mystery noise in rear end
Old Dec 11, 2006 | 11:09 AM
camaro322hp's Avatar
hey guys, it's been a LONG time since i've been around here. nice to see the board is still active.
my car is a 99 Z28 M6.
anyway, about 2 years ago, i heard a cyclical whining noise coming from my rear end. i took it into my guy, and he found a bad bearing around the pinion seal, as well as bad axle bearings. he replaced the pinion seal bearing, as well as both axles and axle bearings. i had him put 3.73 gears in while he was in there.
up until a couple months ago, all was good. however, recently, i've started hearing a different noise from the rear end. this noise is definitely different from the cyclical whining i heard 2 years ago. this noise is more of a clunking, or a knocking, and it's proportional to the speed of the car.
i took it to the same guy, and he heard the noise while we road-tested. he took the rear end apart, inspected every bearing, and said he couldn't find a problem. all the bearings were good. while he was in there, i had him go ahead and replace every bearing in the rear end, as well as both u-joints on the drive shaft.
after all this work, the noise is still there! what else could it be? what else should i look at?
thanks for any help. this noise is going to put me in the crazy house....
Old Dec 11, 2006 | 01:14 PM
The Engineer's Avatar
How about the U-Joints in the drive shaft, are they getting worn-out?
WD
Old Dec 11, 2006 | 02:12 PM
TJsrh420's Avatar
yep i got the same problem. i have a 97 z28 and on a fast start it has this loud clunk noise and when i accel really hard it does it to. my pest guess that i can tell you is check the back lash by moving the ring while the pinion gear is held. i don't know the exact measurment cause i don't got alldata or mitchelle but if too much back lash is there then it will whine and clunk. i've had this problem once before and now again. i hope this helped and if i'm wrong i don't doubt someone will speak up. peace
Old Dec 11, 2006 | 02:19 PM
WD
both u-joints were replaced, and the noise is still there.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
