97 corvette t56 fit in lt1 camaro?
Old Nov 27, 2006 | 06:41 AM
94_camm's Avatar
will a 97 t56 tranny fit in an lt1 camaro?
Old Nov 27, 2006 | 08:43 AM
Sweetred95ta's Avatar
That's an LS1 car, so I know the bellhousing wouldn't bolt up. LS1's use a different master/slave cylinder setup. I wouldn't think it would work (even if you used your stock bellhousing). I think other things are different, too, but I'm not sure.
Old Nov 27, 2006 | 08:55 AM
Capn Pete's Avatar
There are issues just trying to swap between LT1 / LS1, let alone from a C5!!! They use a "trans-axle", so it definitely WON'T work!! Just search around ... you'll find an LT1 T56 and it'll make things MUCH, MUCH easier for you! Is your current one broken, or are you doing a swap or something? Why not get yours rebuilt? (probably cheaper and more effective in the long run).
Old Nov 27, 2006 | 10:13 AM
C5 T56, with torque tube front connection and integral differential mounted to rear:
Old Nov 27, 2006 | 12:50 PM
Capn Pete's Avatar
^ ^ neat pic ... I've never seen that before!
Perhaps you could answer a question my buddy and I were talking about the other day. On a C5, the clutch is still bolted to the flywheel on the back of the ENGINE, correct? But what about an auto ... is the converter bolted to the engine as well, or is it in the "bellhousing" of the tranny at the back?
nballisru
Dec 14, 2014 05:01 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
TYLER94Z28
Dec 3, 2014 07:05 AM
