PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. auto. to man. switch out
  2. Pattern pictures of ring and pinion
  3. assembling 6sp
  4. Rear caliber is grinding the rotor
  5. will this tranny fit?
  6. Trans leak
  7. WOT=Limp home mode
  8. 94 3.4 auto driveshaft Q
  9. T56 - T6060 swap
  10. anyone know how much a stock LT1 T56 weighs
  11. Exhaust, Cat, O2 sensor issues
  12. Do I need Limited Slip Additvie?
  13. Connecting clutch mc to slave
  14. hesitation on take off
  15. 95Z28 M6.....Bad clutch?
  16. transmission acting wierd
  17. How can I tell if a gear is 2 series or 3 series?
  18. one & done!
  19. what converter should i use
  20. Replacing Rear differential gasket
  21. 9" Just bought NEED TIPS
  22. Help! Stuck Trans
  23. Converter not locking up in high gear?
  24. Noob question
  25. 94 4l60e transmision compatibility
  26. lost 3rd and 4th. Very upkept 4l60E. Suggestions?
  27. quick Torque arm question
  28. Effects of Rear end Gear Ratio on Dyno #'s
  29. S60 Owners, driveshaft length?
  30. transmission wont shift right
  31. Installing a new shifter. ???'s
  32. clutch problem
  33. 96 4l60e into a 95?
  34. break-in question
  35. Textralia for LT1(383 Stroker)???
  36. Check out our new website
  37. T56 Conversion in a 1st Gen
  38. Help me choose a posi for my 10bolt!
  39. To much atf?
  40. What to use to flush cooler and lines?
  41. Quick clutch and PP question
  42. Performabult Sale And More!
  43. quick clutch question
  44. 95 4L60E into 94 Z28
  45. What could make my clutch engage/release point change while driving?
  46. Is there a clutch that can hold over 800HP?
  47. Need a little clutch help!
  48. Whats broke? Throwout bearing or pilot bearing
  49. Is this a stock clutch disk?
  50. What are my options with different vss? Please Help ASAP
  51. First gear jammed in an 4L60E
  52. lock up converter in a powerglide
  53. Cutloose in 2ond @ 400 RPM
  54. E-Brake Brackets
  55. M6 Atf Poll
  56. What is this transmission? Casting Number?
  57. cooler line/trans cooler help
  58. annoying sqeaking noise
  59. Best rear gear for the 1/4 mile
  60. 4L60E's weight comparison
  61. crooked rearend
  62. trans problem
  63. Fuddle Racing?
  64. How hard to rebuild McLeod master cylinder
  65. 4.10 install what went wrong?
  66. Rattling sound between gear changes.. 95 6speed
  67. Th400 or 4L60E
  68. 4l60e rebuild kit question...is this good enough?
  69. 3200 stall driving questions
  70. LT1 6 speed in LS1?
  71. Will a 153 tooth flexplate bolt to a high performance torque converter?
  72. Hayden 679 cooler
  73. bad tft sensor
  74. loud 2.73's?
  75. Where to get mikronite process done
  76. Ring and Pinion gear replacement
  77. clutches gone in my auto?
  78. how to remove tailshaft 4l60e
  79. Shift points on a TH350 swap?
  80. tuning in 700r4 shift patterns?
  81. Missed Shifts
  82. how do you convert a 95 Z28 4l60e to work in a 94 Z28
  83. Transmission replacement
  84. shift solieniod
  85. Need pigtail for VSS on T-56
  86. 3.73's
  87. Labor Cost/Size of Converter
  88. is it easy to switch from manual tranny to auto?
  89. Clutch Pedal Problems
  90. Tranny leak, any help would be great.
  91. Break in Period for Strange 60?
  92. Drag radials = broken 10 bolt...Yay/Nay?
  93. Need Help - Axles and LSD
  94. synthetic ATF in M6...not supposed to?
  95. how can i tell of my 10 bolt
  96. 9" 3rd. member questions/info needed?
  97. Can I use a 8.5 truck posi and 3.73 gears?
  98. vibration and leak issues
  99. 4L60E Lo/Reverse Stack-up Question
  100. Strange drivetrain noise
  101. Vig3k sat in garage for a year, will it be ok?
  102. Did my rearend go out?
  103. 4L60E special tools
  104. i need some help...'94 4L60E Z28
  105. performance transmission builder??
  106. 10 bolt axle
  107. Bent throwout bearing? (video)
  108. T56 donor cars
  109. lt1 clutch problems
  110. 4L60E Trouble
  111. Simple Ring & Pinion Question?
  112. 4l60e from 95, put in 94. 2-3 wot no shift.
  113. Play between the axles after rebuild - Torsen worn or something else?
  114. Will V6 rear axle fit V8?
  115. Serious moser 9'' problems... Any ideas?
  116. Another 4L60E done!
  117. Whats the difference in a glide and turbo converter?
  118. 94 Rear end
  119. Burnout with a 4l60e
  120. th400 fluid fill ?
  121. LT1 4L60E difference 93-94 and 95-97?
  122. New Camaro; speedometer off
  123. HELP with T56 to T5 swap!?!?!?
  124. Help with a problem trans or converter?
  125. My Mosher gears whine bad, should they.
  126. Steel driveshafts & vibration?
  127. Gear whine and T/A Cover help
  128. 'Drill mod" Pix?
  129. Need a gear pattern check (pics inside)
  130. transmission takes a while to shift? Why?
  131. Will a ls1 4l60e work with a Lt1...
  132. finished 8.8!
  133. Doing 3.73 Gears, what to expect from stock 10 Bolt?
  134. having problems setting up Summit gears
  135. LT1 F-Body Clutch Review Write-Up
  136. An appology for delays from CPT
  137. Hypertech shift firmness programming and tranny wear?
  138. Converting drivetrain question(stupid)
  139. Piolet Bushing or Bearing?
  140. have a 9 inch rear end and it seems to ride heigher on one side?
  141. Basic Shifting Question
  142. Reverse Lockout Question
  143. tranny cooler.
  144. What size / were to buy trans bolts?
  145. who can definitively tell me what it takes to use a 94/95 trans in a 96+
  146. Wont start
  147. Best bang for the $ gears
  148. Making your auto last longer?
  149. I think I ordered the wrong shifter
  150. broke 1 bolt on flywheel-I can still run it right?
  151. Need help with transmission info
  152. Axel tubes seepage...
  153. Clutch master slave cylinder help????
  154. Should I use this clutch?
  155. Fuddle
  156. Rear of car grinds when reversing?
  157. Wont shift
  158. B&M Hammer
  159. removing hydraulic throwout bearing on 01 3.8 t-5?
  160. SPEC 3, or 3+?
  161. clutch fork rubs on pressureplate. need help
  162. Something New From Performabuilt "restoration"
  163. got problem need help fast
  164. Slave cylinder 1995 camaro LT1!!
  165. T-56 Shift Fork Replacment
  166. stock z28 rear axles ring gear diameter?
  167. drive shaft diameter?
  168. Broken Clutch fork
  169. Pressure plate balance
  170. T-5
  171. McLeod Twin Disc. LT1
  172. need HELP ASAP - how to remove c-clip on axle
  173. Will doing this mess something up?
  174. New rear end
  175. How do you get over 125 mph on track with 4.10's?
  176. Need new flywheel
  177. 12 bolt vs. 9 in.
  178. 2nd gear gone :(
  179. Problem setting proper backlash with Motive 4.11
  180. PerformaBuilt FATHERS DAY SALE !
  181. Will a t5 5sp v6 transmission fit v8
  182. turbo 400 swap
  183. Clutch kits
  184. Won't shify out of park!!
  185. LT 4 pp & dual friction clutch not enough?
  186. Help on a picking a new driveshaft!
  187. Manual question
  188. Need a little Info on replacing the pinion seal.
  189. Poly trans mount
  190. ok gear swap question?
  191. 1994 z 4l60e issues
  192. Questions for those with over 450RWHP AND 4L60E
  193. Did all SS's come with aluminum driveshafts?
  194. Loose pinion bearing???
  195. What gears should i get?
  196. 93 LT1 A4 wont shift
  197. Odd noise wihle shifting
  198. So ....?
  199. Super t-10
  200. clutch will not press down
  201. axle bearing removal - need help soon...
  202. new guy just want say hi and ask simple question
  203. 94Z28 trans removal/clutch replacement
  204. Code 81 What Now Damn 4l60e Help Please.
  205. Pinion seal question (I searched)...
  206. A complete list of obd2 gm powertrain codes
  207. differential pinion shaft - removal tricks? need help quickly please
  208. Driveshaft length with S60
  209. Rear End about to blow??
  210. Driveshaft Length Help
  211. Amsoil Manual Transmission Fluid In M6
  212. Transmission Trouble
  213. Gears and speedo
  214. Vss 4l60e
  215. what gearing?
  216. new 2001 camaro ss rear end price?
  217. Vibrating BAD!
  218. Turbo 400 trouble!!
  219. T56 6 Speed Transmission Swap
  220. My turn at a ticking thread. When braking hard and clutch not pushed in.
  221. Lock up function for torque converter not working: still OK to drive?
  222. Replacing spider gears in Torsen unit
  223. Reusing a Disc?
  224. TH350 vs 4L60E
  225. Vibrating, Grinding Noise From T56
  226. Pinion run-out
  227. Turbo 350 gear question
  228. T56 to A4 Swap. Help Needed!!
  229. B&M shifter linkage help.
  230. Which do you feel is stronger?
  231. Transmission interchange question
  232. Clutch fork question
  233. VSS not working
  234. Swapping out carriers?
  235. where do I get slave cyl plastic "hat"?
  236. 98 Tranny To 94 Z-28
  237. How Do My Syncro's Look (Pics)
  238. hard to find 5th and 6th on t56 h-pattern gone??
  239. Sent the tranny to CPT today!
  240. Disengagement issues - Street Twin
  241. Need help Fast
  242. No 2-3 shift at WOT. How do you fix it?
  243. T56 Removal - 95 Z28 (So Close, Bell Housing Hiting Tunnel)
  244. replacing rear differential grears
  245. clutch kit <$500
  246. 95 z28 26 or 28 spline axels
  247. Help with axle removal, need ASAP!
  248. Vibration and noise problem 2001 SS M6
  249. Flexplate to crank bolts keep coming loose.
  250. Clutch Recommendation?
