View Full Version : Drivetrain
- Need CClip Eliminators for 4.56s???
- Clunk! New Poly trans mount, U-joints? Torque Arm?
- 50 mph wobble
- Lower E/T mile with lower gears???
- question on torque arm clamp for a 700r4
- Does anyone have any experience with...
- Does this sound like a converter problem?
- how hard to get an 01 ls1 rear end in a 94 camaro
- Raybestos Master Cylinder
- LS1 rear end in an LT1
- M6 x-member, TH-400...spacer? VSS sensor?
- how durable is a stock t56
- New clutch goin on soon need opinion
- squealing on left turn
- 1994 Firebird Auto Trans Shifting Problems
- 10 Bolt limits
- Replacing solenoids on 4L60E
- can i just throw a z28 limited slip unit and ring and pinion in my v6 axle
- gear install kit???
- converter not locking
- Wheel studs? Are 12 MM but longer strong enough?
- 12 bolt question?
- New updated SPEC stage III vs. old version (crap) - good, bad, ugly??
- trans coversion question
- TH400, TCI flex-plate shield, TCI trans shield...what dipstick?
- Cheaper Adj. Master Cyl. than McLeod?
- Rear mounted spare tire...
- Problem with 94Z ?
- turbo 400 with 4.10s and N20?
- parts needed for a4 to m6 swap
- 5 speed trans
- Converter help please!
- turbo 400 question
- New eaton posi/gear install
- auto shifter
- something really bad happend
- Zexel Torsen rear
- clutch?
- What is needed to convert from 4l60E to 700R4
- I need some opinions
- Transmission help T56
- Clutch rebuild $
- 2 Questions: Clutch & Gears
- 6 speed swap
- Stock Gear Series Number?
- Ls1 Ram V.D.S. clutch in a Lt1
- Bad Torque Converter?
- any good clutches besides mcleod?
- HELP - 12 bolt Moser
- limited-slip additive in 4l60e??
- pro's/con's of 12bolt to 9"
- Clutch? maybe?
- tranny
- Spec Stage 3 clutch..way cool.
- Chosing gears. Motive or Richmond?
- tranjny code
- engine stutter when idling in gear
- 4L60E won't shift
- Clutch??
- stall
- tranny temp question
- Rear end thud.
- M6 to A4 swap
- How much to get tranny fluid changed
- Where to buy 3.73's.
- Changing valve body?
- Centerforce dual friction clutch
- 6sp. conversion Need help
- How to lower transmission?
- Driveshaft ID
- What exactly is the carrier?
- 3:23's to 3:73's
- M6+DR's+10 bolt?
- bleeding a clutch
- tranny code
- stock trans cooler question
- continous clunk
- changing fluids
- v-6 rear end
- 94 and 95 tranny the same?
- how hard is it to drop the rear end...
- cam no tune..transmission
- Is this clutch still useable????
- how much power can a stock tranny and rear end take?
- 145mph vibration problem
- Flushing the transmission?
- stupid tranny
- Can't shift out of first!! help!
- How loud is your 12 bolt???
- How to get transpan to stop leaking
- aftermarket trans cooler install question
- t56?
- Posi/Gear Install
- Will a lose trans mount cause a vibration at high speeds?
- T-56 Input Shaft
- Auto VS Manual Trans
- just a clutch or the whole tranny?
- What size welds? Brakes?
- DUAL REAR WHEEL DRIVE??? Fishtailing!!
- tranny temp
- 04 cobra tranny in 95z28 ???
- abs ?
- Installing 4.10's, need a panhard rod for differential?!
- Can I patch / JB weld my bellhousing?
- clutch hydraulics?
- Trans cooler, need to remove trans to install?
- converters
- lost first gear tonight
- Replacing clutch, any details I should know about?
- i have a ? about abs hookn up on a 12 bolt!!
- turbo 350 with 700 tail housing
- 8.8 rearend u-joint
- question about flywheels...
- Why is my McLeod clutch clipping????
- Is TCI street friendly?
- What do i need going from 2.73 to 3.73??
- 1993 Z28 Gears...help
- Please don't tell me i need a rebuild tranny
- Bad wheel hop
- need help with a couple problems I am having.
- 12-Bolt Bearings vs 10-bolt?!
- Rear Wheels move in and Out, need Help...
- Replacement Clutch
- Need your help with clunking noise
- Rear End Fluid?
- Questions for a friend
- How to take care of new Ring&Pinion?
- Does PP need to be in certain orientation for balance?
- Fixed Pinion/Yoke seal, now my gears whine like crazy... WTF?
- how much gear oil does a 2001 Camaro
- Stock gear ration questions
- Console ratchet shifter for 95 z28?
- Yoke/Driveshaft question
- Do torque converters hurt mpg?
- b&m shift kit
- High stall converter
- Need Mcleod Clutch install help pls!
- Center Force Dual Fricition Clutch??
- Say.... does anybody have a......
- I have a FORD 9" Available that came out of a Gen 3 Z28. Housing and Axles $750
- How is/was your experiance with the Spec stage 2/3 clutch
- ??? driveshaft won't come out
- help me pick a stall
- Stronger Transmission???
- Ls1 rear in and Lt1 car
- Spec Stage 4 is BADA** (PICS)
- Couple Clutch questions
- Torque arm bolt size
- sycro problem or ??? on a LS1 T56
- 12 bolt swap, what cars are direct bolt ins w/ posi?!
- Auto transmission service - how often?
- Clutch Questions?
- Torque Converter ?
- throwout bearing
- Trap Speed - Rear Ends
- Installing 12-bolt, few questions.
- Spec Clutch Gone Bad 20,000 Miles
- Transmission question
- Best gear ratio for FI
- Need HELP!!!
- Rear End Woes
- I want new gears. What kind do I need?
- Tranny Jumping?
- need advice on torque converter
- SLP clutch questions
- T56 problems, help!
- A4 going out? Please advise..
- auto tranny pull
- 4.10 Gears
- Which Clutch??
- stock wheel stud length
- Removing stock a4 shifter assembly, what is this hose???
- I'm a happy boy . . .
- flywheel questions
- New synchros and still won't go into gear?
- Trans install-bolt on verter or trans first
- trans temp question please help
- NOOB question, but I have to ask..stock=posi rear???
- Sorry I don't know what a stall is?
- 6 spd NOISY.....time for new fluid?!
- How much to RR a TQ?
- Actuator slave install/Clutch Fork!
- New Gear Break in period.
- Transbrake wiring
- 4L65e Tranny mated to a ODB1 LT1
- LT-1/LS-1 rear axle swaps
- Trans Temp Gauge.Where to Ground Sender Unit.Help
- Are 2.73s really better for highway racing?
- Transmission to bellhousing torque spec.
- Pilot spacer for TH400 swap?
- Gears grinding, Hard reverse gear
- t56 trouble
- temp
- Need help asap please, clutch problem!!
- 4:10 gears
- rearend .....loss of power
- Looking for gear brand suggestions
- Stock gear ratio
- 6-speed noisier after clutch swap...
- Need tech info on 6 speed conversion
- stock 3.42 to 3.73 gears worth it?!
- aftermarket trans pan install problems
- Whining gears in differential?!
- Quick question-help choose clutch
- New Clutch, need to replace throwout bearing??
- Pops out of second when letting the clutch out.
- SLP shifter rocks
- 96 4l60e input shaft TCC ball capsule?
- confused on clutches
- Looking for a transmission part
- i need a 12 bolt! anyone have one?
- so the 4L60E will shift into 2ed at 100mph
- rear end width???
- 1st gear mod ?
- Would mixing up the trans cooler lines cause it not to cool properly?
- I Need Help Bad!
- 4L60E Output shaft ?LS1-LT1
- Can I use used gears?
- TH350 kickdown??
- Clutch Problem Need help ASAP!
- Torsen t-2 carrier
- what's needed for a clutch install?
- Street Clutch for 380RWHP ???
- 4.10's or 4.56's?
- Spec Stage 3 disc
- For those that have bought the Z06 clutch...
- Can I resurface a preasure plate?
- My poor baby is broken, help me...
- Are LS1 driveshaft's really that bad?
- Transmission Gear Puller Schematic
- Tranny is stuck in drive need help ASAP!
- TH350 tailshaft question.
- Short Stick input needed
- question for TH350 pros
- Moser 12bolt - LS1 -> LT1
- difference in width between disc and drum rears?
- How to fix reverse sycro step by step
- epc ?
- Stock 10 bolt -400rwhp ??
- ABS and 12 bolt
- Aluminum TA Cover worth it or scam?
- New Rear
- Clutch fork pivot??
- Pro 5.0 shifter with short stick vs stock shifter with short stick?
- How long will a T5 last on a LT1
- Easiest way to convert to t-56 drop front suspension and engine? or just trans.
- A4 4.11's to 3.42's
- 2800 stall or 3:73 gears??
- How many bottles of Limited slip additive?
