So ive been told i have bad bands in 4L60E
Old Nov 18, 2006 | 03:42 PM
Future_Z_Owner's Avatar
So how screwed is this transmission? Because im no pro and im not made out of money either.
Old Nov 18, 2006 | 08:12 PM
Performabuilt's Avatar
Supporting Vendor
Well the 4L60E only has one band . the 2-4 band , But without additional information it would be hard to tell you muc h what is the trans actually doing ?
Old Nov 18, 2006 | 08:43 PM
ok sorry for the lack of info.. Alright so basically at WOT i hit and just bounce off the rev limiter at 80 mph. No shifting just redline lol
Old Nov 18, 2006 | 11:09 PM
Supporting Vendor
how do the shifts feel at light throttle
Old Nov 19, 2006 | 07:20 AM
They are very firm shifts ..... the prev owner had a shift kit put on.
Old Nov 19, 2006 | 09:09 AM
12SCNDZ's Avatar
Most likely the 2-4 band.
Frank
CPT
Old Dec 3, 2006 | 06:39 AM
Gvnitup's Avatar
2-4 Band
I just curious, you say it is the 2-4 band causing a sloppy shift. from 2-3 gear. But what if when it stops shifting from second gear to third to fourth because of the sloppy shift. Would you say time for a rebuild, or band replacement?
Old Dec 3, 2006 | 07:56 AM
12SCNDZ's Avatar
Sounds like potential rebuild time.
Frank
CPT
Old Dec 3, 2006 | 03:30 PM
respectirocz's Avatar
Originally Posted by Pro Built Automatics
I would say that it is because of the "D-1 procharger, dual intercooled & last dyno 602 hp and 634 fpt", this is way too much HP with a stock unit to hold up for very long. This is the cause of the transmission going away. The transmission has to be setup from the beginning to handle the additional HP & torque you have to last & shift correctly. What brand torque converter are you using?, and what stall & diameter? and what rear end gear ratio are you running? I can be of help here, let me know the above please.
but he's not the original guy with the problem
Old Dec 3, 2006 | 04:39 PM
bombebomb's Avatar
Does anyone else find it odd he is bounceing the limiter at only 80 mph in 2ed? Mine don't hit 3rd till 90~. Do you have 3.23s?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
