clutch problems
Old Nov 19, 2006 | 12:47 PM
chevycamaro210's Avatar
clutch problems
i have a v6 1997 camaro and the other day i was tryin to bleed the clutch and the fluid got low and i got air in the system now when i filled it up n tried to bleed it it seems if the clutch does not want to build up pressure can anyone help. thanks
Old Nov 20, 2006 | 02:55 PM
mmmchickenboy's Avatar
you might try using gravity to bleed it. remove the cap from the master cylinder, then open the bleeder. just let it drain for a while, but make sure the reservior stays fulls.
or, you can keep trying to bleed it, but dont let the fluid get low in the res.
Old Nov 20, 2006 | 09:38 PM
I got it to finally bleed i bought the one man bleeder from autozone n i had to make a rig so that the little hose that goes over the bleeder to clamp it down to a adapter then hooked it up to a hose from a power steering pump then clamped it down onthe bleeder valve and i pumped the clutch like 20 times and it worked. thanks for the help though
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
