torque convertor for 411 gears
Old Feb 4, 2005 | 01:08 AM
skippermccoy's Avatar
taking my 95 in to have the new posi,gears and trans go put in it and i also want him to do the torque convertor at the same time but i did a search and i am still kinda up in the air on which stall to go for.the car is a 95ta mainly stock excpet for custom long tubes and full duels and the deletes egr air pump.
Old Feb 4, 2005 | 01:26 AM
madwolf's Avatar
Re: torque convertor for 411 gears
I would recommend a Vigilante 2800 for your setup. If you plan on doing some more mods later on, you could still get the 2800 and take advantage of the free restall when you need it, but I wouldn't go higher than 3000 on your current setup or you better have some really good tires.
Old Feb 4, 2005 | 08:11 AM
Loadre's Avatar
Try searching in LT1 Tech and the Drivetrain forum. Lots of info on lots of different companies and combos.
camy 1993
Feb 1, 2015 07:16 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
94redform
Sep 8, 2002 03:27 AM
chesee48
Aug 22, 2002 08:28 AM
