View Full Version : Drivetrain
- hard 1st-2nd shift, then 2nd start!???
- Rear end oil? syn or dino??
- which ATF?? syn or dino??
- tranny?
- Big HP - A4 or M6?
- 12 bolt vs 9 inch
- McLeod single disc with SLP pressure plate - Qs inside
- How often to change rearend fluid?
- Backlash range recommendations ???
- What is a good way to make my 10-bolt stronger?
- Recomendation on where to get Moser12?
- 12 bolt owners inside
- Gotta buy a clutch...
- Rear end thunk concerns
- TH400 Inspection cover bolts
- Does the stock y-pipe come off when doing convertor?
- car stroke btw 1st and 2nd
- Will my rearend hold?
- Spec stage III need to go on a certain way?
- Lost all forward gears/ still have reverse???
- Stage 5 spec
- Bad tranny or computer?
- 12 bolt question, different than most...
- shaking at 100+mph
- Stang 8.8 in 4th gen
- 93Z Tranny/TV cable question. Maybe related to 52mm throttle Body
- Bent shift forks/time for new shifter?
- Transmission Cooler
- 4.10's in A4
- Whine in stock differential
- what does lock-up converter mean?
- Pro-Built Automatics
- strange 12 bolt, lots of drivetrain loss??
- Anyone using the GMPP transmission controller?
- rear end swap
- Where did my hard shifts go?
- Stall T/c
- what clutch to get
- Driveshaft help!
- Lakewood U-Joints Part Number
- Not the normal "grinding" post
- Jarrod's Short Stick
- What Years Did car did this come in?
- 12 bolt install
- 4l60e: QUICK QUESTION............
- Tranny opinion
- Best place to get a used tranny??
- Changing gears
- what size converter do i need
- m6 input shaft seal did a search but.....
- have a question about getting gears installed on my Ls1 camaro
- anybody go from 3.42 to 4.10's????
- The hughes GM30 (3000 stall) converter for three speeds?
- what differential fluid?
- Lugnut Question
- What gears do I have?
- 3.42 or 3.73
- Bang for Buck convertor?
- driveshaft noise? need balanced?
- Clutch dilema: Do different SPEC "stages" use same PP? :(
- Moser vs Strange
- Does anyone actually like their 2.73s???
- Pro-Built 4L60E Rebuild Kit?
- Rearend ?
- Can't get car in reverse!
- Weight diff. between aluminum and steel flywheel ?
- Art Carr race 700r4 problems - 1st is gone, suspected reverse sprag?
- A4 to T-56 Conversion
- 4:10's are in...speedo question
- need help ASAP - what's the best way to drop the tranny pan in a 4L60??
- Royal Purple syn trans oil??
- Feels like i'm ridin the clutch...wait i have an a4
- rear end clunking?
- Gear change?
- For those who got a 2.73 and converted to 3.73 gears
- ExtremeChassis Ford 8.8" rear end
- Notice a change in gas mileage after TC?
- tranney problems
- what converter?
- T-56 Disassembly question
- auto tranny "kick shift"
- tranny cooler?
- Is there a gasket for trans pan?
- TC lockup issues...?
- Who has painted their rear end?
- How much to replace transmission front seal?
- new tranny in, now problems, HELLPPP!
- What is needed to correct the speedo on a 93 Formula?
- bad u-joint(s)???
- torque arm ?
- Clutch/Rearend help
- Actual parts cost for rebuilding a '95 4L60-E?
- 12-Bolt question
- Will a 93z rear fit into my 94z
- Upgrading read axle to a 3.73 posi...
- one rear wheel is out more then the other...
- I think my rearend is shot??
- 3.73, 4.10 or other gear ratio???
- CC306 4.10's 4L60E ,4.10's too much?
- 4l60 downshifting ???
- Need a new POSI!! Help!!
- To lockup or not
- LSD ?'s
- Can my car's 10 bolt handle 4:10's??
- putting in clutch and driveshaft
- Shifter came loose, did I do any damage?
- how much noise is my stock rear end supose to have?
- grinding noise or vibration from tranny!
- ABS and 9inch
- RKSport CAGS Skip Shift kit
- Soft Loc PP and Iron disk clutch is alive and kicking
- Spohn Torque Arm Q's
- What is this part for in Street twin clutch
- urgent easy question, 12 bolt fluid fill??
- Lt1 Tranny
- Installed Pro 5.0 Shifter...
- McLeod street twin install ?????
- Mod to get 1st gear and does manually shifting the my 460 hurt it?
- Push in the clutch, get a grinding noise
- whats the width of a 96 camaro rear end??
- Tranny seemed dead, sat all winter, now runs fine??
- How do I know if I have a 4l60e transmission
- How many people have been lucky enough to bolt on their street twin with no balancing
- How much did you pay for your Torque Converter?
- Beefing up a 4L60E?
- I think my transmission is going out
- How to change differential fluid?
- Synthetic Gear Fluid
- My differential cover is leaking a little. Do I have to replace the gasket?
- Trannys Talkin ?????
- east coast trans guy?
- Got a t56/A4 swap Question!
- auto trans question?
- New gears whine only part of the time.
- transmission
- big block + t-56
- Sigh....trans problems.
- lt1 auto transmission/good or bad?
- which torque converter??? help!!
- Abs Sensor
- T56 conversion??
- Preload on gears..
- Transdoctor.com has a few answers for those with?
- Mcleod street twin question
- Neutral Safety Switch part number?
- Short Shifters
- Need opinions on rear strengthening
- LS1 alum driveshaft u-joints?
- A4 shift problem
- 4.10s - motive or strange??
- Rear End Swap
- R+I Borg T56 in 2001 SS M6...
- proper shifting
- to stay auto or go manual? that is the ?
- rear end question
- another tranny fluid question
- TC or not?
- 12 bolt or 9 Inch?
- Gears affecting my times?
- How much to switch to 3 series carrier?
- pressure plate torque specs
- Motive 4.11 Gears
- Posi rear end??
- just got tranny done, now key is stuck
- Does the Ratech Install kit come with the chalk?
- T-56 Troubles
- Guys with th400 w/ reverse manual valve body
- T56 rebuilder's guide????
- Post M6 Swap Issues.
- A4->M6 Swap Complete!!
- Time for a Stall Converter...which one though?
- Replacing Clutch....Need recommendations
- When does the M6 need a rebuild? with motor rebuild?
- finally nice to have it fixed!!!
- will it hold up ??
- stock driveshaft and 12 bolt
- This clutch any good?
- Need help!!! T56 questions
- Got my vig 3200 in today
- Should I worry about breaking my 10 bolt?
- What did you gain at the track with your Vigilante converter?
- Adjusting Hurst Shifter?
- Is this the input shaft bearing or throw out bearing?
- T56 is making noise
- 3rd gen rear in a 4th gen??
- $ 950.00 to rebuilt tranny ,is it a good price?
- Proform Universal Pinion Depth Setting Tool HELP!!
- New flywheel + new clutch = grinding noise
- 4:10 GEAR guys...Are you using stock steel Drive shaft?
- Those of you with the big cams on the stock converters
- Differential fluid change
- Input shaft questions???????
- A4 won't go into park
- tranny tube part number
- TA Girdle ... Studs or dont bother?
- how much power can the stock rear end take!
- Where can i get a rebuild kit for my posi?
- Lokar 700r4 Dipstick install help
- Odd sounds have me a bit worried...
- Is it hard to rebuild a T-56??
- will a zo6 tranny swap into a 00 TA
- I need opinions on where to go....diff is gone
- Am i downshifting too hard???
- Automatic to Manual :)
- Question about my tires
- 8.5 10 bolt anyone done it?
- Shifting Issue
- 3.73 install myself?
- Help please, big bang(s)!
- Five speed is dripping...
- trans noise
- Rear Clunking???
- 3.90 gear with stock rearend
- 3.90 gear in a stock rear end?
- 4:56 gears in my 94 camaro 6 speed??
- 4th geners: 'Da Rear Go Boom
- SPEC Stage III Clutch users here
- 323 vs 373
- Just broke the 10 bolt
- Rear end blew up
- rear end loose or tight???
- Limited Slip (posi)??
- Is this my carrier?
- what is this bolt for on a 12 bolt, pic inside
- OBD1 Highest Stall Converter?
- 2.73s or 3.23s for a th350?
- 3.73's or converter, or both?
- Rear end poppin
- Little grind while rowing into 2nd gear.
- Question to those with automatic's (700R4) important.
- 94 4L60E Problems
- Best trans cooler for '95 LT1?
- hows this sound for a 4l60e?
- Rear Diff. ??
- Rebuilt 4L60E slipping after 800 Miles!!!
- Would a 4L80E fit in a '95 Z28?
- What causes a 4L60-E to slip?
- just got my strange 12 bolt today, questions??
- TH350 speedometer fix?
- Which will go out first.
- Fidanza flywheel needs balancing?
- 4l60e high wot shift points
- rearend noises
- 12 Bolt: Whats a reluctor ring?
- How much would it cost A4-M6
- rear end additive?
- switching from 26 to 28 axles
