700R4 problems! Stuck in gear.
Old Nov 18, 2006 | 09:44 PM
BLK96Z28's Avatar
The car is an 1989 350tpi with a 700r4.
I put the car in park and I felt it drop into reverse. I turned the car off and then went back out and started it. I put the car in drive and it did not shift from reverse to drive. It is stuck in reverse. The shifter moves, but the transmission doesnt shift.
The car starts althought its in reverse. The tach is stuck at 7000rpms(max). When the car is turned off the car will roll, eventhough it is in reverse. Also when I towed the car home there was a little bit of tranny fluid leaking.
Im guessing maybe the linkage came disconnected from the tanny, I have not looked at the car and I am hoping that somebody will be able to tell me what is going on.
The transmission was rebuild about 2 years ago, so I dont think the transmission is shot.
Old Nov 18, 2006 | 11:08 PM
Performabuilt's Avatar
Supporting Vendor
sounds like the linkage has come loose either externally or internally
PCLZ28
Dec 24, 2015 05:19 PM
jimmybandana
Mar 22, 2015 07:44 PM
BPS
9
Mar 5, 2015 10:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
tds1213
Nov 27, 2014 12:55 PM
