torque arm question
Old Nov 12, 2006 | 08:30 PM
95LT1conv's Avatar
torque arm question
what tends to happen when the tqarm bushings wear? i have something banging directly under the tunnel under hard acceleration in 1st or 2nd gear and im not sure if it is in the driveline of if it is the ypipe. almost feels like the trans is hitting the floorboard. i have already replace the trans mount.
Old Nov 12, 2006 | 11:05 PM
The rubber bushing holds the TA inside the clamshell TA front mount. If the bushing is damaged, its possible the TA could contact the mount.
Old Nov 13, 2006 | 11:22 AM
95LT1conv's Avatar
any other thoughts?
Old Nov 13, 2006 | 11:31 AM
Mikey97Z's Avatar
That's what happened when the bolt fell off of my torque arm bushing mount. If that's what happened to you, BE CAREFUL because acceleration is making it swing UP, but when you hit the brakes, it can swing DOWN into the pavement and WRECK YOUR CAR! You need to check it out soon!
Old Nov 13, 2006 | 04:54 PM
lethal93ta's Avatar
it could be the trans mount itself and the trans is hitting the floor, mine let loose at WOT one time, man did the bang it felt like the trans was comming out of the floor.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
