does anyone have pics of removing the clutch master cylinder?
No pictures; it's a straight forward job, just hard to get access. The master cylinder is mounted to the firewall, just below and slightly behind the brake booster. There's a rod that passes through the firewall that connects with the clutch pedal. It's held on with a retaining clip that must be removed. The interior firewall has the nuts that mount to the U-shaped mounting "bolts", unbolt them. You'll also need to unbolt the clutch reservoir and the slave cylinder (straight forward).
stockssn2o
May 25, 2015 08:54 AM
