PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Open diff or LSD?
  2. street manners with light alum flywheel
  3. Street Twin clutch alignment
  4. New Clutch Sticks Like Old One
  5. Tranny problem or computer related??
  6. What do you guys think of this homemade tranny mount option?
  7. Stock 10 bolt strength
  8. tranny probs need some advice Quick???
  9. M28 internals?
  10. Clutch problems, have a few questions.
  11. Need Help With Torque Converter....
  12. Pic of 4l60e?
  13. For those looking to buy a ST.....
  14. a little help regarding slave cylinder
  15. Quick Axle Question
  16. Noise in back when turning... brakes? differential? lsd additive?
  17. what tools for ring gear swap, dial ind. question 2
  18. Moser v. Strange, 12 bolt v. 9-inch...
  19. what do i need in order to change gears in my moser 12 bolt?
  20. t56 question
  21. Stock rear whines..
  22. street twin too aggressive for a relatively stock car?
  23. 4:11's for 7.5 10 bolt?
  24. highway driving bad for clutch break in?
  25. Pressure plate bolt question
  26. Stall speed question
  27. what built internals for a t-56?
  28. do you have to buy an adjustable master cylinder with new clutch?
  29. are the problems resolved with the spec stage 3 clutch?
  30. is the slp clutch and billet steel flywheel as good or better than spec &street twin
  31. please help me with my clutch woes
  32. transmission question
  33. Gears now or save up for 12 bolt?
  34. rearend build
  35. looking for new 3.73's for a 2 series
  36. where to buy a 12bolt or 9 inch from...
  37. LS1 clutch install...hell continuation
  38. problems with shifter
  39. Need some answers about rebuilding my 700
  40. Which brand of gears do I use?
  41. 700r4 in a 91?'s
  42. rear diff upgrade
  43. umi short stick?
  44. bleed the system after slave cyl install?
  45. what series rearend do I have?
  46. Special tools?
  47. ringear spacer do they have them
  48. what gears to buy
  49. Clutch Change Without Resurfacing Flywheel
  50. limited slip rebuild
  51. Sun shell failed - total failure imminent?
  52. want a 12 bolt
  53. driveshaft rpm
  54. LS1 tranny mount nut
  55. Shift issues
  56. In the market for a new stall
  57. TransGo Problem
  58. A4 shifts too hard.
  59. AC Delco clutch or aftermarket???
  60. Changing clutch...and flywheel???
  61. broken peice
  62. Tranny Experts Please Help, Fresh A4 Rebuild developing problems?
  63. flywheel
  64. TRADE my A4 for your T56, i need T56
  65. Can't find .012 flywheel shim
  66. line for the "drill mod"?
  67. how to remove pressure plate bolts??
  68. Tranny won't enguage--any ideas?????
  69. Add a shift kit?
  70. Synthetic ATF?
  71. alumn flywheel ....bad idle?
  72. Ok, I need to make some plans for my converter install..
  73. roomate touched clutch...brake cleaner fine?
  74. Put a new tranny in and installed old clutch.. Chatter Problems..
  75. Adding transcooler
  76. Could a little undertorque of pp bolts ruin a clutch?
  77. Clutch wont disenguage
  78. tranny bad?
  79. Question on 9 inch
  80. Clutch Pedal Vibrating Horribly After Clutch Install! Help!
  81. Which of these clutches is best?
  82. Cant get the driveshaft off my LT1
  83. Where to get flywheel shims from?
  84. ???
  85. 4l60e swap 4 t56
  86. Non-Synchronized 1st Gear - why?
  87. Are Richmond gears stronger?
  88. guys i need your opinion !!!!!
  89. RPO codes for rear end gearing
  90. Torque Converter Install: What to buy?
  91. Are 4l60e and 700r4 valve bodies exchangable
  92. Tranny experts...i need a diagnosis
  93. Flexplate for LT1/th400
  94. Tranny or clutch..which is bad????
  95. mcleod disk replacement
  96. m6 trans....any good rebuilder? $$??
  97. probuilt tranny
  98. Which is better Eaton or Auburn?
  99. Got flywheel resurfaced... is it supposed to be smooth?
  100. Strange price increase coming soon!
  101. What Gear Ratio To Use
  102. t 56 rebuild
  103. hp gains (or non-loss) from lightweight flywheel?
  104. removing trans in driveway....how did you guys do it?
  105. Where to find stock flywheel?
  106. Is this flywheel usable?
  107. Gear pattern on the heel- shim estimate?
  108. replacing thrust bearing
  109. possible bad torque converter?
  110. Which gears?
  111. who sells precision gears?
  112. Which tranny would be best for 600+ rwhp?
  113. LS1 Trans Mount on LT1
  114. LS1 Tranny mount on LT1
  115. 4:10 gears to much??
  116. Clutch slipping - what's the least I can spend to fix?
  117. simple question , master cylinder line
  118. Accurate trans temp readings from inspection port?
  119. Car pops out of gear.. or DID pop out..
  120. 4l60e gurus questions
  121. gears
  122. Mcleod install ?'s
  123. Clutch fried or just needs adjustment ???
  124. How much HP can a CF drive shaft take?
  125. Big problem, i think with the driveshaft.. Need help
  126. Eaton differentials
  127. stall question...
  128. Tranny help??
  129. Hesitation after replacing pilot bushing?
  130. What type of lube for pilot bushing?
  131. best tranny cooler?
  132. Would my TCI 3000 stall cause a PO751 code?
  133. What STR for daily driver?
  134. Rear End Might Be Loose
  135. dana 44 in a 3rd gen?????help asap
  136. Clicking noise out of rear end
  137. Clutch safety switch backwards?
  138. Could a bad clutch cause vibration...
  139. cheapest flywheel??
  140. B&M Ripper + D&D Tranny
  141. Motor and Tranny Mounts...
  142. Rear end checking out?
  143. New Clutch
  144. Energy Suspension Polyurethane Tranny Mount Installed
  145. Strange TCC Readings........?
  146. Gear swap ???s
  147. convertor to flywheel bolts
  148. LT-1 M6 into LS-1 Qs???
  149. Will a Z06 clutch and flywheel fit an LT1?
  150. brownish tranny?
  151. Suggestions for a 6spd shifter?
  152. HELP! Wierd rattle from trans!
  153. 400
  154. Putting together a 12bolt, what else do i need?
  155. Rear axel bearing replacement on a Z28 1999
  156. need some quick solid info. rear from 93 to 97..
  157. Wierd rattle coming from transmission?!?!
  158. Disadvantages of aluminum flywheel?
  159. 700R4 Planetaries?
  160. are all 4L60E's the same?
  161. 2 series vs 3 series carrier
  162. car pulls to the right
  163. My Tranny is Squeeling (A4)
  164. Tranny dont kick down
  165. T-56 is BAD?
  166. SLP ds loop w/ oversize ds?
  167. stuck bolt in steering rack
  168. Anyone having a sale on rears right now
  169. difference between spec 2 and 3
  170. is a 94 LT1 z28 4l60e same as 97 z28 lt1 4l60e
  171. Problem with trans at WOT
  172. knock in the rear
  173. Clutch out of adjustment
  174. DOT3/4 Valvoline vs. The White Bottle (DOT3)
  175. wolf drag race swaybar?
  176. t56 to th400 swap??'s
  177. Need help on choosing Converter
  178. Transmission Pan bolts??
  179. gm limited slip additive
  180. What clutch do ls1's have?
  181. Whats missing? T56 question
  182. For those who did the 6 speed conversion. Pedal question.
  183. LS1 rear in aLT1?
  184. Only 1 tire going bald!!
  185. What to do with comp for A4 to M6
  186. T5 into LT1
  187. Rear end question
  188. McLeod [screwed] Up w/ Street Twin Recent Buyers Inside!!
  189. Best Drag Racing Posi???
  190. Brand new posi broke!
  191. Trans Conversion
  192. Where to find clutch alignment tool?
  193. Best clutch and alum flywheel combo for 500hp
  194. Spools
  195. Pinion Yoke size
  196. Limited slip additive, is it needed with Royal Purple?
  197. Need info on putting a 350 turbo into 94 Z28.
  198. T56 Trans problems
  199. Rear End / Tranny Fluid
  200. Are these the same...Transgo shiftkits?
  201. 1st or not
  202. Rear End ???
  203. replacing u joints
  204. 1st thread! Transmission problem! I need your help!
  205. transmission doesnt shift into any gear!!!!
  206. Damage from driving with spare on rear?
  207. m6 conversion problem
  208. stock vs Yank PY3400E converter
  209. Keep cooking clutch fluid? Whats up?
  210. Need a new clutch
  211. Will a V6 A4 swap onto a LT1?
  212. A4 Flush and Refill...
  213. t56 to th350 conversion-having flywheel/starter issues
  214. 3-4 steel clutch fork install, is it easy or should I leave it to a shop to install
  215. Good converter for me Help please
  216. got transmission serviced now shifts like mush
  217. spec stage 3
  218. for all you with 12 bolts.. I have the cash, but where is th best place to buy?
  219. Differential/Rear End fluid changing?
  220. how aggressive of a clutch with a 10 bolt with 4.10s take?
  221. Torque Converter Install!!! What Will it feel like??
  222. What clutch should i get?
  223. issues using studs on block to bellhousing bolt holes?
  224. 4L60E going south... Rebuild? Or M6 swap?
  225. viper clutch fork
  226. Spec Flywheel
  227. same old problem same old trans...
  228. I'm going to try to put new gears in my 99 m6
  229. What is better about 88' and up 700r4's?
  230. This sticker was on my 700r4 i just got....
  231. T56 transmission on dragstrip: Is a scattershield necessary?
  232. m6 Hard to Shift
  233. pro 5.0 installation
  234. tranny limp mode no codes
  235. 4:10 Gears with a T56
  236. What stall and gears this summer??
  237. Need help with a vibration problem.
  238. Driveshaft Help
  239. Spec clutch disk material??
  240. tranmission swap question
  241. Anyone using a TCI SFI tranny shield?
  242. Please help Transmisson Acting up ??
  243. will non lock up converter fit on lockup tranny?
  244. Reccomend A Fluid For My Tranny?
  245. LT1, A4 to M6 questions
  246. Midwest 3200 stall?
  247. A few questions about the 700R4
  248. Dropped my tranny - am I screwed?
  249. can't get m6 to fully seperate from motor
  250. torque arm relocation bracket
