Recommend a good clutch for my setup ---
I will be running a 600 crank hp le2 setup with a 125hp shot of n20 through a m6 and 4.10 gears on 315s. What clutch disc do you guys recommend I run? The guy before me says he put in a "centerforce stage 2" but I dont think it will be up to the new task (pretty much stock now).
What clutch parts should I get/upgrade while I am doing the engine rebuild? Thanks ---
I am hoping it will be 475hp at the crank, then add a 125 shot, so I guess 600hp isnt far off (he rates his le2 packages at 425 REAR wheel hp), hehe
Spec type 3 it is....says good for 680 ft lbs of torque!!! ---
