View Full Version : Drivetrain
- Gear swap
- Power program?
- whats next?
- 383 stroker Transmissions problem
- Vibration after New Clutch/flywheel/balancer
- tranny probs
- Shift points are off
- Clutch fork snapped
- to much bangage?????
- need 94 vibration help
- Transgo Reprogramming kit HD2 with Yank SS3600
- 12 bolt - pros/cons 3.73s or 3.42s
- 4L60E Stuck in Park (not brake interlock solenoid)
- Flywheel weight, stock vs steel...
- T-56 swap into silverado
- T56 slave cylinder -- how much travel do I need?
- What is the best flywheel option for my car?
- gears
- Best Posi - right out of the box ?
- Trans dip stick FYI on a 4L60E
- In middle of T56swap small question.
- Master/Slave T56 fluid displacement?
- How do you replace a deferential on a 1998 camaro (V6)
- pressure plate bolts (streatch bolts?)
- Aluminum Driveshaft
- Shakin' '94
- New Clutch slipping
- changed rear end to 3.73 gears MPH is off by 10
- T5 slave cylinder vs t56?
- Need Help
- Whos Making the best 4L60E these Days??
- Ls1 t56 on 94 lt1 4l60e
- ES Poly Torque arm bushing - Lip faces toward or away from driveshaft?
- Stressed
- Im gonna punch someone!!!
- T56 Swap in progress - need a little help on wiring
- Could this be my throw out bearing?
- 96 LT1 Sachs clutch kit -wrong throw out bearing?
- Clutch fork rubbing against pressure plate HELP!!
- rear end questions
- Need Trans HELP!
- 95 T56 disengaging problem - Oil soaked clutch?
- T56 swap in progress
- car won't take off
- what is a drop out carrier (also knowns as 'third member')
- rear end whining
- what is the Axle shaft spline count on a 98 camaro with 3.73 gears?
- i just got some 3.73 posi rear end for $300.
- clutch engaged won't disengage
- clutch replacement
- Torque converter flush?
- Clutch wont disengage fully
- OE 3.42 RE vs. Rebuilding my 2.73 RE (w/ 3.42s)
- New to forum, and have a vibration question
- Tranny cooler fittings?
- Could someone please point me in the right direction to a 4l80e?
- 4l60E interchange guide?
- Noisy PRO50 shifter
- Clutch going too far?
- Driveshaft Vibration?
- first post...94 Z M6 trans problems..
- Will this fit??
- Adding brake fluid to a 4L60E?
- 4l60e shift problem
- p1416
- spark plugs
- th400 Gurus
- horrible noise from my T56
- ACC Performance? Stall converter
- TH350 or 4L60E?
- th400 dipstick question
- Slave, Master and Bore Questions
- rearend issues
- whats a good brand for gears???
- M6 torque arm mount
- LS1 Throwout Bearing Throw/Distance
- help with finding a new tranny
- My car won't budge
- Help with Diff Gear Upgrade
- Pinion Bearing
- Knocking from rear end
- Price increase notification for wed this week.
- bad vibration only accelerating?
- Manual valve bodys
- getting the speedo to work with the th400
- Will I notice anything by swapping to the Viper internals on my T-56?
- 4l60e limp home mode?
- Tranny Problem
- Tranny Problem
- *Replacing* Pinion Bearing (Pressed one)
- Need serious help - 4L60/4L60E??
- Clutch Fail
- Edge 3200 stall?
- tranny question
- need tranny gear help 94 z28
- Th400
- 1987 IROC 350 rear choices
- M49 5 Speed tranny wont shift into 5th gear
- Rear end grind rorward and reverse 95 lt1
- replacement or aftermarket clutch slave
- Anyone know the thread size of a stock M6 shifter knob?
- 1993 2.73 to 3.73 swap
- 1995 Z28 tranny swap to a T56 from a 4l60E
- Remove u-joints from alum prop shaft
- chatter/ shudder
- McLeod(Wilwood) clutch master cylinder installation
- Help!!!!!!
- 2-1 downshift clunk on new trans.
- Pulled tranny, chipped bolt hole
- Simple Transmission Question
- 4l60e - odd shifting problem
- Drive Shaft Problem
- full manuel valve bodied 700R4 quit at idle after 300 feet!
- Rear end help for my 96 camaro ss
- Carrier Size 7.5 or what
- 9" rear questions
- witch one is better
- Done an A4 to M6 swap? Gear question...
- will 3.90 motive gears fit on my 94 trans am m6?
- lt1 clutch slipping help!
- Problem with my top speed
- 4l60e acting strange
- what driveline to use?
- Difference between 98 Z28 4L60e and 00 Corvette 4L60e
- LT1 T56 Clutch fork measurement
- 10 bolt question
- Swap in a 4 channel rear in a 3 channel car
- Best Performance Tranny rebuild kit
- Auto Zone or NAPA clutch cylinders?
- Transmission pan ???'s
- rear end question
- Spec clutch install help needed - Please
- 3rd gear miss shift to 5th.
- T5- shifter does not return to center
- Not sure about this car
- GU2/GU5 Diff?
- limp mode
- t56 swap trouble
- Trans Question
- Torsen diff = Amsoil 75W140?
- 10 bolt rear help
- melted reverse needle bearings
- transmission problem (automatic)
- 700r4, how many splines?
- Want 3.73s and have a few questions
- Need a Skip Shift Eliminator.... please help
- hurst quarter stick question
- Transmission slipping?
- T-56 potential problem? please help!
- 4 channel LS1 rear end work in LT1?
- Rear end noise
- clutch or trans lost reverse
- 95 camaro 4l60e interchange
- Little help please?
- drive line vibration
- transmission
- actual limp home, odd that it resets when its shut off
- T56 swap write up ? need one !
- t-5 transmission
- 4.10 or 4.56 gears
- Help?
- What style differential did they have in 93 z28?
- Vendors and 4L60E experts: Likely issue?
- rear end gears
- [VIDEO] Driveline Video How-To Thread
- 2000 Camaro SS Trany Shower.
- ABS problem Swapping in Torsen Rear-end
- Reluctor ring
- 10 Bolt Rehab
- T56 will not shift while started + Fork Grinding on Pressure plate - Two Issues?
- pressure manifold in transmission and drivers side bank running hotter than pass side
- broken starter/ clutch kits?
- Turbo 350 and Lt1 Vss question
- right rear axle?
- How noisy is your M6
- Clutch Questions PLEASE HELP
- No oil pumping to top of engine
- 4L60E FROM A 94 Z28 what years of z28 will it fit ??
- Rear ends?
- differential oil
- What speedometer gears for a 91-93 4L-60 Transmisson?
- Questions about a Strange 12 Bolt for my 93 Z-28 4L-60 EX Duty Stroker buildup.
- Camaro won't shift
- 93-97 clutch pedals on 98-02?
- way to make VSS (speedo) work with TH350/400?
- 4L80E w/LT1 PCM
- trans filter change
- Wierd rear end noise...
- trans swap help
- 94 z28 T56 help
- welding stock shifter stick
- will a 88 gm 1/2ton 4l60 trans fit in a 95camaro
- roar with pedal pressed
- Advice on torque converter for '99 camaro
- Don't buy from art carr in tx
- T56 Input shaft play
- manual trans help needed bw t10
- How long will it last outside??
- Rev Limiter
- Need advice/help
- How much slave travel to release LT1 clutch?
- TCC Brake Switch (P0719) Code
- speedometer off??? 4:10 gears
- 4L60E 4-SPEED trans questions
- Swapping to A4 - OBD1 vs OBD2
- LT1/T-56 Clutch pictures Please!!!!!
- Clutch noise.... only when its "disengaged"
- help with rpm
- do it myself?
- Street Twin Problem...LT1 Clutch fork pivot?
- gears recomdation
- C-Clip Eliminators
- Help! t56 fork assembley trouble.
- Aluminum Drive Shaft?
- Valve body swap?
- 2002 SS: Gear Change
- Newly rebuilt 4L60E giving me huge problems....
- LT1 6-speed guys- HD clutch options/opinions
- Do i really need to upgrade my rear end
- For you TH350 guys, what brand TransBrake did you go with and why?
- leaking 4l65e
- 4l60e tps problems causing surging in gear?
- t56 questions
- PROBLEM not shifting HELP
- Source for 4l60E speedo drive gear?
- Rear end gears?
- Input yoke play. No yoking matter!
- 700r4-no manual 1-2 shift
- Transmission cold dipstick reading.
- 700r4 manual valve body.
- MGW shifter
- rear end
- Stock 10 Bolt Rear - Need 4.30:1 Ratio Gears For 2 Series Carrier.
- Another 4L60E question...
- 94 z will not shift automatically between gears
- please help rear end grind
- Installed new slave, bled, but piston is not moving the fork
- Loose Pilot Bearing
- Interchange question: 98 camaro/95 firebird rears
- B&M shifter
- someone have a pic to show the diference between a single and dual cage sprag
- Replacement driveshaft?
- If you have ever built a powerglide, come in here
- 6 speed handling 650+whp
- stock adjustable clutch master
- in need of some serious help!!
- t56 tech?
- 4L60E Identification
- '94 Camaro Z28 Automatic
