95 lt1 200r4
Old Nov 29, 2006 | 06:13 PM
deadcamaroz28's Avatar
95 lt1 200r4
The question is what all do i need to put a 200r4 in my car? The car is a 6 speed. If anyone has done this what do i need and where can i get the stuff?
Old Nov 29, 2006 | 06:49 PM
12SCNDZ's Avatar
One question...Why? It takes alot of money to build a 2004R to handle any power. You'd need a custom crossmember, and driveshaft. How would you run an electronic speedo off a transmission that only has mechanical speedo provision? What are you going to hook your torque arm to? You'd also need a '93 style throttle body, and TV bracket.
To answer your question...alot of money and fabrication.
A 700R4 is a much better choice for a '94. They originally came with 700's in '93, so all the parts are available to make one work. You'll still need a '93 style throttle body and TV bracket, though.
Frank
CPT
Old Nov 29, 2006 | 07:43 PM
rskrause's Avatar
Moderator
What Frank said!
Rich
Old Nov 29, 2006 | 09:14 PM
mostly personal preference.I know they can live in 9 second street cars.
Old Nov 29, 2006 | 10:04 PM
9formula4's Avatar
get a th350 or th400. There is no reason to put a 200r4 in these cars. I thought the 200r4 came in the V6s only also. The bellhopusing would not fit the LT1
Old Nov 30, 2006 | 12:33 PM
Sweetred95ta's Avatar
I would have confidence in Frank to build you a 60e that could live into the 9's and cost less than a 2004r.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
