swap a 5 speed transmission i have a 98 6 speed
- Clutch Issue???
- Gears
- trans fluid change when installin tq and shift kit
- Which clutch for a Bolt on street car?
- driveshaft for Strange 12 bolts ?
- th400 or 4l60e
- tranny builders
- Bolt on weight
- Clutch noise, now starting problems.
- WSS/AC Voltage
- wont shift
- Where's the Clutch Inspection Plate located?
- Transmission
- rear tranny seal - viper spec
- A Head Scratcher (LS1 M6)
- Where to buy LT4 clutch
- Video: Any idea whats wrong??
- Pulling the Trans
- What Clutch
- '98 4L60E in a 1997 - can it be done? What parts?
- 94 Z28 Auto Transmission Flush Question
