eaton differential
It's a good limited slip. But I wouldn't install one if you have a decent working LSD now, only if it was worn out and needed to be replaced anyway. As far as gears, if you mean the ring and pinion that determine your rear axle ratio, it will not come with the diff and unless yours are worn/broken or you want a ratio change you will not need them.
Rich
Rich
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 21, 2015 04:31 PM
