Do It Yourself Gear intall
Old Feb 11, 2005 | 10:54 PM
DarkRider's Avatar
I am 20 years old and I have been working on cars since aboutr 16, I have never really got into the drivetrain, I am doing my clutch next weekend and I want to do 4.10's also, how hard is that to do and what tools does it require.
basically is this OK to do for a DIY mechanic.
thanks
Old Feb 12, 2005 | 07:22 AM
97FormulaWS-6's Avatar
Re: Do It Yourself Gear intall
Honestly... for a DIY it's a crap-shoot.
It cost me about ~$150 for the tools; the most expensive being the pinion depth indicator, and the backlash indicator mount.
With the guidence of people who have done this before, I was able to do it in about 2 hours the first time... the second time with different people I did it in about 1.5 hours... the third time it only took me about an hour to get rid of that POS 10-bolt rearend that did NOTHING but whine and vibrate no matter how things were setup and bolt in my new Strange 12-bolt and Denny Nitrous Ready DS...
I've heard of people having good luck doing it themselves, but from someone who is 24 and has built 4 cars from the ground up, and has wrenched on cars since I was 10; I've come to the conclusion that at this time and skill level, I'm leaving setting up gears to the professionals. I can build engines, trannys, frames, and just about everything else, but setting up rear end gears is an art form.
Old Feb 12, 2005 | 09:13 AM
chris718's Avatar
the proper methods include the use of a pinion depth gage,calculator ,backlash gage,bearing press,torque wrench,and a method to crush the collapsable spacer to yield the proper rotaional torque on the pinion shaft.this is very important .as a youth i watched others attempt this with crude methods,and quickly understood that there was no substitute for the proper tools as the results when they were used was always as a sucess rather than an immediate or eventual failure that would occur without them.www.ckperformance.coom
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
