Auborn Gears?
Old Nov 22, 2006 | 09:39 AM
bitchin94's Avatar
Auborn Gears?
What do you think about Auborn Gears. I found and entire diff for $250 its the hole 3 series carrier. Right now I have 2.73 but Im geting 3.73s. I was just wanting some opinions on this rear diffs.
Old Nov 22, 2006 | 12:50 PM
MyShibbyZ28's Avatar
250 for a stock auburn posi is a bad price. You can find them cheaper, or buy a zexel-torsen for about 300 which is way better than an auburn will ever be. You don't need a 3 series carrier for 3.73 gears in all cases. They make gears that fit 2 series in 3.73 ratio.
Old Nov 22, 2006 | 02:36 PM
godspeed1976's Avatar
Arnt those kinda gears refered to as "thick"?
Old Nov 22, 2006 | 06:32 PM
bitchin94's Avatar
Oh ya and the diff is a SLP aftermarket and isn't used, sorry I forgot to mention that. By the way what do I have to do to switch to a 3 carrier and what will this effect???
Old Nov 23, 2006 | 07:05 PM
If the carrier is already a 3 series you do not have to switch anything. It is either a 2, or 3, series. You cannot change that. You can change what gears go on what carrier though. Some companies make 3.73 (normally 3 series) that fit 2 series gears. However, a 3 series gear (that is made for a 3 series carrier) can fit a 2 series carrier with a spacer.
Just buy whatever gear you want, that is made for your carrier.
Old Nov 24, 2006 | 09:37 AM
bitchin94's Avatar
By chance does any one have a link to a site that sells the 3.73 in a 2 series thanks
Old Nov 24, 2006 | 10:08 AM
If the carrier you are buying is a 3 series, you need a 3 series gear.
http://www.jegs.com/webapp/wcs/store...20737_-1_10167
There's some, just click details to find the carrier series. 3.08 and down is 2, 3.23 and up is 3.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
