TH400 Swap
TH400 Swap
Hey everyone im new here but i have a question for everyone. i have a 94Z28 that ive been building up and im on a budget. i got a good deal on a TH400 so i want to put that in. how hard is the swap or is it even possible? Any help would be greatly appreciated
Go to my mods list and look over the "Drivetrain" section to see what's involved. You will end up requiring an A4 program in the PCM to get the speedometer correct, and that means you will have to deal with the codes for the missing 4L60E electronic interfaces. You will need a new driveshaft with a TH400 slip yoke, and a slightly different length. The M6 tranny cross-member can be modified to support the TH400. There are no clearance issues. The VSS from a mid-90's GMC truck can be used. Lokar now makes a longer dipstick tube, to get it forward, out from under the cowl.
You better like the high RPM buzz of the LT1 engine, because the lack of an O/D in the TH400 can be annoying. The Gear Vendor O/D unit it the fix, but it can get expensive, and it adds a lot of weight.
http://members.aol.com/InjuneerZZ/Mod.htm
Thanks for the help. im sorta used to the buzz, i was running 3.73's so on the freeway it ran at 3,000rpm in o/d. im not planning on the freeway with the new build so im ok with the trans. a lot of people on the f-body forum im on are trying to talk me out of it. if its not that difficult to do whats the problem?
by the way your car is badass
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
