View Full Version : Drivetrain
- yank ss3200 or ss3600?
- what parts do i need to fix no 2nd or 4th
- Messed up, 4L60e!
- Offset axle bearing leaking - Time for new shafts. Is this the correct parts?
- Trans cooler lines
- Cooling System
- 4L60E noises
- torque converter
- P0740 (no symptoms help)
- Rear Posi from 2000 WS6 TA compatibility
- speedometer
- not shifting
- 4l60e/PCM problems?
- 1995 4l60e valvebody
- 4L60E lost overdrive?
- Gears!!
- stall parts list
- Throughout bearing
- 1979 355 with 3.08 open rear
- Dip Stick Spurts Oil
- 4l80e cold 1-2 shift problems P0502
- Need some quick clarification
- transmission shudder? misfire?
- What should my pinion angle be set at?
- Won't downshift
- Engine Swap
- Part name
- new motor mounts and headers, now noise
- Pilot Bushing
- Trans removal help
- Sounds like a bad bearing
- T56 now shifts 'weird' from 2nd to 3rd...
- 4l60e to t56 swap 94 z28. Need hydraulic system
- clutch missing a puck
- Torque Converter Install Guide
- 4l60e limo mode
- Steel to aluminum driveshaft!!
- t56 rebuild kit help
- Replacing Automatic Shifter
- 4l60 skipping 2nd only?
- WOT = no Overdrive anymore?
- 4l60e 2nd and 4th gone?
- Not shifting from 1st on its own, speedometer acting up occasionally
- 97 Lt1 T56 to TH400 help
- Trans problem not sure what it is
- New shifter ?
- 4l60e or t56
- Gear drive whine from below the car.
- transmission shift problem
- pro 5.0 shifter
- Need a Little Tranny Information Please
- '95 z28 transmission help
- no drive gears only reverse??
- shift problems
- 1995 Z28 M6 New clutch going in
- Bad torque converter?
- Freakin' Out a Bit (Transmission Fine?)
- 99 a4 stock gears
- 1996 camaro z28 6spd clutch fork problems
- Z28
- question trans mount
- Differential check
- 94Z T56 wont go into Reverse
- C-Clip Eliminators with factory disc brakes?
- Issue shifting from 1st to 2nd
- 4L60E grinding or Pinion/Ring Gear Grind
- 94 Z Limp Mode ?
- rearend help
- Shift Kit ?'s
- 700R4 Tranny Swap in My 1979 Z28
- Can 4l60e tailshaft bushing be replaced by itself?
- Performabuilt holiday giveaway is back see inside
- Gears
- Major vibration trying to pinpoint.
- TH350 Adjusting Shifter - Need help
- Torsen vs Auburn???
- I need a T-56
- Need help with the 4L60E
- 96 axle into 94
- 4L60E Help
- t56 cost
- In need of some help and advise???
- Tony's T-56 Reverse fix
- Is Ram's aluminum flywheel right for me?
- T56 grinding
- T56 Removal Issue
- transmission compatabilty
- Should i stake my pwm valve?
- How much fluid does a t56 transmission take/need?
- Axle clunking
- removing reluctor ring ??..
- Need help identifying 2 parts, seals.....
- I read the write up on unblocking 1st gear
- Rear end question
- Torque converter question
- ring and pinion
- Stuff this Ford 9" under my 95 Z28?
- 4l60e year compatability
- Clutch Reccomendations
- Tiny little piece in U-joint... what did i break?
- trans slip under WOT?
- trans shifting problem.
- My DIY Low Budget GM 8.5 Build (using 2nd gen fbody rear)
- Issues With My Transmition?
- I have a question??
- Lt1 clutch recommendations
- 98 v6 firebird A4 vibrates at a stop, in park or Neutral
- Fluid line broke going into 81 Firebird Tranny
- One tire fire
- Transmision Going Bad
- How to properly tow my Camaro?
- building 2 gen 8.5 10 bolt with 4 gen axle tubes have questions
- Clicking in rear end.
- Smoke from shifter?
- Braided line conversion
- 1986 I roc rearend
- Lt1 swap to an LS3, stay m6 or switch to auto
- these the right wheel bearings?
- T-56 Transmission Fluid?
- tranny compatability
- Rear end noise
- SLP shifter ?
- 3k stall with 3.73 or 3.42
- cracked bell housing
- Rebuild trans
- Rev limiter
- which street gear for daily driver
- 1996 camaro transmission problem?
- what do i have on pos traction
- 7.5" traction control posi into a regular housing?
- stall & gears 4 street car only?
- Clutch Problem??
- Hitting my rev limiter?
- whats a good manuel for rebulding 4l60e tranny
- Help figuring out rear end
- Bad auto tranny??
- Unhooking BTSI doesn't help
- Whats a good do it urself rebuild kit for 94 4l60e?
- PNP Switch
- Help with torque converter.
- 4l60e
- rear popping/binding noise
- Which rebuild kit???? help
- what's this part called
- 82 Z tranny questions
- Torque arm install tips
- 98 3 channel rear into a 97
- Spec PP with other brand clutch disk??
- 1994 Z28 Modded LT1 Shifting Problems
- Question removing 4l60e from 2002 z28
- budget rear end
- gear ratio for street and drag strip help?
- 1994 z28 tranny problems
- LT1 vs LS1 4 Channel Rears
- LT1 T56 Transmission Mount?
- torque converter
- 90 IROC idles fine, kills when put into gear and given the gas
- Hitting a wall with reverse and 1st
- Differential question
- rebuilt Trans no forward
- trans slips at WOT but shifts ok otherwise ?
- 4L60E Transmision Problem 3 and 4th
- 3/4 syncro keys broke what to do now?
- 94 Camaro Z28 6 speed swap (need help)
- transmission help
- PerFormaBuilt MayDay SPECIAL
- New rear end
- Clutch Wont Disenguage After Winter Storage But Petal Feels Perfect.
- 4l60E question
- New gear
- cracked piston
- RPM, Jakes, or Performabuild
- 2500 stall ?
- kickdown cable maby?
- Need help with tranny removal
- Shifter Options: 97 SS 6-spd w/Hurst
- 1978 camaro
- tranny cooler lines.
- rear end weight
- McLeod Street Twin Issues pedal changes
- 4L60E, no 2nd or fourth
- Swapped to Stranos/Bilsteins and Fresh 10 Bolt
- Transmission Shift Cable Replacement
- Rear end
- probably can't help
- HELP... 94 A4 to M6 conversion.... with a twist lol
- 6 speed manual shifter thread size
- 1995 z28 motor swap
- Announcing PerformaBuilt Transmissions “Spring break/Easter Holiday Sale”
- CLUTCH GONE AGAIN (i was on my 4th)
- Mcleod twin vs stock assembly weight LT1
- 4l60e valve body
- Rear End Gear Oil?
- Trans swap
- 2000 Z28 AT shifting to higher gears around 1500 rpm, 25 mph ugh!
- 6 Speed
- transmission lines
- help with rear end swap!!!!!!!!!
- Chirping
- Trans swap questions!
- Newbie
- Another transmission problem!
- I have no overdrive in my 94 cam
- New working relationship with FTI Converters
- 99Z M6 to TH400 Conversion - Step by Step
- Will a700r out of a 89 2wd pick up fit in a 94 lt1 camero?
- McLeod Street Twin LT1 ?'s
- Questions for the Transmission Builders
- 1983 Z28 camaro
- 80Z28 th350C
- 4L60E slow to downshift
- Flywheel recommendations?
- 1995 automatic trans "clicking" sound.
- Removing trans on a 97 3.8 with a 5 speed ??????
- Throwout bearing - NEED HELP PLEASE!
- 4L60E Never seems to "fully" engage converter/trans problem?
- Transmission cooler line leak.
- 94 z28 1-2 WOT shift. Misc. probs.
- which Trans can I use
- Bad transmission? if so...
- BadAss t56 setup for lsx crate motor
- Moser or Strange center section noise 9"
- removing 4l60e
- 2002 Z28 Transmission Issue, Maybe?
- Proper pinion seal for KTRE 12-bolt?
- want to swap a lq9 into my 94 z28 questions
- what is this
- Front ABS Sensor Location/Transmission Shift Points
- 4l60e 3/4 clutches
- 6 speed conversion
- A4 Not shifting at wide open throttle
- Stage 2 A4 Having Issues Please Help!
- 93 z28 with 4l60 not the 700 or e
- 1994 Camaro 4L60E goes neutral in 3rd
- need Torque arm replacement recommendations
- Broken ring gear
- rear axle removal
- 4l60e 3/4 clutch pack
- i need a slip yoke???
- Whining Problems 4l60e
- One day only performabuilt 12/12/12 sale
- 4l60e or 700r4 ?????
- 7-5/8" Rear Interchange Questions
- 94z28 wont shift out of 1st
- Anyone tried Bahnhof (eBay) clutches?
- 4l60e problems
- New tranny dumping clutch fibers and clogging filter.
- new ACDELCO Clutch set not made by Valeo any longer?
- Clutch pedal vs. slave travel for custom setup
- lot of play in my steering
