Transmisson shifts hard
I have a 94 Z28 with a 4L60E transmisson. If I accelerate fast it kind of jumps into second gear. The other gears are fine, what is my promblem. I tried to search but I could not find any info.
It's supposed to do that to some extent, even stock. If any programming has been modified, it will probably be more pronounced.
It's stock, a guy that I work with said that I might want to change the tranny fluid. It only jumps into gear like that when I take off fast. It all most feel's like the tranny is going to come threw the floor board.
There are a few possibilities here. As stated already, check for codes.
The 1-2 accumulator spring may also be broken.
Is this a "slide-bump", or just a hard/quick shift?
What does the fluid look like? Pink? brown? Black? Does it smell burnt.
Frank
CPT
Frank
CPT
armedtrigger
02-24-2015 08:30 PM
