View Full Version : Drivetrain
- 5 speed
- Is this Normal?
- SFI bellhousing for LT1
- Which clutch for 500+rwhp
- need new shift boot....gm part number?
- Wont Shift Above 4 Grand
- Ford AOD behind a GM?
- Gears
- Faulty slave cylinder?
- I live in boston Local good Transmission shops??
- lt1 pressure plate bolts arp?
- Prothane vs Polyurthane??? Tranny Mount
- Axle bearings
- torque converters?
- help! separating t56 from bellhousing?
- Quick Question
- 96, pretty stock, should I get 4.10's?
- How can you tell if you have an Aluminum Driveshaft?
- Time for a new Trans Mount or U-Joint?
- Need pilot bearing part number, lt4 throw out number
- question...
- Shifter for 01 SS
- ok im an idiot...help asap
- Dana 60?
- Replace gear or whole ten bolt?
- what parts are interchangeable
- Transmission Help
- 9 inch vibrations!
- T-56 Swap, M6 wiring harness, M6 flash, question withing on reverse lights
- 98 vs 99 up positraction
- 94 v6 10 bolt posi for 92 camaro?
- More T56 Problems
- Got a slippery A4 shifter? Check your cable bolts!
- Whine from rear only when turning
- Valve body check balls.
- 9" or 12 bolt
- Need Bellhousing TQ specs...
- shifting issue
- Hurst shifter notchy/hard to change gears
- I think a local paint shop messed up my tranny
- posi rebuild
- anyone ever use Zoom
- Ripper shifter Working, and then Not Working
- What all is involved in upgrading my T-56 to the Viper internals?
- Button on auto shifter stuck!
- will never buy Spec again
- 4.10s on a daily driver?
- I need some help with choosing a clutch setup...
- I'm at a loss (vibration)
- Strange 12 Bolt questions
- 700R4 transmission issues
- torque converter help
- Transmission mount
- wont shift at wot.. 1-2 and 2-3.. how hard to clean valve body?
- 1987 2.8L Tranny (empty and possibly broken)
- One wheel of fury
- Strange S60 diffs
- clunking noise out of the clutch after removal
- T56 3,4,5,6 synchros shot-Q's
- Thinking about a torque converter..
- Anyone running a HAYS CLUTCH DISK?
- Broken T56 Mainshaft
- Any sponsor
- tranny help
- 84 z28 rear
- What gears do i have?
- tranny help
- Will an adjustable master create more seperation?
- what is the best clutch for a trans am pushing 550 hp?
- Do Not Buy A Mc Cleod Clutch!!!!!!
- Little knock in 1st and 2nd.
- possible true trac problems
- 4L60E [issues]
- HELP A4 problems! :-(
- shifter
- Just installed 4:10s: Excessive whine when turning: plz HELP!
- is it ok to run redline atf
- Replacing all the clutch hydraulics..master cylinder?
- Do I have a broken trans? 4l60e
- front driveshaft u joint (Silverado)
- 6 speed and 5 speed ?
- Driveshaft compatibility.
- 10 bolt holding 400 hp + spray
- Problems getting T56 into Mcleod ST
- trans problems
- stall/tranny cooler question
- Trans
- gap where axle meets rearend
- Kind of weird T56 problem
- auto and M6 driveshafts
- 700r4 wont shift from 2-3 at wot???please help..
- Shifter questions
- Help looking for a 700R4.
- Won't roll backwards
- Common GM and Dana differential ID
- New High-Efficiency TCI Converters!
- 8 bolt rear end
- when you guys do a auto to 6 spd swap
- Tranny cooler lines popping off
- Torque converter problems
- upgraded 3rd clutch apply piston
- Eaton Posi Units
- Rear End Noise
- T56 adapter plate question (tranny rebuilders)
- Possible Trans Problems.
- Transmission pan bolts help?
- tranny got hot
- 3.73 gears
- T56 Reverse Lights issue. Internal tranny ?
- Street Twin question about "Special Internal Balancing"
- rear axle
- Got something causing noise in the drivetrain...
- 4l60E to 700r4 convers.
- Weird rattle
- Moser axle wheel studs
- Just Finished Spec 3 Install
- Determining LS1 from LT1 T56 input shafts
- Which to build, 2 series or 3 series? I have both!
- Annoying driveline vibration
- rear gets tight
- 700r4 shift kit help
- SLP Traction Control Module for 1997
- A4 dynos #s higher in 3rd than in 2nd??
- Stage 5 clutch
- A4 or T56?
- Cheap flywheel.
- stripped threads on the short shifter mounting plate
- Good old gear question
- 700R4 Good or not?
- manuel shifting a auto
- Detroit vs spool
- jerky trans
- something is messed up
- Rear whining...
- 4l60e in a 93 fbody
- TCC problem
- LS1 T56 conversion to LT1 T56 (trans, not car)
- Clutch thump noise
- Torque Specs on Pressure Plate
- 4L60E 4 pinon gear question
- 700r4/th350 swap in a 3rd gen?!
- Anybody ever heard of "RPM Transmissions"?
- Put fresh rebuilt T56 in 2nd gear, now its stuck!
- Posi starting to fail?
- car running...skip shift solenoid
- car shudders....
- TH400 and VSS...please read
- Car jerks when put into gear?
- Street twin floater adjustment
- Transmission slipping, trying fluid and filter change
- 10 bolt, 12 bolt, 9inch, Dana
- Long black tube coming off top of tranny
- reverse lockout
- What tranny?
- Bottomed out and cracked my B&M Tranny pan...my car isn't lowered
- Converter problem or what.
- Clutch Pedal?
- Torque Converter lockup problem
- Rear End Noise
- Suddenly difficult to get M6 in reverse
- D or [D]
- weird 1-2 shift, 700r4
- LT1-6Speed trany prob
- 95 lt1 tranny line question
- Question about replacement Auburn differential
- Rear end rebuild parts?
- How i removed the pilot bushing
- 1998 trans am tranny problem
- Can you rebuild the stock 10 bolt differential from a 1994 Z28??
- 2 series to 3 series easiest swap
- Mcleod Twin Disk Question
- issues downshifting from 5th to 6th...
- ??? Few Stall Questions:
- Clutch mileage?
- spec clutch issues
- 4 bolts on moser tq arm mount?
- Top end with 3.73
- Help! 200R4 question.
- TB effect tranny shiftpoints?
- so im thinking of going fuddle.
- How to tell if a car has a shift kit versus a slipping bad trans?
- Where to get gears
- To stall or not to stall?
- reverse trouble
- Moser 12 bolt and brake block.
- How much should axle pull in and out?
- Energy Suspension Tranny Mount Problem
- Rattle!!
- tci 700r4
- 4l60e or t56 conv?
- ?s shortening the rear.
- It ONLY shifts DOWN!!!!
- ring gear was loose...why?
- I hope its not my transmission
- torque converter bolts??
- Recommendation: Jennings Race Performance for T56 rebuilds
- How loud are the new Dana 60's?
- 4.10's going in, what type of tuning on a 93?
- 450 miles enough--clutch break in???
- who makes good stalls?
- another trany question
- Anyone have Vigilante redo there stall or rebuild there converter?
- Max 60' time for a 10 bolt 3:42 factory rear?
- Transmission and rear ??s
- 94/95 4L60E Parts Swap
- Help
- Anyone rebuild TH350's? Couple questions and pics inside...
- 6-Speed noise
- popping out of gear
- Are Richmond gears louder than Motives?
- tranny won't shift at wot..
- Anyone with Trans temp gauge
- looking for a NEW performance trans
- moser 9 inch torque arm help?
- Dtc P1870
- Transbrake For 4l60-e. Are They Available?
- Redneck Performance
- How is everyones strange dana 60 holding up?
- Anybody know the name of this part?
- Over 4000 RPM Vibration (Driveshaft?)
- transmission banging - not tranny mount
- Crossmember bolts ??!?
- Bad shifting problem in A4
- 3 speed people..simple question
- diff between true trac and detroit locker??
- My Transmission Acting Strange
- Got in new gears, one is chipped! problem?
- 3.73's for a series 2 carrier
- Rear end noise
- Exact cause of the T56 low RPM growl???
- 4L60E lost all gears
- transmission swap
- T56 Shift arm reattachment
- Is there a "quick change" or Nascar rear end.
- CPT.Transmissions good or bad????
- Replacing Axle Shaft
- shift kit stopped working???
- built tranny, new program??
- 4L60e fluid flush, filter, and refill--prices?
- Question about deeper oil/tranny pans
- clutch actuator
- Just installed my B&M shift kit
- Strange clicking noise fro new tranny.
- Tranny acting weird
- Recommend a TC manufacturer.
- 3rd gen rear / 4th gen rear
- 4l60e Blues
- Is a turbo 350 Short Shaft Lighter Than a 4L60E?
