Auto trans filter change
Hello,
I know this topic is constantly slogged, but I think I have a couple of pointed questions. This is on a '94 Base-model Camaro with 150K miles (obviously with an automatic trans).
I'm a Ford guy and we can get real nice rubber-over-metal gaskets with ferrules in the bolt bosses - they make for a wonderful seal and install (no overtorquing, etc). Is there a similar animal (be it Dealer only, Felpro, et al) for the Camaro?
The rubber/steel grommet seems to be an area of PITA-ness. Is it requisite to replace this, or if it looks good, do you leave it be?
Lastly, is Dexron III (I think that's right) the still-current fluid? Again my background is Fords, and they liked to sneak-in retroactive TSB's recommending a newer fluid (i.e., MV instead of Mercon).
Thanks so much for any thoughts and advice!
So you just want to know if they make that gasket, that is it? I don't know if those are really needed. I got a completely rubber gasket with my filter, and it has been holding up just fine.
Yes Dexron III is still used, it also tells you in the manual if you still have it.
Did you replace the grommet inside the trans? Was it necessary to do so?
I'm aware of what the manual says regarding fluid recommendations. I simply wanted to confirm that there have been no TSB's requiring a different fluid.
Thanks for the reply.
No I did not change the gromit on the inside, assuming you are talking about the gromit connecting to the filter itself. Mine was in awesome shape so I left it. Changed the filter, bolted it back up, added fluid, was done.
I've seen those type of gaskets before, but have not looked for one for a trans pan, so I can't help there.
And MSZ28, thank you for the follow-up. I'll eyeball that grommet and if it looks alright, I might just leave well enough alone.
Thanks again for the replies.
jb4xx
Feb 2, 2015 10:00 PM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
