View Full Version : Drivetrain
- im trying to find info on the disassembly of the rear end internals ?
- which fluid to use in t56
- hp lose through a 9 inch?
- stop the whining
- 700r4 lockup help
- 3.90's or 3.73's?
- setting up a ford 9 inch rear end?
- 3.42 guys need help.
- clutch rubs when pedal pressed in all the way. ??
- eaton differential
- 1LE driveshaft?
- Yoke problems, need advice
- TH400 Swap
- I hate the 4L60E
- 98 axleshaft in a 95 Camaro?
- Torsen info needed; had a bolt break
- Will this 12 bolt fit my car?
- Vibration that won't go away
- Edge converters
- What do you guys think it may be?? 4l60e
- how many miles did you get out of stock 4l60E?
- converter lock-up switch
- new drive shaft
- replacing axle shafts
- Engine is out...Transmission?
- Flywheel ??
- Custom 2 piece driveshaft mod
- what do you guys think of the RAM clutches and do i need adj master cylinder for it
- 1984 elcamino help
- wiring reverse lights in B&M Pro Stick?
- who has the best price on a spec3+
- OMG! Clutch again...
- Torque arm
- transmission fluid
- 6-speed hard to shift
- Need a part #
- 6 speed
- How to make a built/bullet proof 10 bolt?
- Manual valve body on the street
- mcleod single disc????
- Tranny Dying by the day
- need some help guys
- Anyone move from a Vigilante to an Edge converter?
- another v6 to v8 swap
- scraping/squeek
- Who thinks I will end up hating my 4.10's?
- 2 things, maybe frank will chime in
- do 4:10 gears require paddle pin kit?
- Transmission Gurus
- Which way does a C-clip go in?
- rear end lube?
- Hard to get into gear when car is running (T56) (Help me kill a mustang)
- plastic clutch hydraulic lines
- stepson fried my 4l60e
- Turbo 350?
- I don't think my rear gears are stock..... (M6)
- Recommend a good clutch for my setup ---
- LT1 Driveshaft....need to upgrade?! ---
- v6 to v8 4L60E swap
- old dana 60
- Gears
- Clutch problem
- Dana 60 Owners
- Red or Blue Loctite Flywheel and Pressure Plate Bolts?
- HELP....Installed new Spec 3 = Grinding
- How much HP can a stock t56 hold?
- B&M Ripper????
- ES or Prothane Motor Mounts?
- mystery noise in rear end
- Will this motor tranny work together?
- New toy under my car.... Ford 9"!
- camaro rear-ends-how different-6cyl-8cyl-?
- Which install kit should I get??`
- Clutch assembly
- A4 Starts in 2nd Sometimes After Rebuild
- Symtoms of a bent shift fork ? How about a seized pilot bushing ?
- Not F-body related tranny question.
- Who here still has their box they used to ship to CPT?
- 6 Speed Swap
- My TRANS Woes
- rear end gear companies???
- Transmisson shifts hard
- Who should I have rebuild my T56?
- Steel drum and sprag th350
- Detriot locker issues
- Who here has a scatter shield???
- tranny stick problems?
- T56 Rebuild Kits, Do These Prices Seem Okay?
- Not sure
- Driveshaft swap??
- Shifter loose somehow?
- Dead 4l60e
- Which 12-Bolt Posi (Eaton or True-Track)
- Anti ballooning plate question.
- Yank converter bolt size ?
- CPT "Direct Bolt In" transbrake TH350
- Adjusting feel of the clutch for 6-speed on '97 SS?
- Who's?
- Leaking T56/ low fluid??
- Somethings not right
- how much will gears help
- Question...
- Th350 Swap
- I Need a Clutch
- Help buying rear
- rear end hold up?
- 95 Z28, automatic shifter problem
- Anyone done their posi/gears set up themselves?
- 2 series 3.73s
- Got my TH350.. Now what
- Transmission guys in HERE!!!
- Where to buy...
- How do I make my T56 NHRA legal to 10.00 E/T??
- Help!TRANSMISSION CONVERSION
- knotchy shifting / occasional grinding
- How do you put the clutch fork back on?
- pedal question
- bad rear end possibly installed??
- Which tranny is best for me?
- Can the V6 rear axle assembly be upgraded
- Auburn posi's
- clunk when shifting
- vehicle shake!!
- Rear End??????
- clutch question
- Strange S60
- Pro 5.0 shifter
- Anyone here running 4.10s in an AUTOMATIC
- hahaha spec III finally bit the dust
- t56 swap electrical problem
- 4.10 and torque arm
- tranny question
- Need to ID a Tranny for my camaro
- McLeod single disc?
- Transmission troubles T-56
- which shift kit for my 700r4?
- 95 lt1 200r4
- How would you clean a dusty Auburn differential?
- T56 fit questions
- Vibration
- T-56 Transmission (Anyone know how to get this part out of it?)
- LT1 clutch disc replacement?
- where to buy?
- Tranny problems?
- where to get a REAR END ??
- just instaled 3.73's, a few questions...
- Will an LT1 aftermarket shifter work in an LS1 car?
- 97 corvette t56 fit in lt1 camaro?
- 15k mile 95 Z28 should i change the tranny fluid?
- T-56 Rebuilder in here!!!
- just installed 4th gen rear and/ ss wheels
- rattling in 1st and 2nd
- is this clutch still usable?
- alternate tool for 3800 & LS1 clutch slave hydraulic line disconnect
- car feels like it goes into neutral in third gear.......
- Christmas special from CPT
- 3.73 gears, 2 questions
- Which brand Converter??
- mcleod street twin clutch ....finished
- throwout bearing...replaceable?
- BULLET PROOF 10 BOLT? You be the judge!
- Is there a special tool for rebuilding a T-56?
- axles
- 4L60E Problems
- I need to fix the trans (6spd). What else should I replace while it's out?
- 410 gear
- New T56 trans
- Free 4l60E core
- does anyone have pics of removing the clutch master cylinder?
- Anyone know Precission Torque Converters?
- TCC Lockup Issues, I need a little Insight PLEASE!
- Slick 50 = WOW
- A4 lags when turning left
- Happy Thanksgiving from PerformaBuilt to all
- Play in tire rotation
- McLeod clutch questions
- Auborn Gears?
- Anyone ever heard of a Luk clutch?
- Where can I get this tranny part?
- Terrible Vibration from Tranny at 4k rpm
- slight pop when releasing clutch
- tranny woes
- Moser 12 bolt questions
- m6 wont shift
- A4 shifter question ...
- Saginaw 4spd? info?
- anyone heard of performabuilt trannys?
- No power transfer
- Spec/McLeod/Textralia-what to buy
- T56 LT1 Z28 6speed Transmission Issue, Please Help!
- clutch noise.
- what's the best brand for rear gear sets???
- price shopping for spec 3+ ....
- Is brute force the only way to remove the pinion?
- Anyone with 3600-3800 stall??
- finishing up t56 swap, problems
- What type of rubber line for the clutch reservoir?
- clutch problems
- Installing an transmission temp gauge/sensor in a 93, will either of these work?
- Are Moser 9" seals prone to leak?
- CPT web site link
- My posi is loosey goosey, but how? Is it supposed to be???
- 700R4 problems! Stuck in gear.
- So ive been told i have bad bands in 4L60E
- finished t56 conversion, just bleeding problem
- What shif Knob do you have?
- Auto trans filter change
- Transmission pan torque spec?
- Just installed new clutch - bad noise with pedal to the floor.
- Talk rear end gears with me! (3.73 vs 4.10)
- 73 Rear End
- Where did you get your 12 bolt or 9" Rears
- RAM Powergrip HD Clutch Sets ???
- Tranny Mount Broke...again
- rear end noise...ahhhh
- New clutch installed.. OMG!! I so forgot how nice it was!!
- Vin number - gear ratio
- So whats the story on 3.90 gears?
- how to bypass skip shift? problem with skip shift and speedo sensor! HELP!!
- Holy crap, massive driveshaft came with Dana, how much is this hurting me?
- Clutch Chatter
- rearend girdle?
- Is this worth the money?
- does anyone have pics of the install of a street twin clutch (mcloed)?
- Clutch compatibility between years..
- stall
- How do I change..
- Rearend question...
- SS & TA drivetrain problems????
- Question about 12 bolt and 9in ford
- One wheel peel on my Z....?
- What companies sell good rear end pkgs.??
- Gear Install on 9" Question
- High RPM Vibration
- Friendly Reminder (avoid problems)!!
- 10 bolt with 3.73
- What's my problem? Slave? Fork?
- Video of my slipping tranny at the track :)
- No clutch
- T56 shift action
- Transmission solenoid
- Spec 3+ or 4?
- Clutch or T56 problem?..Long...
- what length tailshaft for a th400
- Driveline issues! Dunno whats goin on here.
- torque arm question
- new stall!!!
- Manual tranny alternative to T56?
- shutters when clutch applied
