rear end help
Old Feb 26, 2005 | 04:18 PM
94camaro3.4's Avatar
rear end help
i have a 94 camaro STOCK model non posi and want to put a posi rear in my car the posi i have has 2.73 gears can i pull my axels and gears out of mine and put the new gears in my rear
any help would be great
Old Feb 27, 2005 | 10:15 PM
92RS305#2's Avatar
Re: rear end help
you should be able to fit your ring gear on that posi unit, but if the posi carrier is too small i know they make spacer adapters that will make your bigger ring work with the smaller carrier. just remember that you'll need a press to get on the side bearings and ring gear so don't bang on the side gears or try to pull up the ring gear with the ring gear bolts.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
