quik help identifying my rear end
Old Feb 25, 2005 | 08:49 PM
97Transam123's Avatar
i just wnet outside and got some number off of my rear diff i got 28041414 the last 14 the 1 was half gone so im not sure what else it could be. but i was wondering if anyone knew what this number meant. im trying to indentify what rear end i have so i can get new gears for my car. i have a 1997 pontiac T/A with a m-6 6 speed trans. any replies/advice would be appreciated
-Kevin
Old Feb 26, 2005 | 06:25 PM
SVWHAT's Avatar
Re: quik help identifying my rear end
Look in the glove box for the sticker with all the different codes. If you have a GU6 on that sticker you have a 3.42 rear end Gu5 I believe is a 3.23.
Old Feb 26, 2005 | 06:44 PM
i do not have the numbers in my glove box. i see a patch where a sticker could be but there is nothing their, is there anyhere else? i read that they could be in the trunk and i looked but i dont see anything around the spear tire or underneath the mat. i cant believe its this hard to firgure out my gear ratio .
Old Feb 26, 2005 | 08:16 PM
Mizz96Z28's Avatar
Try your driver side door, sometimes the codes are there near the latch mechanism.
Old Feb 26, 2005 | 11:03 PM
Capn Pete's Avatar
Well, if it's a 6-speed car, then there's really no question.....you've got 3.42's! They're on a 3-series carrier, so when you're ordering new gears (4.10's, I'm guessing??) then be sure to order for a 3-series carrier.
The only thing that I'm not sure how to identify without pulling the cover, is whether you've got an Auburn, or a Torsen diff? My guess is you've got the Auburn, since that's what was in my friend's '96 LT1 car, and I think that the Torsens were used more in the newer LS1 models.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
