setting up a ford 9 inch rear end?
Old Dec 20, 2006 | 01:29 PM
ghost stripes's Avatar
what does it take to get a rear end to fit in a 95 f body ...not many result when searched for
Old Dec 20, 2006 | 04:31 PM
OBE1 95Z28's Avatar
The main mods are provisions to mount a torque arm, spring perches, LCA brackets, axle width and mounting plates for the brakes.
Old Dec 20, 2006 | 04:42 PM
mdacton's Avatar
your miles ahead to just buy one from moser....you can get just the housing and axles
Old Dec 20, 2006 | 09:20 PM
lethal93ta's Avatar
yep a housing axle kit with the torque arm bracket lists for 985, your better off just buying a kit from moser than dealing with it, a set of custom axles are around 500 bucks so for 500 bucks you getting the housing/bracket and axle bearings, its not worth all the work it would take to make one fit in there.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
