converter lock-up switch
Old Dec 18, 2006 | 04:51 PM
JAG05's Avatar
Has anyone put a converter lock-up switch in their car? IS it worth doing? And how do you wire it up?
Old Dec 18, 2006 | 04:55 PM
12SCNDZ's Avatar
The computer controls lock-up. Why mess with that? Most who install a manual switch, end up forgetting to lock the converter when they're supposed to, and overheating the 3-4 clutches.
Frank
CPT
Old Dec 18, 2006 | 05:23 PM
JAG05's Avatar
I heard it pulls harder in 3rd when you lock it up.
Old Dec 18, 2006 | 07:04 PM
12SCNDZ's Avatar
Locking the converter in the quarter mile will usually slow the car down. People often make the misconception that just because it makes more HP on the dyno with the converter locked, it'll run quicker ET's. This is false...When you lock the converter in the quarter mile, it usually drags the engine RPM's down below the peak HP range...Usually slowing the car down.
Frank
CPT
Old Dec 18, 2006 | 10:43 PM
JAG05's Avatar
nice to know.
Old Dec 19, 2006 | 12:56 AM
Pro Built Automatics's Avatar
When the torque converter is "matched" to the motor, you will always go quicker & faster with the torque converter unlocked in normally asperated motors. A good torque converter is always multipling torque, even if very little at high rpm's. Once you lock up the TC, the torque multiplication is gone, and now it is worse in the terms of HP loss than a manual transmission, etc. I have found that when someone has a manual switch to lock up the TC, they usually forget to unlock it, and it will break away at WOT, gradually taking out the TC clutch in the process. If the computer works for lockup, use it. If not there is GM vacuum switch that will work very similar to the computer for locking and automaticlly unlocking the TC, without a manual switch.
Old Dec 19, 2006 | 06:48 AM
rskrause's Avatar
Moderator
Like the tranny pros said, locking the converter produces better dyno numbers but nearly always worse drag strip performance.
Rich
Old Dec 20, 2006 | 01:08 AM
Daniel6718's Avatar
dont most ls1 guys tune their autos to lock at 40-60mph or more with shift exstension or w/e it is?
ive seen some drag videos of guys locking them and it seems to pull harder
http://s97997631.onlinehome.us/temp/...2th%202006.wmv
http://s97997631.onlinehome.us/temp/...026%20970b.wmv
i think it would help more for those who run shorter gear and can pull more mph out of it
MichiganSkip
Jun 8, 2015 10:30 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
timmy39120
May 2, 2015 05:12 PM
